Author Topic: EEVblog 1384 - Halve Your Processor Power Consumption!  (Read 9066 times)
Offline drussell
  • Hardcore Geek
Re: EEVblog 1384 - Halve Your Processor Power Consumption!
« Reply #25 on: April 01, 2021, 02:32:56 pm »
He was like 3 hours early...  :)
No, I'm alway on time.
What time zone are you in in Sydney?  Yesterday, Google said that 7am my time when I wrote that comment was 12am there, (today it is now 8:30am, April 1st here and Google says it is currently 1:30am in Sydney) and you has posted this topic at 4:02 my time, which was three hours prior.
Is Google's "Sydney Time" wrong or are you somewhere else?
Online MK14
« Reply #26 on: April 01, 2021, 02:47:24 pm »
Halve Your Processor Power Consumption using Diffusion Capacitance!
Dave demonstrates a neat but tricky technique to PWM a processor's power pin to reduce power consumption.
Yes, that or a similar technique is/was used in an early Clive Sinclair Calculator. It might be before your time and/or too British (i.e. It may not have reached Australia ?), for you to know about it.
http://www.vintagecalculators.com/html/sinclair_-_the_pocket_calculator.html
Clive Sinclair is an electronics genius and is noted for his miniature electronic products achieved by using very innovative designs.  The first Sinclair Executive calculators used one of the standard calculator chips of the time, the Texas Instruments TMS1802.  This normally has a current consumption of about 300 mA which dictates that normal AA size batteries, or larger, need to be used to give a decent battery life.
Sinclair in his quest for miniaturisation, to produce a true pocket calculator, wanted to use button cells rather than normal batteries, but these would be drained in minutes by the chip and the LED display.  However, Chris Curry and Jim Westwood at Sinclair Radionics, in Huntingdon, England, found that the power to the chip did not have to be on continuously, it could be pulsed and the internal capacitance of the chip would store enough electrical charge to keep it working till the next power pulse.  Power pulses lasting 1.7 microseconds are used, at a frequency of 200 KHz during calculations and 15KHz between each operation, reducing the power consumption to 25 to 30 mW.  Texas Instruments did not recommend operating in this way, but it allows the Executive to get about 20 hours continuous operation from 3 small mercury button cells.
Another link:
https://www.i-programmer.info/history/people/370-clive-sinclair.html?start=1
It used a standard chip with a, typical Sinclair, power saving trick of pulsing the power supply.
N.B. The links are NOT April 1st jokes!
« Last Edit: April 01, 2021, 02:49:03 pm by MK14 »
Online David Hess
  • DavidH
« Reply #27 on: April 01, 2021, 02:58:38 pm »
Since I watched this on the last day of March, I am glad it is revealed so that I do not have to explain what was really going on.  The oscilloscope showing the gate drive waveform explained all, as I have seen that before.
Offline golden_labels
« Reply #28 on: April 01, 2021, 08:08:15 pm »
Is the 328P actually running with just 1.25V (25% duty cycle of 5V) at 16 Mhz or this part of the fake?
I can’t tell if it’s fake or not, but the supply voltage wouldn’t be 1.25V.
This is not PWM smoothed out by a low-pass filter: there is no “pull down” phase. The supply cycles between high and HiZ, not high and low. That means any capacitance is instantly charged to Vcc during the on phase, but is later slowly discharged only by the current consumed by the controlled itself. The voltage is determined by power consumption of the controller and timing, not directly by the duty cycle.
People imagine AI as T1000. What we got so far is glorified T9.
Offline Kleinstein
« Reply #29 on: April 01, 2021, 08:42:49 pm »
The slowly falling supply voltage because of the "diffusion" capacitance is what Dave tells. The main part of the power is likely comming from the LCD interface, powering the µC with some 4 V or so.
The the voltage switches between some 5 V and some 4 V both a fine, though the fast transients may cause glitches. Similar powering via a supply pin can work but is still outside the specs and it can also cause funny behaviour, especiall with pins close by.
The odd point is not so much why the µC still runs with the PWM active, but why it fails with a lower PWM setting.
Offline julian1
« Reply #30 on: April 01, 2021, 09:13:10 pm »
Pwm in Davecad is an N-channel fet. So DIO must be > 5V to turn on. But DIO is powered by the mcu itself, so I can't see how it ever switches on.
Do I read that wrong?
