I'm curious what the outputs of the supply board showed with the low input voltage. Assuming the others are right about accepting a wide range of input values, the outputs might have been correct. Alternatively, ignore inputting the input voltage and use power supplies to just generate the output values and bypass the board altogether to test the other parts of the system. Might help figure out how much of the whole thing is working correctly and tell you more about whether it's worth moving forward.
