Author Topic: EEVblog 1520 - Troubleshooting a Faulty BM786 Multimeter  (Read 15978 times)
Online EEVblogTopic starter
« on: December 20, 2022, 06:17:23 am »
Looking at a faulty returned BM786 multimeter.
Warning: Some components were harmed in the making of this video.
Offline bob808
Re: EEVblog 1520 - Troubleshooting a Faulty BM786 Multimeter
« Reply #1 on: December 21, 2022, 02:06:25 am »
That might be a possible short from manufacturing. Seems to be under the pins.
edit: nah, looked again at other frames and seems like it is gunk that you scraped earlier.
also can the micro pull it's own rails high? shouldn't the on signal come from some other chip/circuit?
there was also another rail that was coming through an inductor, can't remember if you measured that. if the enable for the rail doesn't happen there might be other stuff that's not enabled.
« Last Edit: December 21, 2022, 02:29:31 am by bob808 »
Online joeqsmith
« Reply #2 on: December 21, 2022, 05:34:41 am »
Best two shots I saw of it.  Maybe damaged during the testing or maybe fine and just looks like the back was blown off.
Offer stands.  If you would like the Keysight for parts to repair yours I'll swap you.
Someone had posted a link to a better view of U2.   Looks fine.
« Last Edit: December 21, 2022, 01:38:08 pm by joeqsmith »
Offline bob808
« Reply #3 on: December 21, 2022, 11:53:57 am »
Had another look at the video and I don't see you measuring the other rail (photo 1).
Also the line (photo 2) that should latch those +/-1.65V rails might very well be RESET which is low. Even if you manually enable those +/-1.65V rails all micros might be in reset.
Those +/-1.65V rails seem like VACC for an ADC. So the other line might be the 3.3V digital for the chip. If that's missing, or RESET line is low, it might explain why you're getting nothing from the micro.
So RESET might be low because of a bad voltage supervisor chip / part of its circuit.
« Last Edit: December 21, 2022, 11:57:37 am by bob808 »
Online thm_w
  • Non-expert
« Reply #4 on: December 21, 2022, 09:22:45 pm »
In the youtube comments, Dave verifies multiple hacked/missing/etc components on this meter.
Either production quality really slipped here, or someone did try to mess with it.
This would be one benefit of having a tamper sticker, not a "warranty void" one though.
Offline bob808
« Reply #5 on: December 21, 2022, 09:44:57 pm »
I assumed it's a new unit because it had the plastic foil on the display.
Online SiliconWizard
« Reply #6 on: December 21, 2022, 10:10:58 pm »
If it got like this straight from production, this isn't pretty. I wouldn't expect something like this from Brymen. ::)
« Reply #7 on: December 21, 2022, 11:12:34 pm »
Yep, I cleaned it up and it's fine.
« Reply #8 on: December 21, 2022, 11:13:21 pm »
Yeah, very poor hand soldering.
Most likely replacing missing components from the PnP.
« Reply #9 on: December 21, 2022, 11:13:44 pm »
About 9 months old.
« Reply #10 on: December 21, 2022, 11:19:47 pm »
About 9 months old.
Oh you mean that it had worked for 9 months before failing?
« Reply #11 on: December 22, 2022, 04:08:49 am »
About 9 months old.
Yes, just died one day. Was working fine and then it didn't.
« Reply #12 on: December 22, 2022, 04:57:38 am »
Oh yeah. In this case, the bad touch-up in production may indeed have been the cause, and it wasn't caught during production tests - some soldering joint making intermittent short-circuit for instance, that ended up killing the microcontroller or something.
Some clients may ask to reject any non-functional boards after reflow and not accept rework altogether, but that would add significant production cost and would make the product much more expensive.
I don't even know if Brymen would accept that. And I guess your return rate is too low to be a concern (at least I hope so.)
« Reply #13 on: December 22, 2022, 05:21:33 am »
Correct. No concern on my part.
