EEVblog => EEVblog Specific => Topic started by: EEVblog on January 10, 2021, 09:51:25 pm
Dave repairs the Compaq Portable Plus power supply.
And takes a look at the schematic and an unusual old documentation system.
https://www.youtube.com/watch?v=M6PVarUSjqg (https://www.youtube.com/watch?v=M6PVarUSjqg)
As of five hours ago, this blog post was made, during which the new BM786 multimeter was featured; Dave also noted that he had fresh stock of this multimeter in the store.
Sadly, when you go to the store, the meter is now shown as being "out of stock."
That sure didn't take long.
When you power it on, watch the CRT for the animated Compaq Logo. It was "the talk of the town" at the time. Nothing like it existed then.
About Christmas 1984 I got a brand new, dual floppy Compaq portable. A few months later they released the Plus model that included a "giant" 10 MB hard drive. I got the parts to upgrade mine to have the hard drive. Within a short time the power supply cratered. I looked it over and found it to be the strange mess yours is. I bought a replacement from Compaq (they were in Houston then, as I was) and it too died within a week. That caused me to call Compaq and plead until I got through to a Technical Engineer and asked for a schematic so I could repair the very expensive PSU. He sheepishly admitted to me that their original design was not robust enough for the hard drive upgrade that they sold me and said he would send me a replacement (next version?), but couldn't share the schematic. I was totally shocked when the package arrived and contained 3 new PSUs. I guess he didn't trust them either, ha ha. A few years ago I came across the two old New In Box PSUs in my barn. The sad part is they are not the oldest electronics stuff I have in there. ;D
About Sam's Photofacts -- they were an absolute necessity when TV & Radio repair was still a thing. Every repair shop had 5 or more four drawer file cabinets full of them. They were bought by annual subscription and it was priced so only companies could afford them. They started in 1946 and ran up to about 1991. However ITT bought them out in 1967. There was no Google or internet to get the data from, so you HAD to have the hard copy. Remember that even the plain paper copier was not introduced until 1963. I was always suspicious that Sam's Photofact saw that as writing on the wall and that is why they sold out within the next 4 years.
The pictures and annotations were to be used like a map to help you link the schematic to the board you had in front of you. Most of the folders also included alignment and calibration procedures, dial string diagrams for radios, model variants and what was different between them, etc. The original ITT Sams division went through a bunch of sales and splits after 1985 and I suspect that the current "owners of the corpse", Simon & Schuster, might still try to have some copyright claim. But most antique radio and TV enthusiasts are generally comfortable with any of the folders published before the the ITT buy out.
I love the vintage equipment repair, especially test equipment. A buddy of mine once commented that my lab was half cutting edge and half like a time warp to a 1987 research lab. ;D But really, some of that equipment is still very useful if you understand how it works and how to use it. Nearly all of my test equipment is older items I bought and repaired. Thank again for all your time and effort creating this "watering hole" for us!
Dave, sorry to argue, but you're in error about the 5V rail regulation mechanism. The 5.6V Zener that you mentioned as part of the regulation (CR26) is actually a sacrificial crowbar, i.e. if the 5V line rises due to a malfunction of other circuitry above 5.6V, CR26 clamps the voltage and converts it into heat until it fails by shorting out the rail or the other protection mechanism (via photocoupler U1) kicks in (whichever comes first...). These 5.6V (or rather probably 6V) overvoltage will be tolerated by the digitial circuitry from the 1980s momentarily without damage.
The 5V regulation is arranged by modulating the primary of the PSU via U9, referenced by the TL431 just below, and then Q2 driving the photocoupler U2.
Since the coupling of the transformer windings is not close enough for a direct regulation of several outputs (like it's done today on the cheaper low power SMPS's), the lower current lines are stabilized with linear post-regulators.
Hope this clarifies the control scheme for those who are interested in the details. Anyway, thanks for this very nice "retro" repair clip :D
Cheers,
Thomas
Hah, 'old format' opto-couplers, they're still available from Mouser.
OPI1264
Brought back memories, I must have repaired dozens of those, they were rarely as simple a fix as that :)
I think I've still got a bag of LM338K chips too...
Sam's is way older than 1958, it predates transistors. They would have huge volumes by year of all consumer electronics (dating back to AFAIK the 20s) service manuals. If you watch many vintage electronics restoration channels they often mention "The Sams", even if they are just referring to the schematic or service manual outside of the actual Sams guide (as Sams usually had it anyway).
