Author Topic: EEVblog 1384 - Halve Your Processor Power Consumption!  (Read 3392 times)
Online EEVblog
« on: March 31, 2021, 10:02:19 am »
Halve Your Processor Power Consumption using Diffusion Capacitance!
Dave demonstrates a neat but tricky technique to PWM a processor's power pin to reduce power consumption.
https://en.wikipedia.org/wiki/Diffusion_capacitance
MIT: http://web.mit.edu/6.012/www/SP07-L16.pdf
Colorado University: http://ecee.colorado.edu/~bart/ecen3320/f99/pdf/ch4_4_5.pdf
Power a micro with no power pins!
Offline TrickyNekro
  • Country: gr
  • Drinking Frappé on the way to Isomnia!
    • Youtube channel, electronics and more ;-)
Re: EEVblog 1384 - Halve Your Processor Power Consumption!
« Reply #1 on: March 31, 2021, 10:23:02 am »
I seriously do not buy it until I try it. Chips usually have some bulk capacitance inside on the power rails but that´s just ridiculous... And the switching frequency is quite low.
And you are driving a whole LCD bus let alone the processor itself. Edit: Which as stated below could be powering the processor.
And it´s April first coming fast to Aussieland so... no... Something is up... It can´t be that nobody ever tried that before, I have been on the internets for a while...
No no no no no... I saw quite well how good your acting was on the Keysight video... no no no no...
Edit: Actually reading a character from the LCD and then going to sleep plus the PWM BS, could also explain the low PWM frequency... really good call from the guy below!
« Last Edit: March 31, 2021, 11:27:03 am by TrickyNekro »
If you are an engineer and you are not tired...
You are doing it wrong!
Offline graybeard
  • Senior III-V RF/mixed signal/device engineer
    • Chris Grossman
« Reply #2 on: March 31, 2021, 10:25:29 am »
It is not diffusion capacitance.  Diffusion capacitance is due to minority carrier storage of forward biased junctions.  You are using the the reverse biased substrate junction capacitors.  They are never forward biased.
You are lowering the current since the PWM is lowering the average voltage the microcontroller sees.  The internal voltage will have a sawtooth edge.
« Last Edit: March 31, 2021, 11:04:49 am by graybeard »
Offline chekhov
  • Country: by
« Reply #3 on: March 31, 2021, 11:13:08 am »
So in this example processor is actually takes it's power from SPI/whatever lines from display board if I understand the joke right? :)
Offline TrickyNekro
  • Country: gr
« Reply #4 on: March 31, 2021, 11:23:13 am »
Good call! But that really depends on the LCD driver, you got to get the LCD in write mode for that to happen! Which of course it´s pretty reasonable!
Offline nctnico
« Reply #5 on: March 31, 2021, 12:06:32 pm »
Look what timezone Dave is in and what date it is in Australia..  >:D
The following users thanked this post: egonotto, highlanderIII
Offline golden_labels
« Reply #6 on: March 31, 2021, 12:27:59 pm »
Assuming that the internal capacitance would really allow that and ignoring all the problems associated: how would that differ from simply lowering supply voltage? ATmega328P has pretty linear dependency of current consumed and supply voltage. My bullshit sense is tingling.
Worth watching: Calling Bullshit — protect your friends and yourself from bullshit!
Offline TrickyNekro
  • Country: gr
« Reply #7 on: March 31, 2021, 12:52:41 pm »
I´ve seen many strange things in my life ok... enough to doubt what I know... and I know brown-out can be disabled in AVRs... But sure the Aussie is trying to pull a Roo on us...  :-DD :-DD
Offline Cnoob
« Reply #8 on: March 31, 2021, 12:53:55 pm »
Fascinating until I looked at the date.
Dave I think you do the best ones on you tube :-+
The following users thanked this post: SeanB, highlanderIII
Offline drussell
  • Hardcore Geek
« Reply #9 on: March 31, 2021, 01:01:30 pm »
He was like 3 hours early...  :)
Offline Anthocyanina
  • The Sara
« Reply #10 on: March 31, 2021, 02:20:45 pm »
This sounds just like capacitive deractance at work
The following users thanked this post: ludzinc
Offline woofy
    • Woofys Place
« Reply #11 on: March 31, 2021, 04:06:20 pm »
Its not just microcontrollers it works on.
I've been using this technique on my core i7 desktop, PWM'ing the power at 11.574 uHz
The following users thanked this post: ludzinc, Chris_Walch, highlanderIII
Offline tocsa120ls
  • Country: hu
  • Electronic hobbyist living in Stuttgart
« Reply #12 on: March 31, 2021, 04:07:12 pm »
To be honest, I liked MickMake's video better.
« Last Edit: March 31, 2021, 04:14:34 pm by tocsa120ls »
Short circuit - long fire
Offline woofy
    • Woofys Place
« Reply #13 on: March 31, 2021, 04:30:25 pm »
I used to subscribe, but Mick hasn't posted since a year ago, anyone know if he's ok?
Offline tocsa120ls
  • Country: hu
« Reply #14 on: March 31, 2021, 05:01:04 pm »
He's tweeting all right.
The following users thanked this post: woofy
Online SiliconWizard
« Reply #15 on: March 31, 2021, 05:51:59 pm »
That was a fun one.
Offline MK14
« Reply #16 on: March 31, 2021, 06:45:48 pm »
It can be done. Using the following device, you really can cut your electricity bills in half.
The following users thanked this post: nctnico, Kleinstein
Offline os40la
« Reply #17 on: April 01, 2021, 04:02:01 am »
I smelled something fishy as soon as I noticed his DaveCad of the CMOS Inverter looked a little bass ackwards.
Looked more like a buffer, eah?
Plus.. My calender was close by..
« Last Edit: April 01, 2021, 04:05:37 am by os40la »
"No, but I did stay at a Holiday Inn Express"
Online EEVblog
« Reply #18 on: April 01, 2021, 05:45:15 am »
No, I'm alway on time.
The following users thanked this post: highlanderIII
Offline garethw
« Reply #19 on: April 01, 2021, 05:54:08 am »
Oh Dave, you get me every year. Although I worked this one out before the end of the video. Good work!
Father
Husband
MENG Electronic Engineering student
Offline garethw
« Reply #20 on: April 01, 2021, 05:57:44 am »
What duty cycle?
Father
Husband
Offline Ranayna
« Reply #21 on: April 01, 2021, 07:50:35 am »
I have to admit: The Troll in the thumbnail was a dead giveaway. ;) But that might also be because i know those hideous things from when i was a child, they were all the rage back then.
But again i have to congratulate: You can get stuff like this across so professionally, that I can really believe them, being the layman that i am.
Offline woofy
    • Woofys Place
« Reply #22 on: April 01, 2021, 08:17:24 am »
What duty cycle?
30-40% on time.
« Reply #23 on: April 01, 2021, 01:10:21 pm »
<insert the sound of slow clapping here>
I smelled something is wrong, but haven’t realized it’s April’s Fools. Dave got me. Good job. :D
Offline srb1954
  • Retired Electronics Design Engineer
« Reply #24 on: April 01, 2021, 01:51:39 pm »
When I first saw the video I thought it was a joke as my calendar had already ticked over to April 1st. But I am in NZ and and we are 2 hours ahead of Australia so it would have still been 31st March in Australia when Dave released the video.
