Author Topic: EEVblog #1362 - A Very Skookum Mailbag  (Read 6186 times)
Online EEVblogTopic starter
« on: January 03, 2021, 10:28:57 pm »
First Mailbag of 2021 is a skookum bumper!
Spoilers:
00:00 - AvE's 5lb Copper Widlarizer!
https://www.youtube.com/user/arduinoversusevil
Making of the hammer:
Final packing of hammer:
05:05 - Avionics Guest Lab from Gary Bertram
10:01 -  Koki'o Project Cases: https://www.crowdsupply.com/cowfish-studios/kokio-project-case
12:50 - 1960's Chinese Analog VOM! + modern replica still made today.
19:35 - Dodgy looking chinese face thingo
20:11 - Russian Voron-3 night vision viewer
23:58 - Greener EM3081 pocket multimeter
25:10 - PCBite handsfree osilloscope probe!
https://kandaelectronics.com.au/search?type=product&options%5Bprefix%5D=last&q=pcbite
https://sensepeek.com/
44:39 - Astro photography
47:54 - Russian Amateur Radio Magazines
49:31 - Giant Russian TV schematic
50:29 - 10GHz circular polarised antenna + RF Preamp
https://olegkutkov.me
https://twitter.com/olegkutkov
55:04 - More vintage russian stuff! Geiger counter, calculator, and alarm clock.
Offline Tek_TDS220
Re: EEVblog #1362 - A Very Skookum Mailbag
« Reply #1 on: January 04, 2021, 01:14:49 am »
Tektronix TDS220 scope!!!  You can tell the avionics guy is serious.
The circuit in the cast aluminium box on the 10.7 GHz antenna may be a downconverter.  Most of it is a local oscillator and a mixer.
« Last Edit: January 04, 2021, 01:52:47 am by Tek_TDS220 »
The following users thanked this post: EEVblog
Offline wilfred
« Reply #2 on: January 04, 2021, 02:50:56 am »
Can someone point me to the poll where Dave polled viewers about whether he should keep the TV behind him. He said to his surprise the majority voted to keep the TV.
I tried searching for it but couldn't find it. I am surprised too. Even with the "DaveHead logo" poll recently 50% said not to put up the sign. And that 50% was only 22 of 44 viewers.
I'm in the majority that don't bother voting in internet polls and I don't like distracting backgrounds. A distracting background being one that needs to be spoken about. An accumulation of stuff on the shelves is not distracting because no-one remarks on it.
Just had a thought the poll might have been on Twitter which is something I rarely look at.
Offline tocsa120ls
  • Country: hu
  • Electronic hobbyist living in Stuttgart
« Reply #3 on: January 04, 2021, 09:32:02 am »
Probably good that that GM counter didn't show anything, if I understand the switch labeling correctly the upper limit is 200 REMs  :bullshit:
Short circuit - long fire
« Reply #4 on: January 04, 2021, 10:48:09 am »
https://www.youtube.com/post/Ugx9W9DRVZ1Eab_A4lB4AaABCQ
Offline David Hess
  • DavidH
« Reply #5 on: January 04, 2021, 11:27:08 am »
I wondered where those copper Widlarizers would show up.  I look forward to a video from that crazy Canadian showing what you send him in return.
Offline highlanderIII
  • Country: in
« Reply #6 on: January 04, 2021, 04:04:14 pm »
G'day Dave!
The high-res photo and talking head is obviously far better for commentary. You could do that and then leave the image up on the TV for the rest of mailbag. I don't know if that will end up as more work for nothing. :-\
Thanks!
Back from haitus
Offline Dave
  • Country: si
  • I like to measure things.
« Reply #7 on: January 05, 2021, 08:04:42 pm »
The word 'Cyrillic' is pronounced like see-reel-ick, not cree-lick. ;)
<fellbuendel> it's arduino, you're not supposed to know anything about what you're doing
<fellbuendel> if you knew, you wouldn't be using it
Offline jceev
« Reply #8 on: January 10, 2021, 11:34:22 pm »
Anyone have info on the screwdriver kit at 44:00?  I couldn't see any markings on it.
Offline scopeman
« Reply #9 on: April 04, 2021, 01:10:27 am »
Hi Dave,
The probes are really cool. If you have some copper tape with adhesive on one side and tape a piece on top of the chip and then solder a short wire to the copper tape and solder that to a ground pin on the chip. You then solder a short ground wire to the probe ground to the copper tape and then you will have a very good ground for the scope and excellent signal fidelity!
Sam
W3OHM
W3OHM
