I have received mine some minutes ago.
FW 1.03 too.
After making some adjustement on tweezer, and setup some items in the menu+voltage calibration (+0.2V offset for mine - checked with my Keysight U1232A DMM): I find this really a great tool after testing removal of some SMD caps and R
It is super fast for that task
Menu items are not so hard after understanding the 5s timeout for waiting to go back.
But I have some T° overshoot showing on the Oled screen like we can see on the Dave review, but not as big as in the video, don't know if it is a bug with having 2 sensors, or real overshoot ? I will try to check that back home.
Also, I have not found support page on the Sequre website for downloading firmware of this HT-140.
So I don't know how the 1.02FW user could upgrade their tweezers
Edit:
>About 2 to 5°C off so it is good, will try to calibrate it later.
>All is grounded to USB-C and DC ground. About 100VAC between tips and mains ground. Will try also to put the mains ground on negative, but I have to check the leakage current before.
>Positive DC Jack is also the positive USB-C, so we can also power directly from USB-c at any voltage without having a PD or any other handshake protocol negociation.
I already do this with my MHP30 hotplate