« Reply #14 on: December 22, 2022, 06:43:33 am »
LOL. EVERYONE including myself missed a major goof in this video. Can you spot it? It's not the fault, but it's something I was wrongly assuming. I can't believe not a single viewer picked me up on it!  :-DD
Offline armandine2
« Reply #15 on: December 22, 2022, 02:00:08 pm »
in for a penny - was the battery pack correctly loaded ?
Funny, the things you have the hardest time parting with are the things you need the least - Bob Dylan
Offline Kleinstein
« Reply #16 on: December 22, 2022, 04:23:55 pm »
Much of the test were to see if the µC runs and can be recognized from the debug / update interface.  If the µC is not running, chances are the LCD is not showing anything useful.
A suspect point could still be a power supply supervisor, if used. It may do more than enabling the supply to the µC, but it could also hold the µC in reset state.
The tricky point is that for the custom (could be just custom pin-out) µC it is not clear which pin actually is the reset input.
One may be more lucky with the LCD controller if this chip gets the same reset signal.
Offline floobydust
« Reply #17 on: December 24, 2022, 03:01:05 am »
Beuller Beuller I just watched the video and think U1 is the DMM IC, it's got all the analogs heading into it. U16 I'd say is the MCU. But then the crystal needs to feed both. I'd beep out the TX, RX programmer headers to confirm where they go.
OT fake Ferrari just auctioned off. I thought it was REAL!
« Reply #18 on: December 26, 2022, 10:00:30 am »
 :clap: You are the only one who noticed!
Someone on the live show also got it after I mentioned it and urged everyone to guess at it.
https://youtube.com/watch?v=oJbX-xcq0XU&si=EnSIkaIECMiOmarE&t=6738
Offline bob808
« Reply #19 on: December 26, 2022, 12:16:14 pm »
I was close, called the +/- 1.65V rails being for ADC.
Offline floobydust
« Reply #20 on: December 26, 2022, 10:30:23 pm »
Hey that's pretty funny. I'm just used to having no schematic, drawing out the circuit blocks in my mind, when doing repairs. Having a schematic is a luxury.
I find the best engineers in electronics have no need to be an "expert" or be right all of the time. So what, something wasn't right, just move on.
But there's this social push for "experts", know it all's- who are of course crap as designers, repair techs etc. The art constantly humbles a person.
The following users thanked this post: EEVblog
« Reply #21 on: December 26, 2022, 10:48:48 pm »
As I said in the video, most Youtubers would probably edit that out and forget it ever happened.
But I have no fear of being embarressed by a mistake made in the heat of filming.
Online golden_labels
« Reply #22 on: December 27, 2022, 01:41:43 am »
Dave, you mentioned Brymen wouldn’t share schematics with you. I wonder: how much trouble would it cause to you, if someone from audience reverse-engineered the board and published the results?
People imagine AI as T1000. What we got so far is glorified T9.
« Reply #23 on: December 27, 2022, 03:21:16 am »
Zero trouble, go for it.
I've even done a video doing some on the BM235:
Offline bob808
« Reply #24 on: January 05, 2023, 04:59:07 pm »
So the micro was dead but also another IC? What could cause this? Overvoltage on 3.3V rail? Maybe the user tried hooking something up to the programming port and maybe used 5V instead of 3.3?
Will we get a part 3 where you go further?
Offline McBryce
« Reply #25 on: January 05, 2023, 05:33:24 pm »
Hi Dave,
        this is a very off-topic question, but possibly an important one for many... Why do you have a large poster of a very questionable public figure displayed behind you? Or am I mistaking who that is? If that is who I think it is, I consider it very distasteful.
McBryce.
Online thm_w
  • Non-expert
« Reply #26 on: January 05, 2023, 10:17:13 pm »
Unlikely user would have tried to program it.
No other ICs were proven dead yet, youtube comments noted possibly low battery could cause that error.
But the actual cause, who knows, could be ESD (dave didn't think so), or that rework job was wrong, or firmware corrupting to an unrecoverable state.
