LoZ is fine while the inputs not exceeded.
Discharging on ohms is bad practice due to unexpected failure modes, in turn leading to accidents.
You're essentially abusing the input for the sake of an otherwise trivial task such as making a discharge resistor lead (good practice in understanding discharge curves).