I am surprised that the Compaq power supply didn't self destruct when it was first switched on after all those years !
I repaired many computer SMPS, it was always a dried or shorted capacitor that took out the power transistor and / or other components, NEVER a loose wire, even though that was what the customer suggested it probably was.
Repaired one Antec 450W (Greenpower ?) power supply that faulty (bloated) caps on the +12 rail that were dragging it down to around 10v causing the computer behave a bit erratic.
The poor power supply was struggling to work with a massive load on the +12V rail !, no magic smoke, no other damaged components !.
It had been running in a file server 24/7 for over 10 years without missing a beat !.
I replaced the offending caps with Panasonics and all was good.
Good one Antec !.
I've just been lucky enough to acquire a very clean original Compaq Portable for $129. Cosmetically very clean, and functionally promising. It will sometimes boot to the point of getting a 601 diskette error. CRT is bright when it boots, but keyboard was unresponsive after the diskette error.
Having just watched the 3 parts of this series, I was cautious of the PSU. So I got into it and measured the rails (measured with no load, just like in the video)
+5 = 5.10v
+12 = 12.45v
-5= -4.99v
-12 = -11.82v
These all seem good. This unit seems like it has been very lightly used, so I don't think it booked a lot of "on" hours.
Question: Thoughts on whether I should proactively re-cap the system before working on the functional issues. PSU only? Electrolytics only? or Tantalums as well? and the Tantalums on the motherboard/VDU/floppy? Or is this overkill?
Thanks for any input!
Greg
@gstarks: I'd start by reseating all socketed chips and connectors. That likely solves most of your problems. Replacing parts while this isn't necessary (parts have not been tested/identified to be broken) usually breaks more than it fixed. Especially when done by people who need to ask >:D
Haha! Careful what you assume! Learned my soldering skills 40 years ago, so I'm not concerned about accomplishing the task at hand. Just happens my projects
have always been on new (or fairly new) kit, so intimate knowledge of aging faults in capacitors is an area that escapes me.
I've seen other sites where people swear by re-capping 100% of the time, but thought I'd post here for maybe a bit more insightful engineering opinion.
I only just recently started getting some retro kit. So far an Apple II, Leading Edge Model D, and now this Compaq. Leading Edge had some battery leakage damage to repair, but haven't seen any caps on any of the systems that seem in bad shape visually. Not sure if the re-capping thing is mostly hype, or sound advice and want to make sure that if I do it, I go ahead and do the types of caps that need it and not leave any out or do a bunch unnecessarily.
As I mentioned, the system boots most of the time after it's been off a while, but will sometimes not boot (no video, nothing but fan - which I think runs off the primary), if it's a quicker power-cycle (like off for 30 seconds or less). I've just noticed that when it does this, the 5v rail is 0v, so looks like I may end up with a PSU issue anyway.
Also the keyboard mystery is resolved... none of the foam pads are conductive anymore, and the foam is rotten. Apparently common issue with this system. I've ordered replacement pads but the underlying keyboard electronics are working.
I've also successfully booted from one of the floppy drives. the one that was connected as drive A throws the error, but the controller and the second floppy are good.
Overall, it's in pretty good shape :)
Agree that recapping for the sake of it is usually unnecessary but the tantalums on those boards, they were a common cause of failure when those machines were on the market and they're now 35ish years old
One of the tantalums on the PSU gave a colleague a scar on one of his fingers which was still visible 30 years later, the PSU was whistling and he worked out that squeezing the cap changed the pitch, when he demonstrated, it exploded between his fingers...
I tend to recap when I've had a cap fail, rationale is that they're all the same age and thus, unless there's some provable or obvious reason for a failure (low value cap sat right next to high power resistor or other heat source) then they're likely all close to failing and as they're usually dirt cheap, cheaper than the time taken to desolder, test and replace, it makes sense for reliability to do the lot.
I recently got one of these and retro fitted a multi voltage board from an AT power supply. There is enough room for it to fit along with the cooling fan.
The monitor runs off 12v DC and so there is no issue with the mains frequency.
I have a video of mine here, which shows the voltage rails required:
https://youtu.be/GRLDEQ13884 (https://youtu.be/GRLDEQ13884)
Ant.
I have a compaq portable power supply that needs repair.. maybe two of them.