Hi Dave,
McBryce.
Why not be more specific, that guy in a red and green christmas suit?
Chances are most people don't care.
Offline bob808
« Reply #27 on: January 05, 2023, 10:38:32 pm »
If just that micro died than it can clearly be a random thing. Not worth pursuing further.
Offline McBryce
« Reply #28 on: January 06, 2023, 10:11:55 am »
Hi Dave,
McBryce.
It seems to be a picture of ex-Prince Andrew.
McBryce.
« Reply #29 on: January 06, 2023, 11:17:31 pm »
Hi Dave,
McBryce.
I have no idea who he is, I found it in the dumpster and it's a joke with my live audience and twitter users who follow me when I found him in the dumpster.
I presume it's some local businessman in my business. We call him Larry.
Who do you think it is?
https://twitter.com/eevblog/status/1526911165657681921
« Reply #30 on: January 06, 2023, 11:21:12 pm »
Extremely unlikely to be ESD in a previously working meter that was not taken apart. It simply just failed one day.
« Reply #31 on: January 06, 2023, 11:22:29 pm »
Probably not, unless I find something.
Someone mentioned battery voltage, I'll double check that when I can, but I don't think it's it.
Offline McBryce
« Reply #32 on: January 07, 2023, 10:12:10 am »
Hi Dave,
McBryce.
Maybe it's just because the picture is so small (as you are in a sub-window), but it looks very like Prince Andrew from here.
McBryce.
« Reply #33 on: January 07, 2023, 11:07:18 am »
Thousands of people have seen it, you are the first one to even suggest that.
Offline McBryce
« Reply #34 on: January 07, 2023, 01:49:46 pm »
Face recognition was never my strong point :D Maybe it's just because I recently watched a documentary about him?
McBryce.
Offline IanJ
  • Country: scotland
  • Full time EE & Youtuber
    • IanJohnston.com
« Reply #35 on: January 07, 2023, 04:38:06 pm »
3.1Vdc is the power up cut-off on my BM786. Still powers up fine.
Anything below that it doesn't power up at all (nothing on the LCD).
Ian.
Ian Johnston - Original designer of the PDVS2mini || Author of the free WinGPIB app.
Website - www.ianjohnston.com
YT Channel (electronics repairs & projects): www.youtube.com/user/IanScottJohnston, Twitter (X): https://twitter.com/IanSJohnston
Online joeqsmith
« Reply #36 on: January 07, 2023, 04:56:03 pm »
I wouldn't put it past a beginner to play with that programing connector and fuck up their meter in doing so.
Offline Neutrion
  • Country: hu
« Reply #37 on: January 07, 2023, 06:11:34 pm »
Is it possible to decap the chip properly to have a picture and see what went wrong? I am not aware of many troubleshooting videos about the inside world of a microcircuit. (OK have never looked for one) It would be interesting. We would finally also have a REAL teardown picture of our loved Brymen meters brain.
In the design phase of chips it must be done, so people are possibly doing it. Maybe it would be a nice video as well. Once I saw a video about a german company producing the testers to test single transistors on the highest end processors.
And if we are here, once I posted a question on this board what could cause the mass failures of Linkswitch LNK chips and the likes, but everyone was just guessing. However it causes huge amount of electric failures.
I think there is no single other component in electronic history which alone caused so much trouble.
« Reply #38 on: January 07, 2023, 10:36:29 pm »
Possible, but from my communication with the owner it seems unlikely.
And there is a history of BM235 chips just failing.
« Last Edit: January 07, 2023, 10:38:09 pm by EEVblog »
Offline IanJ
  • Country: scotland
    • IanJohnston.com
« Reply #39 on: January 08, 2023, 01:20:27 pm »
I've had two customer instances over the years where the Atmel uP just plain failed (PDVS2mini). Both times it powered down ok at last use, but the next day it just failed to power up completely (running on batteries only).
I half think that maybe at power up or power down the 3.3Vdc regulator "fails" and maybe spikes through a higher voltage killing the uP.
