Author Topic: EEVblog 1410 - Mailbag  (Read 4424 times)
Online EEVblogTopic starter
« on: July 29, 2021, 10:10:56 pm »
SPOILERS:
00:00 - Dancom RT403B 25W VHF Marine Transceiver teardown.
09:07 - Workbench of the week, Tony Albus:
https://www.youtube.com/channel/UCwLPcv2xiA3D9lfGArF58ww
TEA: https://www.eevblog.com/forum/testgear/test-equipment-anonymous-(tea)-group-therapy-thread/
12:36 - Riedon SSA-100 100A Differential Isolated Current Sensor.
https://riedon.com/
https://www.digikey.com/en/products/detail/riedon/SSA-100/12149327
22:19 - DODGY! Soviet era mains rechargable torch
27:36 - Jon Newcomb's Microcontroller Proto Boards
https://www.ebay.com/usr/jon_newcomb
33:57 - Affable Snake Breadboard LED bargraph
https://www.tindie.com/products/affablesnake/slim-breadboard-indicator-green-8-position/
35:34 - Mystery $2 ebay item DESTROYED by Widlarizer!
37:47 - Present from a 13yo viewer
39:40 - Multimeter PicoProbes:
https://www.tindie.com/products/twires/picoprobes/
Offline Monkeh
Re: EEVblog 1410 - Mailbag
« Reply #1 on: July 29, 2021, 10:50:04 pm »
That case is what you get off a 3D printer which is working properly, rather than something like a Creality firing on three cylinders with a hole in the exhaust.
Offline MAS3
« Reply #2 on: July 29, 2021, 11:54:33 pm »
Hi.
The 1st item is a marine VHF, and the invoice / warranty forms are in Dutch, not Danish (like Australia not Austria).
The module is an Australian made (by Sigtec) ATIS module, which is sort of a 'roger beep' transmitting the station callsign through a FSK pulse train.
This ATIS became mandatory on inland waterways in 1995 or so.
This particular module also has a killer, which detects and suppresses this rather unpleasant FSK signal on the audio output of this radio (through the white wire to the audio amp).
« Last Edit: July 29, 2021, 11:57:46 pm by MAS3 »
The following users thanked this post: Andrew McNamara
Offline agtrbt
  • Country: tw
« Reply #3 on: July 30, 2021, 04:03:24 am »
The soviet mains charged torch has been copied into a one hung low Chinese shaver
certainly dangerous.
Offline ve1nhb
« Reply #4 on: September 17, 2021, 06:12:27 pm »
How did the 'FLASHLIGHT' charge the batteries work.  :-//
Nelson from the far eastern Island of Cape Breton.
Offline thm_w
  • Non-expert
« Reply #5 on: September 20, 2021, 08:37:06 pm »
