Author Topic: EEVblog 1714 - Presonus Eris Speaker REPAIR (Capacitor Pop)  (Read 1490 times)
Offline EEVblogTopic starter
« on: October 17, 2025, 12:39:00 am »
Classic intermittent "popping" noise from this Presonus Eris 5 studio monitor speaker. Electrolytic Capacitors are suspect number one.
00:00 - Faulty Presonus Eris 5 speaker. Classic "popping" sound.
03:48 - Teardown
07:16 - Testing for popping again
07:36 - Testing for hiss
08:32 - Rectified voltage testing
09:34 - Woah, that's that?
10:26 - Getting the PCB out
10:55 - A look at the PCB under the microscope
TAD7294:
https://www.st.com/resource/en/datasheet/tda7294.pdf
13:15 - Missing parts
14:39 - Removing the capacitors
16:00 - Measuring the main filter capacitors
17:14 - The Preamp PCB
18:08 - What is the most likely culprit?
20:21 - In-circuit  ESR testing
21:32 - All new capacitors
24:15 - Soldering in new caps and testing
25:38 - What did I goof?
27:57 - Conclusion
« Last Edit: October 17, 2025, 05:22:36 am by EEVblog »
Offline Simmed
Re: EEVblog 1714 - Presonos Eris Speaker REPAIR (Capacitor Pop)
« Reply #1 on: October 17, 2025, 12:47:37 am »
*presonus
Offline Brumby
Re: EEVblog 1714 - Presonus Eris Speaker REPAIR (Capacitor Pop)
« Reply #2 on: October 21, 2025, 05:31:09 am »
@EEVblog
Dave ..... Has the popping stopped?
