Author Topic: EEVblog #1345 - HP DV7 Laptop Repair  (Read 3660 times)
Online EEVblog
« on: November 03, 2020, 10:59:07 pm »
Dave fixes a thermal issue with his old video editing laptop, a HP Pavilion dv7
Offline Howardlong
Re: EEVblog #1345 - HP DV7 Laptop Repair
« Reply #1 on: November 03, 2020, 11:59:37 pm »
I have a Sony Vaio Z2 i7-2620M & AMD HD 6700M laptop running in Windows 10.
I didn't have to do anything to get the drivers to work in Windows 10, but the original Windows 7 was upgraded to Windows 10 using a Vaio supplied image, surprising considering Sony has sold off its Vaio PC division some years earlier.
It was quite the bees knees in innovation back in the day, 1080p 13.1" screen, ultra light carbon fibre 1.17kg (2.27lbs), 8GB RAM & 512GB SSD (2x256GB in RAID 0). It was an ultrabook before ultrabooks were a thing.
The AMD HD 6700M graphics are inside a companion external Blu-ray slim drive caddy connected via Thunderbolt over optical (aka "Light Peak").
[attachimg=1]
Online Brumby
« Reply #2 on: November 04, 2020, 04:16:49 am »
I was given a laptop to look at for an overheating issue once...
When I pulled it apart, I found a wad of dust that was as solid as a piece of felt completely blocking the path for the cooling fan air flow.
No surprise when I removed that wad that things ran cool again.
Something to keep an eye on, especially if you're in the habit of using your laptop while sitting up in bed.
Online BrianHG
« Reply #3 on: November 04, 2020, 04:50:11 pm »
I have the same laptop.  I have the HDMI out plugged into 1080p screens and the video mode shows up fine, both 1920x1080 and 1280x720 as soon as you select external monitor/projector mode, or separate modes on 2 screens.
  The video modes are restricted to lower resolution if you try to clone the external screen with the built in LCD.  You might even be able to get 1440p out, though I haven't tried this mode.
It also has no problem playing back 1080p or bluray images.  Only some newer revisions of Firefox have stutter when playing back 1080p @60hz with Intel graphics.  The ATI is better, but always makes Win7 crash randomly when enabled, so I never use the ATI.  This may be defective on my laptop as I can deliberately trigger graphics glitches when using TeamViewer as a client in full-screen mode when the ATI graphics is enabled.
« Last Edit: November 04, 2020, 04:51:51 pm by BrianHG »
__________
BrianHG.
Offline I.T. Manager
« Reply #4 on: November 05, 2020, 01:02:41 am »
With a 17" screen the DV7 is a big laptop and was often used a desktop replacement.
I have worked on a few HP DV7's with varying issues.
Overheating, as with Dave's  DV7 is common and all laptops can suffer from dust in vents and fans.
Usually, the first the technician hears about it is when the laptop continually shuts down, most times a clean fixes the problem, sometimes it is too late and overheated chips have failed.
Bad video memory was another DV7 fault (caused the screen to show random green pixels). Haven't worked on one for about five years so can't remember other faults I came across.
Note for Dave or anyone wanting to repair one:
The service manual was available online from HP, as I downloaded a copy. I can make it available, if it is possible to upload it here.
Once heard years ago "My 95 Windows are broken"
Offline Ashen
  • Country: ru
« Reply #5 on: November 06, 2020, 02:38:00 pm »
Well, there's a guide how to make a Windows 10 using AMD discrete graphics on this laptop.
Some tools/drivers are required^_^
UBR tool, to get valuable info from your machine, which is required to make every function to work properly. I've uploaded it here
DDU (Display Driver Uninstaller), to properly remove windows default drivers, can be downloaded from their official website: https://www.wagnardsoft.com/
And latest Leshcat Drivers for old AMD GPU's. Grab it from his repository
Additional note - download drivers which you might need before you start installation of Win10^_^
First step is to get back to Windows 7, install minimum set of drivers (to make sure that everything IS working properly). Original drivers have to be downloaded from official HP's website. Install, as i said, bare minimum of drivers - Intel's chipset, Media Engine, Intel's GPU and AMD's GPU, and "Nothing else matter".
After you installed everything i've said above, you have to run UBR tool. You'll see something like it:
Write down anywhere you feel comfortable two sets of data - {CurrentControlSet Intel} and {ControlSet001 Intel} In my case it's f840 for both, your machine might shown different values. These are required to make all graphics workng properly after Windows 10 installation (like sleep mode, brightness control, etc). Keep them in safe place in case if you have to reinstall Windows. They are working with Windows 7/8.1/10.
Second step is - install Windows 10. Be sure that your laptop IS in offline mode - no ethernet nor Wi-Fi connection is allowed! You can use Windows 7 x64 drivers for most of internal hardware. But install minimum set of drivers first - Intel's Chipset and Media Engine. Then you have to prepare your Leshcat drivers. Run it and you'll see a startup menu. Check in it's configuration window that you have marked all required stuff, like Intel and AMD's drivers and let it extract all required files.
Third step is to run DDU tool. When you launch it it will offer you to reboot in SAFE MODE. Do it. When in SAFE MODE DDU will restart istelf and you have to:
1) Remove AMD Drivers (without restart or quitting DDU!)
2) Remove Intel Drivers (with reboot, which is recommended).
After laptop reboots go to folder with previously extracted Leshcat drivers and run manually Intel's GPU drivers. There will be 2 folders, don't let them confuse you, you need the set for Windows 8.1/Windows 10. After installation it might ask you to reboot, it's okay to do that. BUT BEWARE! You have to configure Intel drivers before proceeding further^_^
Run UBR tool again. There you have to press {J} button and tool will ask you to manually input configuration data (f840 for my machine, possibly different data for yours!) twice - {CurrentControlSet Intel} and {ControlSet001 Intel}. It can be identical values for both or different for each other. Then tool will ask you to reboot to apply these values.
After reboot your system have to work properly in normal mode, after you put it in a sleep mode and wake up.
Fourth step is to install AMD's drivers. Back again to folder with extracted drivers, run SETUP and follow instruction. It already configured, so just run it and proceed with it till the end. Can't remember if it will or not ask you to reboot, but do it anyway, just to be sure that everything installed properly.
Technically, if everything went fine and all internal hardware is perfectly working, you've done hardest part of the job and now you can use AMD discrete graphics on Windows 10.
Just install all required drivers for other hardware and you can safely get it online to update Windows.
Be aware - depending on installed cardreader in your laptop (Realtek definitely won't!) it might or might not be working with Windows 7 drivers. In that case let me know, i'll upload for you the drivers which i use on my DV7 with Win10.
P.S. - as i said on your youtube channel, you can upgrade laptop's CPU to a better one. But check Service & maintenance guide first. You can check for it on official HP's website. My DV7-6152er has Core i5 2410M installed. After some soldering (i've soldered in parts for third PWM phase of CPU power supply and now is able to use quad core cpu's) and i'm using i7-2820QM which is wa-a-a-ay better^_^
By the way, i also tried i7-2630QM and it sucks. It's just a bit better than i5-2410 i had before.
One more thing - this motherboard can be upgraded for 2GBytes of GDDR5 VRAM.
Offline barycentric
« Reply #6 on: November 14, 2020, 10:46:26 am »
Had to bake my old 2006-era DV7 motherboard one time after it wouldn't POST. Worked fine for another eight years, outlasted several sets of batteries and chargers, and I just sold it (working)) on eBay this summer. The poor guy spent a whopping $75 for it! Remarkable computers.
