Author Topic: EEVblog 1567 - Wireless ESD Monitor? - The IONA StatIQ Band TESTED  (Read 9695 times)
Online EEVblogTopic starter
« on: September 25, 2023, 11:02:03 pm »
Does the $1200 IONA Tech StatIQ wireless ESD monitor actually work? or is it just BS?
And if so, how does it work?
Wiresless ESD strap BUSTED:
ESD Explained:
ESD Playlist: https://www.youtube.com/playlist?list=PLvOlSehNtuHsKCtJJ_rlRP5qE7lN-1EMX
Offline Bud
Re: EEVblog 1567 - Wireless ESD Monitor? - The IONA StatIQ Band TESTED
« Reply #1 on: September 25, 2023, 11:47:20 pm »
Market it to Ghost hunters and Prana healers and retire early.  :-+
Offline thm_w
  • Non-expert
« Reply #2 on: September 26, 2023, 09:20:47 pm »
It could also be sold as a scifi prop, the spinning gold part is just wild.
« Reply #3 on: September 28, 2023, 12:31:58 am »
Indeed!
If I had done a modicum of reserach I would have found out it's a minature Field Mill.
https://en.wikipedia.org/wiki/Field_mill
Offline BreakingOhmsLaw
  • Certified solder fume addict
« Reply #4 on: October 06, 2023, 04:58:09 pm »
Basically a classic field mill. I've been building field mills for some years now.
The reason why it's gold plated actually is not corrosion, as you might suspect.
 It  is because gold (1,69V) is galvanically closest to oxygen (1,76V).
So that increases the accuracy of your field mill.
If designed correctly, field mills can be pretty accurate.
The challenge when designing a field mill is having an instrumentation amplifier with extremely high CMRR, as jt will pick up all the 50Hz noise around you from the power lines.
https://en.m.wikipedia.org/wiki/Field_mill
« Last Edit: October 06, 2023, 05:02:17 pm by BreakingOhmsLaw »
The following users thanked this post: EEVblog, thm_w, I wanted a rude username
Offline kingsolmn
  • 220, 221 - whats the difference?!
    • TeamRampage Services
« Reply #5 on: December 23, 2024, 07:07:44 am »
And then Medhi uses the same device to prove why living or existing near high-tension power lines makes you tingle but doesn't cause cancer! Lol
Tho, I really wish I was near that bridge to experience this myself! The closest I've been to this type of thing is the Hoover Dam and it wasn't nearly as dramatic because of the EXTENSIVE grounding plane they established around the visitor facilities near the power lines leaving the power plant! I mean, 000 gauge wires bolted to the rocks running in an extensive array around the parking garage, and even the hand railing on the steps was ground strapped - taking no chances! Lol
P.S. - If no one beats me back there, I'll grab some pics of this all if anyone is interested the next time I'm through there sometime between now and fall 2025.
I run a small IT/Electronics repair shop out of my garage. The electronics part came about because my son was getting old enough to use a soldering station by himself and does some pretty interesting things (and he has plenty of ideas!) and e-waste recycling for parts (except for the eBay stuff).
Offline Langdon
    • My website + My software
« Reply #6 on: February 25, 2025, 04:25:55 pm »
Apparently, if you stick fluorescent tubes into the ground under high-voltage power lines, they will glow a bit.
My website used to be www.getpacman.gq
It is now www.langdonstaab.ca
"Low-tech solutions are beautiful"
