The fastest update rate appears to be at about 20 ns/div. Your image show faster a faster timebase. Set to 20 ns/div and you should get about 4.5M wfms/s.
Yep, 4.5M on 20ns/div only. All other above and below are lower.
Not sure if setting the waveform colors to temperature impacts update rate. it may take more processing for this. I used the simple yellow (requires factory default/preset) to change the color back to default.
Nope, same.
It's a seriously cool oscilloscope, I don't see anything that I didn't like.
I'm off to write an email to my boss why the current scope isn't good enough
Fat chance.
I'm off to write an email to my boss why the current scope isn't good enough Fat chance.
Betcha they have an infinite rental budget though. Capex is always a hard no.
Their overall serial bus coverage is a bit sparse at the moment. Hoping this fills out...for engineers who need to work across a wide verity of buses.
The MXO 4 series is tempting because of its performance, but I am currently looking for a DSO which can display the FFT magnitude and phase of a differentiated waveform for impulse response testing, and the MXO4 can do neither according to its documentation. Older LeCroy and Tektronix DSOs support this and I may end up going with one of them.
