Author Topic: EEVblog 1574 - Is the $42 Fluke 101 Multimeter Any Good?  (Read 11506 times)
Offline joeqsmith
Re: EEVblog 1574 - Is the $42 Fluke 101 Multimeter Any Good?
« Reply #25 on: October 31, 2023, 01:25:13 am »
Dave,  watched your EEVBLOG2 box of random meters and noticed the old KeySight.  Offer still stands for the two meters if you're interested.  You never posted why you cancelled the auction for the Agilent.  Maybe you no longer have it.  I would still be interested in the ICs from that Keysight.
Offline EEVblogTopic starter
« Reply #26 on: October 31, 2023, 02:04:37 am »
The Keysight slowly drifted back out of spec after a few days. So I could sell it as repaired.
I don't know why you want to pay so much for a scrap PCB and a dodgy OLED meter, what's the catch?
Offline joeqsmith
« Reply #27 on: October 31, 2023, 12:36:15 pm »
The only stipulation is pull the PCB from the U1282A and check that none of the ICs have cracked cases or missing pins.  You can keep all the mechanics.  Just place the board in an anti static bag.   Nothing needs to be done with the U1273AX.  I understand it is as is.  If you want to further lighten the load, you could toss in a dead current revision of the 121GW, assuming there was one.  Hardly makes a dent.
Consider my offer a donation for use of this forum and keeping me entertained for a decade.
Online Fryguy
« Reply #28 on: October 31, 2023, 07:14:34 pm »
This Fluke 101 reminds me of the Extech EX330 - which i like much more than the 101 . Way more bang per buck . . .  :-DMM
Born error amplifier  >.<
Offline dobsonr741
« Reply #29 on: October 31, 2023, 11:22:37 pm »
Got a 101 last week, encouraged by this tread. It was too small and too little in features. Returned, got a Thsinde 18 Z-III for bit less. Happy with the swap. The 18Z is accurate and the continuity test is fast. Recommended.
Offline Monkeh
« Reply #30 on: October 31, 2023, 11:26:43 pm »
Reads thread about a video review which makes it clear this is an extremely compact and basic meter. Buys meter. Returns it for being small and basic. :-DD
The following users thanked this post: Fungus
Offline AG6QR
    • AG6QR Blog
« Reply #31 on: October 31, 2023, 11:46:59 pm »
I own two of these -- one in each of my vehicles.  A very solid meter, compact, with a minimal feature set and good reliability.
I've recommended them to several people who rarely use a meter, but want the ability to do some basic tests.
The fact that there's no current range is certainly a limitation, but it's also a safety feature, since it eliminates the possibility of touching probes to a stiff voltage source when they're in a low-impedance current measuring configuration.
At my local ham radio club, whenever I have a chance to check out someone else's meter, I always test the fuse(s) for the current mode.  Many of the ones I test are blown, which suggests that a) it's not uncommon for someone to make that mistake, and b) when they do make that mistake, many casual users don't value a working current range sufficiently to replace the fuse.
If you're the kind of person who needs a current range, knows how to use it properly, and will replace the fuse when it's blown, this meter is not for you -- at least not as your only meter.  But you're probably not the kind of person who will ask me for a recommendation, either.
Online Fungus
« Reply #32 on: November 01, 2023, 01:05:12 am »
Most people only need volts and continuity in a meter.
Yep, I've seen that many, MANY times.
I've also seen too many people pull the fuse out and wrap it in tin foil when I point it out to them. These are the ones who should own a Fluke 101.
The following users thanked this post: AG6QR
Offline nctnico
« Reply #33 on: November 01, 2023, 01:09:23 am »
This is the reason I buy DMMs with at least 4.5 digits. There will be enough resolution on the unfused 10A range to do all current measurements while not worrying about blowing a fuse inside the DMM 8)
Online Fungus
« Reply #34 on: November 01, 2023, 11:57:37 am »
Sure,  that's why you need them...  ;)
Offline fdk
  • Country: jp
« Reply #35 on: November 05, 2023, 02:56:38 pm »
I bought one of these about 3 years ago, here in Japan.  Was about JPY5500 or something like that at the time.  Basically bought it because it was a Fluke, and it did enough of what I need.   It has been absolutely fine, good enough for all the repairs I've done over the last 3 years (hifi, appliances, automotive, etc) especially when paired with a scope.  I can confirm it is very solidly built and I have no qualms about using it on mains.  Only minorly annoying thing is that the back is rounded so it rarely sits nicely on a flat surface and it is hard to prop up in a position where you can view it easily.  Clearly, I have managed regardless  :)
Online Fungus
« Reply #36 on: November 05, 2023, 05:09:01 pm »
The magnetic hanger accessory works like a stand. See pics on page 1...
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #37 on: November 05, 2023, 05:53:35 pm »
As far as the stand/hanger, I wonder if Dave's was lost.  Mine has a compartment to hold it inside of the shipping box.  I've never had it out until now.   It does have a magnet if you use it for a hanger.
Mine has the compartment but there was nothing in it. I wondered what the compartment was for!
That certainly adds value.
The stand/hanger is part of the Fluke 101 Kit - the basic Fluke 101 does not come with it.
I mentioned this before, but my experience with the quality control of the Fluke 101 was very disappointing. The first (2017 date code) had issues with the display. The second (2016 date code) did not, but both had oxidized pads on the PCB vias and pads, including the ones leading to the LCD.
This may be due to improper storage, but it was coming from two different sellers from very different locations.
Perhaps they improved that nowadays, but I won't be caught doing the same mistake... thrice.
Offline joeqsmith
« Reply #38 on: November 05, 2023, 09:39:21 pm »
Mine came from some seller on Amazon.  I don't see any mention of a "kit" on the box, but it is all in Chinese.   The box is different from what Dave showed in his review but I bought mine several years ago so I'm not too surprised.
« Last Edit: November 05, 2023, 09:49:38 pm by joeqsmith »
Online Fungus
« Reply #39 on: November 06, 2023, 12:21:32 am »
I didn't get one with mine but I knew that when I ordered it.
You can buy them separately on Aliexpress but they aren't cheap - about half the price of the meter.
Maybe 3D print a stand instead. There's half a dozen on thingiverse.
Offline fdk
  • Country: jp
« Reply #40 on: November 06, 2023, 02:31:54 am »
The magnetic hanger accessory works like a stand...
I wonder if that is a later addition, as I don't remember ever seeing that in the box.  I think I still have it somewhere...might check if I find it.
Regardless, if that comes with them now, then it makes it even better.
Offline joeqsmith
« Reply #41 on: November 06, 2023, 01:37:06 pm »
I purchased mine in 2015.  From the paper inside, guessing the meter was inspected/built on 5/4/2015.
Maybe it was originally included but removed later to increase profits.   No idea.
« Last Edit: November 06, 2023, 01:39:02 pm by joeqsmith »
Online newbrain
« Reply #42 on: November 06, 2023, 03:57:14 pm »
I'm quite sure the shunt resistor for 10 A will act as a fuse given enough effort.
Ask my Iskra Unimer 3 and my 12 y.o. self how I know. (5 A full scale, to tell the truth)
