Yes, even if it could work, it likely would be limited in capacity, and would, if you can make small ceramic units, make for great bearings for small fans, like PC fans, with a life and RPM an order of magnitude over regular ones. Get the noise ultrasonic, and the life over 100k hours, and you can have non noisy fans, or at least ones that are easy to silence.
