This is the most contrived, awkward, forced video ever.
Quote from: eti on January 30, 2023, 10:22:36 amThis is the most contrived, awkward, forced video ever.Piss off, I was having fun with my son.
But I'm looking forward to the EEVblog meditation channel promoting Ohm's law.
I would have bet real money that with that IR camera you would have found a couple that were really hot due to poor assembly. Since you didn't I guess the company has good control over the assembly procedures.
Imagine having fun. How dare you?!I am deleting feeds, removing my account, withdrawing from Patreon, burning the screen on which I watched the video, and reporting you to Electrical Equipment Protection League! /s
Dang. Takes little these days to get canceled.
You really are a verrrrrrry strange man at times 🤣🤦♂️🤦♂️🤦♂️This is the most contrived, awkward, forced video ever.
What exactly would you have done with them?
Well, you can arrange them to be in blocks of 30, so you can put a double socket outlet on top of each bench, fed from the floor mounted socket outlet.
You're using a heater for a load. The adapters give off heat. Was there really a net loss of overall heat generated? If you find enough adapters during the dumpster dives, you could forget the heater and try using 100% adapters.
So that lot dropped 40V. Dave's only got to scavenge another 1400 or so, and put a shorting plug in the last one, and he can use them for distributed electric heating!
More to the point, what should I do with them now?I'm thinking maybe a stargate style ring on the wall in the dungeon? Or even the lab? but there is no wall space for it really.
Quote from: EEVblog on February 02, 2023, 11:17:02 amMore to the point, what should I do with them now?I'm thinking maybe a stargate style ring on the wall in the dungeon? Or even the lab? but there is no wall space for it really.What's the maximum curvature before they all fly apart? Minimum circle radius?
