Author Topic: EEVblog #1337 - I Bought An Electric Car  (Read 103575 times)
Offline Gyro
Re: EEVblog #1337 - I Bought An Electric Car
« Reply #25 on: September 19, 2020, 12:13:05 pm »
Looks like my care does not have the VESS simulated engine noise sound system. Manual shows a button for it which my care doesn't have.
I thought that was a mandatory thing?
Yes, it's certainly mandatory in the UK - and other European countries that I know of. Our Kia has a reversing bleeper that uses the same speaker, it's a little annoying that it comes from the front of the car rather than the rear but is useful for shifting people standing in front of your parking space at the supermarket when you want to pull away!
Best Regards, Chris
The following users thanked this post: Lord of nothing
Offline Lord of nothing
  • Country: at
« Reply #26 on: September 19, 2020, 12:28:07 pm »
I could not remember to hear anything from a E Car when the are driving so its maybe not everywhere mandatory.
Made in Japan, destroyed in Sulz im Wienerwald.
Offline NiHaoMike
    • Facebook Page
« Reply #27 on: September 19, 2020, 01:14:16 pm »
The "missing link" is some way to convert the 300V - 400V main battery power directly to 115VAC, rather than going via the 12V system like I did, which is much more limited!
There are some fairly cheap inverter boards for that purpose. Just need to add a power tap with a properly rated DC breaker. Also note that switching supplies, including VFDs, will run from DC.
Offline radar_macgyver
« Reply #28 on: September 19, 2020, 01:40:26 pm »
My GM Bolt EV has this, and it quit working one day (also triggered the check engine light). Turned out rabbits had chewed the wires.
Sounds like an opportunity for a creative electronics project -  how about generating the sound of a Maserati Bi-Turbo?  :D
I think manufacturers missed a big opportunity by not making the sound customizable. I would have made it sound like the Jetson's car, or maybe even the Flintstones :)
The following users thanked this post: SilverSolder, The Soulman, george.b
Offline Brumby
« Reply #29 on: September 20, 2020, 09:33:48 am »
That Jetson's car sound in the first 10 seconds would be a whole lot of fun!!
I'd just have to do that - but it would be selectable.  Not sure how it would go with our laws.
« Last Edit: September 20, 2020, 09:35:22 am by Brumby »
Offline SilverSolder
« Reply #30 on: September 20, 2020, 02:08:34 pm »
That is actually pretty cool, I never really considered how much stuff actually runs fine on DC.
The important thing for me is to run the fridge/freezers...   which I don't think will work off DC.
The question is, where to look for an affordable 300+VDC -->  120VAC inverter...
Offline NiHaoMike
    • Facebook Page
« Reply #31 on: September 20, 2020, 03:15:17 pm »
Here's one example of a cheap HVDC to AC sine wave inverter:
https://smile.amazon.com/Ccylez-Converter-Post-Stage-Correction-Workmanship/dp/B08BRYQC8B/
Some tweaking will be needed to adjust down the output voltage.
Or you might be able to find a VFD for cheap.
« Reply #32 on: September 20, 2020, 04:05:47 pm »
Looks interesting!
The specs are a little confusing:
Pure Sinus Inverter Power Board Input voltage: DC380V.
Input voltage: AC16V.
Output voltage: AC220V.
What does it actually do -  DC380 to AC220?
Offline xmetal
« Reply #33 on: September 20, 2020, 05:59:24 pm »
We used to use a peg and a piece of card on our bikes when I was a lad! ;)
The following users thanked this post: Ed.Kloonk
Offline maginnovision
« Reply #34 on: September 20, 2020, 06:23:34 pm »
There you go, with those fan wheels you could add some whistlers, duck calls, small didgeridoo(maybe).
Offline coppice
« Reply #35 on: September 20, 2020, 06:23:59 pm »
It isn't so much about using the battery, as it is about using the ICE/generator set in the car -  in other words, you let the car sit there and cycle the engine and provide power to the house, like a generator on wheels...
I did that during the last outage, but with a hybrid car (not a plug-in).  It just stood there, cycling the engine, as the power was consumed.  It did that for several days in a row with no ill effects.  The battery level was maintained within about a 20% window so not worse than actually driving the car in terms of wear.
The reason for choosing PHEV rather than Hybrid for this, is simply to get longer cycles between the recharges, and of course the normal benefits of a PHEV when it is being used as a normal car.
Quite a few cars now have a 115V/230V AC socket that can put out 150W or so, for note book charging on the go. However, the new Honda E electric car has a 115V/230V AC socket that can put out 1500W. Its not clear why they have made it so high output, but its enough to run fairly substantial appliances. A couple of YouTube videos reviewing the car include the reviewer taking a microwave oven with them to cook their lunch while on location.
  • Country: at
« Reply #36 on: September 20, 2020, 07:06:31 pm »
Maybe for a Death Ray Laser?
