Author Topic: EEVblog 1567 - Wireless ESD Monitor? - The IONA StatIQ Band TESTED  (Read 4062 times)
Offline EEVblogTopic starter
« on: September 25, 2023, 11:02:03 pm »
Does the $1200 IONA Tech StatIQ wireless ESD monitor actually work? or is it just BS?
And if so, how does it work?
Wiresless ESD strap BUSTED:
ESD Explained:
ESD Playlist: https://www.youtube.com/playlist?list=PLvOlSehNtuHsKCtJJ_rlRP5qE7lN-1EMX
Online Bud
Re: EEVblog 1567 - Wireless ESD Monitor? - The IONA StatIQ Band TESTED
« Reply #1 on: September 25, 2023, 11:47:20 pm »
Market it to Ghost hunters and Prana healers and retire early.  :-+
Offline thm_w
  • Non-expert
« Reply #2 on: September 26, 2023, 09:20:47 pm »
It could also be sold as a scifi prop, the spinning gold part is just wild.
« Reply #3 on: September 28, 2023, 12:31:58 am »
Indeed!
If I had done a modicum of reserach I would have found out it's a minature Field Mill.
https://en.wikipedia.org/wiki/Field_mill
Offline BreakingOhmsLaw
  • Certified solder fume addict
« Reply #4 on: October 06, 2023, 04:58:09 pm »
Basically a classic field mill. I've been building field mills for some years now.
The reason why it's gold plated actually is not corrosion, as you might suspect.
 It  is because gold (1,69V) is galvanically closest to oxygen (1,76V).
So that increases the accuracy of your field mill.
If designed correctly, field mills can be pretty accurate.
The challenge when designing a field mill is having an instrumentation amplifier with extremely high CMRR, as jt will pick up all the 50Hz noise around you from the power lines.
https://en.m.wikipedia.org/wiki/Field_mill
« Last Edit: October 06, 2023, 05:02:17 pm by BreakingOhmsLaw »
The following users thanked this post: EEVblog, thm_w
