EEVblog => EEVblog Specific => Topic started by: EEVblog on August 17, 2023, 09:27:12 pm
Tech Tip: How to use you Arbitrary Waveform Generator as a High Resolution DC Voltage Source!
https://www.youtube.com/watch?v=XKI4DOduWs4 (https://www.youtube.com/watch?v=XKI4DOduWs4)
Siglent teardown: https://www.youtube.com/watch?v=Ijb_SzJ9Fs0 (https://www.youtube.com/watch?v=Ijb_SzJ9Fs0)
Nice video.
A while ago I digged through as much videos about the Siglent generator as I could find on you channel. The teardown convinced me the most.
I remembered from 1 of those videos that you prefer to change the load / output impedance setting by holding the "output" button above the BNC connector and the Siglent couldn't do that. Maybe it was a software version thing, because mine does exactly that and the video is from the first release back then.
Likely this is redundant info for you, but I saw you pushing through the menu doing that. That output button isn't really easy accessible with a T connector / splitter in the way.
[attachimg=1]Good morning, as always a splendid informative and above all interesting video, thank you very much David. Taking advantage of the topic, I have a problem with a similar generator model but with 80MHz with the possibility of loading waveforms from USB or from PC. I have a need that I can't solve and in the following: I can't find any file with a signal pattern of video color bars in CVBS format similar to those offered by the old TV signal pattern generating equipment to perform calibrations. I have searched the internet and I also consulted the manufacturer, unfortunately I did not get an affirmative answer. Do you know if there is a similar file?
Thank you
