Not being able to run ./lcdtest after running make: this is the fault of unix voodoo and your USB stick having a windows (probably fat32 or exfat) filesystem. The problem was solved when you moved the files to your raspberry pi's (probably ext4) filesystem.
OLED and monochrome LCDs are magnitudes different in terms of power consumption. Also a reflective LCD is set and forget, whilst an actively lit screen requires brightness controls (or annoyance).
What would be a practical usage of such an uTimer in the lab? Perhaps - in a chemistry lab or a similar one lab where you have to cook something for, say, 360 minutes long..In an EE lab you have to measure or watch time with picoseconds resolution these days, imho.. unless you want to measure the time you need to find and fix a shorted capacitor on a motherboard.. ..
If a manufacturer is offering a RasPi demo for their product, it would save so much time if they just provided a full SD card image, so no RasPi knowledge is needed.
Why not colour OLED than black&white LCD? I hate theose old fashioned LCD displays.
Quote from: mikeselectricstuff on August 02, 2025, 10:29:02 amIf a manufacturer is offering a RasPi demo for their product, it would save so much time if they just provided a full SD card image, so no RasPi knowledge is needed.I don't know why they offer that demo board, seems overly complex having to supply a different programmed MCU and I/O matrix for each display.Just have an Rpi SD card image as you said, and supply the cable with the adapter board.
OLED's are power hogs.
My iphone has a timer/alarm/clock, in colour, so why would anyone want a standalone timer?
I think the Memory LCDs were mentioned, but possibly you rejected that because there wasn't one large enough for your project? There is. Several of us just here have used the 4" version which is 400x240 (IIRC) and has very good contrast and viewing angle. It doesn't seem to be available anymore from Sharp for some reason, but they have a bunch of new references to choose from:https://www.sharpsecd.com/#/memory-in-pixel-lcds-productI'd be surprised if you didn't find one that fits.The downside is the cost, but I don't know if it matters in your project or not.
If this is going to be a real life product. It's very likely go be hacked into and modified by quite a lot of people. To me it makes sense to turn this into a community project right from the start. Community projects need a project leader to give it guidance and a clearly defined scope. Dave can of course design whatever he wants. Define functionality and features etc...
Quote from: chilternview on August 02, 2025, 10:15:34 amWhy not colour OLED than black&white LCD? I hate theose old fashioned LCD displays.OLED's are power hogs.
Quote from: EEVblog on August 02, 2025, 11:41:52 amQuote from: chilternview on August 02, 2025, 10:15:34 amWhy not colour OLED than black&white LCD? I hate theose old fashioned LCD displays.OLED's are power hogs.Maybe e-paper / e-ink displays.
Quote from: BrianHG on August 04, 2025, 12:10:01 amQuote from: EEVblog on August 02, 2025, 11:41:52 amQuote from: chilternview on August 02, 2025, 10:15:34 amWhy not colour OLED than black&white LCD? I hate theose old fashioned LCD displays.OLED's are power hogs.Maybe e-paper / e-ink displays.They are not designed for continuous and fast display updating.