Offline tszaboo
« Reply #31 on: April 01, 2021, 11:10:10 pm »
I'm somewhat disappointed, that the new turboencabulator wasn't used in this test setup.
The following users thanked this post: MK14
Online David Hess
  • DavidH
« Reply #32 on: April 01, 2021, 11:40:01 pm »
I am disappointed that Dave's old turboencabulator was not used.
Online MK14
« Reply #33 on: April 01, 2021, 11:41:25 pm »
It was. It was secretly hidden under the bench, and was able to power the Arduino, via its flux-capacitor ultra-field rays.
Offline schmitt trigger
  • Country: mx
« Reply #34 on: April 02, 2021, 12:12:38 am »
Easy;
It is the hook up cable’s negative resistance. The load-side voltage becomes larger than the supply side.
Think of it as a wire with gain.
Offline mindcrime
« Reply #35 on: April 02, 2021, 05:20:43 pm »
 :blah: :bullshit: :blah:
I'll believe this load of bollocks when I see the power measurements done on a high-quality (eg, "Made in USA"), quantum-entangled, reverse neutron polarity, sub-fractional cardinal-grammeter.  :-DMM
Offline free_electron
    • SiliconValleyGarage
« Reply #36 on: April 03, 2021, 10:42:05 pm »
that's why we (the semiconductor farmers) have been using fully depleted silicon substrates for at least he last decade. SOI (Silicon on insulator) does away with Csb and Cdb so the floating node can switch much faster.
You can also make structures denser ( not smaller. this i has to do with the distances between diffusions , not the size of the diffusion . size is current. distance is voltage. )
All those processors running your smartphones are built using fully depleted silicon.
of course your average arduino is not built using that technology. that barely left the vacuum tube age.
http://csit-sun.pub.ro/courses/vlsi/Carte_VLSI/bookch15.pdf
Online David Hess
  • DavidH
« Reply #37 on: April 04, 2021, 03:05:31 am »
I suspect SOI is limited to higher margin products which can afford it.  Microcontrollers also require floating gate memory which is only available on processes with a much larger feature size; I think they have only just reached 28 nanometers.
Online EEVblogTopic starter
« Reply #38 on: April 08, 2021, 06:05:57 am »
I care about my audience everywhere around the world.
« Reply #39 on: April 08, 2021, 06:08:26 am »
Nope, I goofed.
I realised this before I shot and drew it again, then dumb arse me used the old sheet in the video instead of the new correct one  :palm:
Offline julian1
« Reply #40 on: April 08, 2021, 08:14:00 am »
Ahh, the intent was clear, but since this was posted as a (semi) riddle I wasn't sure that it might not be a clue.
I wonder, given stray cable inductance/ or from a choke somewhere + blocking diode + fet, it resembles a simple switching converter.
And extra capacitance from the LCD board decoupling would help to store energy.
« Reply #41 on: April 09, 2021, 12:36:17 am »
I did notice it during editing but then realised it would be fun to leave it in rather than reshoot, so  ;D
Offline JustMeHere
« Reply #42 on: April 09, 2021, 12:45:58 am »
Do you have to disable brownout detection to get this to work?
Offline VK3DRB
« Reply #43 on: April 23, 2021, 08:35:13 am »
Interesting phenomenon. Certainly not recommended for anything serious.
Most MPU's at least have plenty of different power modes which should be managed as required.
I worked in the electronics team designing Zoleo (www.zoleo.com). The device talks to the Iridium satellite network, GPS satellites, a mobile phone, and a host of internal I/O devices. From a small single cell 3.7V battery this baby will typically operate for an impressive 200 hours between charges. One task I had was the power consumption calculations during the design, and it was not easy by any means. Every chip, pullup/pulldown resistor was analysed prior to the schematic being locked down. And within the MPU, the power consumption with different power modes under firmware control was critical to keeping current drain minimal. With most products no one cares much about a few milliamps here or there, but this application was critical because as Zoleo is used by trekkers, often in the middle of nowhere. This product is now a world beater which is a credit to all on the R & D team. A very satisfying result and a terrific product even if I say so myself.
Most small CPU's these days consume very little power and can often be left in sleep mode until an external interrupt, from, say a MEMS device springs it into action. Using PWM to reduce power consumption on a micro in this day and age for a commercial product is nonsense. Many products do not have anywhere the level of power consumption analysis done that we did for Zoleo. The importance of this of course depends largely on the application requirements.
