Author Topic: EEVblog 1677 - An Interesting Effect with Fuses (EXPERIMENT)  (Read 1742 times)
Offline EEVblogTopic starter
« on: March 31, 2025, 10:02:07 am »
An experiment to test an interesting effect with fuses.
The following users thanked this post: thm_w, pdenisowski, golden_labels
Offline MaTkEOxjC
  • Country: at
Re: EEVblog 1677 - An Interesting Effect with Fuses (EXPERIMENT)
« Reply #1 on: March 31, 2025, 10:34:25 am »
Did you just put them into the Freezer at -17°C until they reached temperature or did you follow any specific thermal shock?
Btw. Here is the old video:
Offline tszaboo
« Reply #2 on: March 31, 2025, 11:29:10 am »
10 minutes. You got me for 10 minutes.  :-DD :clap:
« Last Edit: March 31, 2025, 11:32:07 am by tszaboo »
Online tggzzz
« Reply #3 on: March 31, 2025, 12:13:12 pm »
Offline riyadh144
« Reply #4 on: March 31, 2025, 04:29:11 pm »
I got got. You were able to exploit my material weakness.
Offline reodor
  • Country: no
« Reply #5 on: April 01, 2025, 05:04:07 am »
Time zones, mate.
Offline pdenisowski
  • Product Management Engineer, Rohde & Schwarz
    • Test and Measurement Fundamentals Playlist on the R&S YouTube channel
« Reply #6 on: April 01, 2025, 08:37:54 am »
Grok agrees:
Test and Measurement Fundamentals video series on the Rohde & Schwarz YouTube channel:  https://www.youtube.com/playlist?list=PLKxVoO5jUTlvsVtDcqrVn0ybqBVlLj2z8
Offline bitwelder
« Reply #7 on: April 01, 2025, 09:19:52 am »
OMG! Now I wonder the fuse shipments that go through freezing transport phases (unheated airplane cargos, polar regions of the world) how they do it.
There is a place for a certificate of non-refrigeration during transport and stocking :P
Online tggzzz
« Reply #8 on: April 01, 2025, 09:35:21 am »
Time zones, mate.
Really? What are they? :)
Online tggzzz
« Reply #9 on: April 01, 2025, 09:39:43 am »
Grok agrees:
Grok both an LLM and a Musk product, isn't it?
https://duckduckgo.com/?q=%22jones+effect%22+fuse shows many results, none related to EEVBlog. Why am I not surprised :)
Offline temperance
« Reply #10 on: April 01, 2025, 11:27:21 am »
After seeing this and realizing that no matter how you look at it everything is a fuse I tossed a 250 W SMPS into the freezer and set it to -20°C.
Deficiency before freezing: 8 %
Deficiency after freezing cycle: 6 %
More experiments will be required because the change in efficiency isn't in line with the resistance change measured on a simple fuse. The problem is that I'm not a metalurologist.
Offline thm_w
  • Non-expert
« Reply #11 on: April 01, 2025, 09:28:57 pm »
Now do the same with a SRF.
Efficiency before freezing: 8 %
Efficiency after freezing cycle: 6 %
More experiments will be required because the change in efficiency isn't in line with the resistance change measured on a simple fuse. The problem is that I'm not a metallurgist.
Fixed spelling above.
The FET resistance should drop so that might be the main increase in efficiency.
Offline tszaboo
« Reply #12 on: April 01, 2025, 09:40:53 pm »
Yeah, for that we need to turn to this Youtube channel called The chemical path, formerly known as the signal path.