Ian.
Offline Neutrion
  • Country: hu
« Reply #40 on: January 08, 2023, 08:55:45 pm »
The frontend, or the hy2613? Only a given batch is affected, or all of them? Is it known what is the process size used in these?
Isn' it extreme rare that a chip fails without overvoltage? Sorry for the many questions! :)
Because the frontend could get some spikes which get through, but the processor should be a bit more separated I suppose.
« Reply #41 on: January 08, 2023, 09:28:51 pm »
The processor. Doesn't seem to be batch related. It's not many but there is a history of it.
Offline bob808
« Reply #42 on: January 08, 2023, 11:56:37 pm »
I found this in its manual:
Beep-Jack™ Input Warning
The meter beeps as well as displays “InEr” to warn the user against possible damage
to the meter due to improper connections to the A, mA, or A input jacks when another
function, especially a voltage function, is selected.
« Reply #43 on: January 09, 2023, 03:37:29 am »
Yep, but it doesn't go away when the amps range is selected, so it's something else at fault.
Offline Kleinstein
« Reply #44 on: January 09, 2023, 10:33:27 am »
There is an report of the inEr occuring after water damage. So this could be thing with leakage or possibly a solder bridge / solder ball causing a short.
« Reply #45 on: January 09, 2023, 10:42:29 am »
IC failure is often from ESD damage at some early point, as it can take months to show up, even years, so it is insidious. Could be as simple as a broken ground lead on one of the PNP machines, but the ball races still provide a good enough path for discharge normally, only the odd chip gets zapped. Otherwise could be a die defect where a trace is just too small, and electromigration eventually makes it open.
Water ingress and conductive paths causing Iner is also common, it can take a lot of washing to remove the contamination from the board and sockets.
Offline Neutrion
  • Country: hu
« Reply #46 on: January 09, 2023, 06:23:16 pm »
That's interesting, thanks! If you would happen to have any good links to this topic I could apperciate it.
As far as I know also older (bigger) technology could be also more reliable if done properly.
As for the ball races: I would supose, that in such enviroments already conductive grease is used.
Offline bob808
« Reply #47 on: January 09, 2023, 07:23:32 pm »
Could the "InEr" error come from a bad ADC chip?
« Reply #48 on: January 10, 2023, 02:24:06 am »
In that case though the warning should stil go away when in the Amp range switch position.
Offline Jeeper44
« Reply #49 on: March 25, 2023, 01:04:28 am »
Around the 2:54 mark in the second video, 1522, you mention a content creator who has multi-series troubleshooting videos. Can you share that name again. I've tried searching based on what I think you said but haven't found them. This was right after mentioning Joe Smith.
Online Kean
    • Kean Electronics
« Reply #50 on: March 25, 2023, 07:42:23 am »
That would be Defpom
https://www.youtube.com/channel/UCllpBTH26_dAl5tYl7vA1TQ
The following users thanked this post: EEVblog, Jeeper44, TheDefpom
Offline NoMoreMagicSmoke
« Reply #51 on: May 21, 2023, 05:21:08 am »
Is this an issue specific to the BM235 chipset? Or is it a problem with the Hycontek processors in general? Have you seen many failures in the BM786 related to the processor?
« Reply #52 on: May 21, 2023, 06:15:16 am »
There have been odd failures were the chipset appears to be the culprit, but not confirmed by Brymen.
Offline Phil_A
« Reply #53 on: November 18, 2023, 04:36:21 am »
I just saw this video.  I think the U1 "microcontroller" you are pointing to is actually the HY3131 DMM front end (48 pin).  The NCs pins seem to line up.   The pins you pointed to are AGND, REFO and VSSA on the front-end. The location of Xin/Xout seem correct and the HY3131 spec sheet specifies that 4.9152 Mhz Xtal.  Perhaps U16 (64 pin) next to the buzzer is the microcontroller?   Maybe U16 is a HY16F 32bit microcontroller? - Phil