Or when you want to Upgrade your Car:
Offline NiHaoMike
    • Facebook Page
« Reply #37 on: September 20, 2020, 09:13:37 pm »
The 16V AC input is an auxiliary for powering the logic and gate drivers. Probably would work with DC as well, although it would have to be isolated.
It accepts DC at 380V and outputs sine wave AC at 220V. Most likely the voltage can be tweaked down by changing some resistor values to change the duty cycle.
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #38 on: September 20, 2020, 10:11:04 pm »
Depends on regs in your country. In the EU it became mandatory for cars type-approved around last July, so the switch is no longer there as it can't be turned off.
It typically operates from 0-20mph in drive mode. Pretty sure yours will have one - just open the window and put it in drive - you should hear it easily enough
« Last Edit: September 20, 2020, 10:13:07 pm by mikeselectricstuff »
Day Job: Mostly LEDs
Offline Ed.Kloonk
  • Cat video aficionado
« Reply #39 on: September 20, 2020, 10:22:48 pm »
Looks like my car does not have the VESS simulated engine noise sound system. Manual shows a button for it which my care doesn't have.
Fun times with the spokes.
I know you're old timer, but I hope you're not miss remembering the red flag rule applied when these new fangled horseless carriages first showed up on the scene.
 :P
https://en.wikipedia.org/wiki/Red_flag_traffic_laws
iratus parum formica
Offline Kalvin
  • Embedded SW/HW.
« Reply #40 on: September 20, 2020, 11:24:35 pm »
In the spirit of DIY, you could probably use this one as a starting point for the missing engine sound:
Anyway, you get the idea :)
The following users thanked this post: Ed.Kloonk, SilverSolder
« Reply #41 on: September 21, 2020, 01:41:51 pm »
Interesting, that is a serious amount of power - and more than enough to get by in "survival mode".  Unfortunately, it is missing an ICE to keep the battery topped up!  :D
Here is what I'm using today - I bought a used one, I think they are installed on American utility trucks.  This guy will start and run the fridge/freezer.   The problem with it, is that it is capable of using almost 150 amps from the 12V circuit, which is too much for most cars...  I monitor it and keep the current below 80A which seems to not overpower the car's generating capabilities.
« Last Edit: September 21, 2020, 01:45:32 pm by SilverSolder »
Offline bsdphk
« Reply #42 on: September 21, 2020, 05:22:28 pm »
I have always felt that precisely this is evidence that Elon Musk is devoid of any sense of humour.
If I had designed the Roadster, the driver would be able to select the exterior sound on the fly, and amongst the factory installed choices would be "Citroën 2CV", "Wartburg", "Lawmower", "Tractor", "1-cylinder Fishing boat" etc.
  • Country: at
« Reply #43 on: September 21, 2020, 05:56:17 pm »
 ;D How about a Tank sound for the Tesla Truck?  :-DD
« Reply #44 on: September 21, 2020, 06:00:36 pm »
This engine shows how far we've come...   Our ancestors obviously didn't believe in high RPMs!  -  the shaking camera footage out on the water totally captures the experience of one of these boats.
The sound is nothing short of TOTAL awesomeness!  :D
  • Country: at
« Reply #45 on: September 21, 2020, 06:06:03 pm »
The are often operate multiple time during the Day.
Offline Poe
« Reply #46 on: September 23, 2020, 02:18:02 pm »
The Nissan Leaf sold in Australia appears to be made in Japan and the Hyundai in Korea.  MSRP in Japan for 2020 S model starts at $32k.  Wonder why so expensive in Australia, before taxes.  Shipping can't be that much for a place so close.
Does the Nissan actually get worse Km per Wh? Some car manufacturers report the total battery capacity.  Some manufacturers report usable capacity.  That is to say, if Nissan is reporting total capacity, but only using <88% of the battery to get the 150mile range numbers, it might actually get the same or more miles per Watt.  Many of the better manufacturers limit the total usable capacity of the battery to increase lifespan.... or just put in an adequately massive battery so you're rarely ever using most of it (Model S).
« Reply #47 on: September 23, 2020, 03:06:03 pm »
Import duties on what is regarded as a luxury vehicle no doubt, based on the mass block it occupies and power output. Only incentive to buy one is that electric power is not levied for road taxes when used for EV use, so the fuel cost is artificially low, but that will change when governments figure out how lucrative it can be milking the tax payer by keeping the duty just below the cost of fuel, and simultaneously increasing duty on fuel for road use even higher, once there is a large enough base of EV's that it starts to eat into fuel levy revenues.
« Reply #48 on: September 23, 2020, 03:28:16 pm »
They will find a way to dye electricity,  so cheap electricity sold for heating cannot be used in an EV!   Are those red electrons I see in your battery, Sir?   :D
The following users thanked this post: SeanB, Andrew McNamara
Offline EEVblogTopic starter
« Reply #49 on: September 24, 2020, 12:54:23 am »
No, the LEAF is well under the luxury car tax threshold.
