Author Topic: EEVblog 1655 - Multimeter TIP: Discharge Capacitors using ANY meter  (Read 5791 times)
Offline Shock
Re: EEVblog 1655 - Multimeter TIP: Discharge Capacitors using ANY meter
« Reply #25 on: December 21, 2024, 05:33:55 pm »
LoZ is fine while the inputs not exceeded.
Discharging on ohms is bad practice due to unexpected failure modes, in turn leading to accidents.
You're essentially abusing the input for the sake of an otherwise trivial task such as making a discharge resistor lead (good practice in understanding discharge curves).
Offline David Hess
  • DavidH
« Reply #26 on: December 21, 2024, 06:09:27 pm »
Sometimes I install a discharge resistor into a dual banana plug and place the dual plug between the multimeter and test leads.  Or I used one of my multimeters which has standard binding posts.  Then I can have any input resistance that I want in voltage mode.  Of course this depends on the multimeter having standard 3/4" spacing which many newer meters do not.
The following users thanked this post: Shock, thm_w
Offline Shock
« Reply #27 on: December 21, 2024, 06:31:44 pm »
There is a schematic or teardown somewhere of Flukes LoZ addon accessory which is a dual banana. Resistor is handy for loading power supplies and circuits in a pinch as well.
