Author Topic: EEVblog 1388 - Dumpster Diving TV Murphy's "Repair"  (Read 2722 times)
Offline EEVblog
« on: April 23, 2021, 10:43:21 pm »
Dave fixed this Hitachi dumpster diving 4K TV so well that he broke it!
Offline fable
  • Country: cs
Re: EEVblog 1388 - Dumpster Diving TV Murphy's "Repair"
« Reply #1 on: April 24, 2021, 01:03:49 am »
Here is schematic
The following users thanked this post: EEVblog
Offline eblc1388
« Reply #2 on: April 24, 2021, 07:13:18 am »
Should have used a wired 5A fuse for replacement. PFC switching MOSFET draws high instantaneous current through the inductor following the AC wave profile. This might have caused the PTC resettable fuse to go into higher than normal resistance, and PFC controller IC doesn't like it a bit.
Online BrianHG
« Reply #3 on: April 24, 2021, 06:53:06 pm »
Ohh, the modern version of when in the old days, I would have a good working CRT, with an intermittent problem which occasionally required me to whack the display to fix.  I open it up, find a few cold solder joints.  I re-solder cleaning them up.  The display works for a day, then literally blows up the next time I power-on.
I was told by an experienced repair tech that some of TVs become dependent on the cold/poor contact solder joint and doing repairs may destroy the display.
__________
BrianHG.
Offline ivb
« Reply #4 on: April 25, 2021, 03:35:15 am »
I'm reminded of a similar problem my family had when I was growing up. Something went goofy in the tuner section of our CRT TV where it would just suddenly go out of tune despite being "digitally" tuned. My dad being a machinist and definitely not an EE or even electrician decided the best remedy was to drill a hole in the case directly above the RF shielded tuner and use a brass rod inserted to regularly hit the RF shield it until it came back in tune. We called it the "bonger" as in "get the bonger the TV's gone out again". Oddly enough no one ever managed to electrocute themselves despite what I now realize were our best efforts :palm:.
Offline David Hess
  • DavidH
« Reply #5 on: April 25, 2021, 08:52:57 pm »
I am surprised that the PFC controller IC was not damaged.  In my experience when the power transistor fails, usually high voltage gets applied to the gate or base destroying the drive circuits as well.
The following users thanked this post: Towger
Offline dcac
« Reply #6 on: April 26, 2021, 05:59:29 am »
Yeah, everything can be shorted in a failed power transistor. Not just Emitter to Collector - but Emitter/Collector to Base too, or in this case Drain/Source to Gate. I don't know if Dave measured the Gate - I don't think he showed it in the video.
Still bit of a mystery why something else seems to have broken by just installing the new mosfet. If the PFC IC is damaged and its output failed open it shouldn't do anything at all - if it failed short as in sending a constant voltage to the mosfet - the mosfet and/or the fuse would blow again.
Offline EEVblog
« Reply #7 on: April 26, 2021, 11:09:26 pm »
Yes, that was my analysis too.
The gate was about 10ohms, so the chip might have been taken out.
Offline dcac
« Reply #8 on: April 27, 2021, 12:02:07 pm »
And likely then the ZD101 zener too as it sits directly between Gate and GND. If that zener is shorted it kinda rules out any involvement from the PFC IC together with the new mosfet causing the new fault.
Offline Robert Smith Eco Warrior
« Reply #9 on: May 05, 2021, 08:22:24 am »
I wasn't sure where to put this reply but since it was a dumpster dump find I thought I would put it in a dumpster dive thread...
I helped my mum move a wardrobe from a house that was being cleared. There was a skip outside full of alsorts of rubbish plus various old hifi (mostly low-fi crap) and these two little boxes.
I asked the guy there and he said take what I want. I thought these might fetch £10 on ebay or pull them to bits and add them to my scrap metal or just put something in the nice wooden boxes.
Bloody hell.... these things go for mega bucks on ebay  :o
Vitavox GP1 Pressure units...
Offline Pinkus
« Reply #10 on: May 05, 2021, 09:18:32 am »
Life is a give an take. Just thinking about how my future heirs will give away many of my valuables for less than they are worth or even throw them away, makes me feel sick already.
The following users thanked this post: Robert Smith Eco Warrior
« Reply #11 on: May 05, 2021, 09:23:03 am »
I think we should all make a equipment and tools list to tell relatives what all our 'junk' is  :)
Online Doctorandus_P
« Reply #12 on: May 05, 2021, 02:34:30 pm »
It may have nothing to do with the PFC at all.
It looks like you did a firmware update, then cycled power and it does not work anymore...
Offline Kaluluka
  • Country: vn
« Reply #13 on: June 26, 2021, 05:02:53 am »
Failed firmware update and no 5V STBY Power from this PS, relation explanation please?
