Author Topic: EEVblog 1507 - Mida: A surprisingly good quality cheap EVSE  (Read 3907 times)
Offline EEVblogTopic starter
« on: October 12, 2022, 11:08:09 pm »
Teardown of the cheapest EVSE available in Australia, the 15A Mida Type 2 portable electric car charger.
https://s.click.aliexpress.com/e/_DEYLWux
« Last Edit: October 12, 2022, 11:16:15 pm by EEVblog »
Offline rhodges
  • Available for embedded projects.
    • My public libraries, code samples, and projects for STM8.
Re: EEVblog 1507 - Mida: A surprisingly good quality cheap EVSE
« Reply #1 on: October 12, 2022, 11:58:59 pm »
For the brief image of the CPU, I think it was a STM32F030 with a lot of probably unneeded pins. I like STM32, but I think this could have been done with a cheaper STM8.
Currently developing STM8 and STM32. Past includes 6809, Z80, 8086, PIC, MIPS, PNX1302, and some 8748 and 6805. Check out my public code on github. https://github.com/unfrozen
Offline ssander
« Reply #2 on: October 13, 2022, 01:29:36 am »
If those eye terminal connectors for the mains are loose, are they able to touch each other?
Offline Circlotron
« Reply #3 on: October 13, 2022, 04:53:08 am »
Didn't watch the whole video.
What joins the input ground to the output ground?
If it is a PCB track rather than a solid wire, is that legal in Australia?
« Reply #4 on: October 13, 2022, 04:56:16 am »
PCB trace. It's approved and sold here. Don't know about the legalities of that.
Offline gamalot
  • Correct my English
    • Youtube
« Reply #5 on: October 13, 2022, 12:06:06 pm »
I see Chinese characters for "国网电瑞" on PCBs, it should be a subsidiary of China State Grid.
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #6 on: October 13, 2022, 06:52:38 pm »
I would be surprised to see any standard dictate whether a conductor is carried by wire or PCB trace - more likely that it would specify a current-carrying capacity & leave it up to the manufacturer how to achieve it.
Day Job: Mostly LEDs
Offline BrianHG
« Reply #7 on: October 13, 2022, 10:25:37 pm »
In this application, and even though I do use latching relays myself to save on system power, I think that they should have used normal relays which disconnect under loss of power.  The system did use a switching supply instead of a capacitor dropper, so it should have been a way to keep thermals of powering normal relays of that size under control in the sealed device.
I guess the other argument can be made if an MCU IO gets fried on or turned on by corrupted code, a connected relay would still immediately be turned on after connecting power.  Without the schematic, we cannot tell if there are any protections at the low level transistor relay driver level to prevent this which may actually be a plus if done right regardless of the MCU's state.
« Last Edit: October 13, 2022, 10:31:47 pm by BrianHG »
« Reply #8 on: October 14, 2022, 07:39:36 am »
In this case the relay coils are 1.5W each. That's a lot inside a sealed case like this.
Offline Wollvieh
« Reply #9 on: October 16, 2022, 01:43:19 am »
In Germany the earth wires would have to be longer than the others, so they rip out as last.
Offline VK3DRB
« Reply #10 on: November 16, 2022, 03:33:50 am »
The unit does not have the RCM mark on it. It cannot be sold be legally sold in Australia.
Offline KE5FX
    • KE5FX.COM
« Reply #11 on: November 16, 2022, 04:36:58 am »
They will have used what they could get.
