Author Topic: EEVblog 1609 - Composite Amplifier Tutorial + Practical Demo  (Read 18477 times)
Online EEVblogTopic starter
« on: April 10, 2024, 09:16:42 pm »
A lot of texbooks don't teach Composite Amplifiers, but they are one of the most used circuit configurations to solve real world design poblems where you have multiple conflicting specifications.
Opamp Tutorial Playlist: https://www.youtube.com/playlist?list=PLvOlSehNtuHu2FviAaZaiyXwN41G4b1Lf
Cascaded Compound Amplifiers:
00:00 - Composite vs Compound Amplifiers
02:53 - How a Composite Amplifier works
05:09 - Why not just cascade them?
07:23 - This doesn't just apply to opamps
08:24 - An example with gain, and another way to look at it
09:37 - Composite gain vs stage gain
11:19 - What's the catch? + rule of thumb for stability
12:42 - Another example: Composite precision high bandwidth amplifier
14:50 - Breadboard demonstration of Composite vs Compound amplfiers
19:09 - Changing to Composite configuration and Magic Happens
20:07 - More magic as it compensates for the buffer drop too
Offline Kleinstein
Re: EEVblog 1609 - Composite Amplifier Tutorial + Practical Demo
« Reply #1 on: April 11, 2024, 09:58:07 am »
The stability part can become quite tricky. I know that this can be a complicated topic, but with the 2nd amplifier in the loop stabilty really is an issue to keep in mind. It is at least a good idea to use a simulation to check stabilty upfront.
It is rare to have 2 equal amplifiers combined. The usual tendency is to have the 2nd amplifier that is inside the loop of the other to be the faster one. If the 2 amplifiers are the same speed, the gain should not be split evenly, but less for the 2nd amplifier to make sure it is still fast enough.
Attached is a Burr-brown Application note on Composite amplifiers.
The amplifier in the µCurrent is a case where a composite amplifier instead of 2 amplifiers in series would make sense.
Offline Nominal Animal
« Reply #2 on: April 11, 2024, 01:43:09 pm »
It is exactly the combined feedback approach that made this video so useful to me: it simply hadn't occurred to me before, but now makes very much sense.
I consider the one on the input side as the "outer" opamp, and the one on the output side as the "inner" opamp, to intuitively understand how the feedback works, and what the limitations of the combined system are.
As a first approximation for the entire system, the "outer" opamp's noise and accuracy/drift dominates the combined system, but is "supported" by the "inner" opamp especially in slew rate and amplification (by taking part of the burden from the "outer" one).
Even if one uses ideal opamp models in spice (KiCAD/ngspice has a OPAMP model in the Simulation_SPICE section), modeling noise using input and output referred voltage signals, shows directly how the outer input-referred noise gets amplified by both opamps, but outer output-referred and inner input-referred noise only by the inner opamp, giving a rough idea how amplification should be divided between the two opamps.  Of course, real-world properties, especially noise (not being purely input- or output-referred) and gain-bandwidth product, affects that somewhat so simulation with appropriate models will yield much better results; point being that even super-simplifying the situation one gets pretty good starting points: no black magic here.
I'm particularly interested in the case of using opamp output to control the gate or base of a transistor, with feedback across both the transistor and the opamp.  In that case, the "inner" one is a transistor "amplifier" instead of an opamp, but the same intuitive model still applies just fine.
In the Art of Electronics, figure 4.29 shows a feedback voltage regulator using this scheme, but I'm even more interested in voltage-controlled constant current sources (in the 0-120mA range) with PWM/PDM capability for flicker-free display backlight LEDs.  (This allows one to choose between constant current-controlled LED drive which can affect the color at lower currents, and PWM/PDM at specific current designed to optimize color output and backlight lifetime, at run time, with just microcontroller firmware changes.)
Manipulating the feedback, or the transistor base/gate, seem both workable options for this.  I haven't simulated this yet, because I'm still looking at components I can both obtain easily but also use in KiCAD/ngspice simulations, but it definitely opened up an easy way to approach the underlying problem at a conceptual level without just copying suggested schematics and trying to understand how they work.
Thanks!  Figures 1 to 4 confirm to me my new understanding is correct to at least the first approximation, while showing how much the exact details affect the combined system –– that is, that modeling and practical experimentation is necessary to verify and optimize the first approximation.
Stability/oscillations is always a bit of an issue in feedback-based systems, but to me, a hobbyist, grasping the basic feedback path makes it much less scary, more like an issue to watch for.
Compare to e.g. linear voltage regulators that require a specific load and capacitance to not oscillate.  To me, those are black boxes. I basically have to estimate the minimum and maximum load and capacitance of the rest of my system.  All those supply bypass capacitors do add up quickly even in relatively simple microcontroller projects; and then their spiky or pwm/pdm-like current draw –– switching noise in MCUs and OLED displays being worst offenders –– means someone like me without enough practical experience cannot ever be sure before testing and measuring the worst case conditions in practice.
Offline Kleinstein
« Reply #3 on: April 11, 2024, 03:34:36 pm »
The noise of the inner amplifier to a large part (at least for the lower frequencies) corrected by the outer amplifier. So it is more than just less gain, but near perfect correction from the other amplifier. It is only the higher frequency noise that can be relevant as the outer op-amp is no longer fast enough to correct.
The theory is for a voltage output. It gets more tricky with a current output, as than the load capacitance also effects the loop gain. Even the voltage outputs are not zero impedance, especially at higher frequency. This is why capacitive load can lead to additional delay / phase shift and if to much adds up the loop can start oscillating.
A point not covered in Daves video and also the linkes App. note is a mixed feedback, e.g. in the classical circuit to drive a capacitive load. Here the low frequency part is like the composite amplifier with an emiter follower for more current drive. However the higher frequency part gets direct feedback via a capacitor from the "outer" amplifier. So for the higher frequencies it is more like 2 stages in series.
