Here's a small list of 100+ selected MOSFETs I came across over the years, some are complete jellybeans and others are not so much.
I don't remember exactly for what particular purpose I've bought each one of them, but I tried to leave some comment on the properties of each device.
A general motif for selection is top voltage/current-wise performance in a particular package.
Maybe this helps to choose a good MOSFET for a job without scanning huge supplier catalogs.
Please excuse me for not filling all parameters in the table.
| Name | Package | Polarity | Uds, V | Id, A | Rds, Ohm | Vgs, V | Vgs.th, V | S, A/V | Manufacturer | Comment |
| NTS4001NT1G | SC70-3 | N | 30 | 0,27 | 1,5 | 20 | 1,2 | | ONS | A smaller version of 2N7002 |
| NTS4173PT1G | SC70-3 | P | -30 | -1,3 | 0,165 | 12 | -1,15 | | ONS | P-type complement to 2N7002, small package |
| BSN20.215 | SOT-23 | N | 50 | 0,173 | 15 | 20 | 1 | | NXP | Some cheapie like BSS138 |
| BSS138 | SOT-23 | N | 50 | 0,22 | 3,5 | 20 | 1,4 | | FAIR | Another cheap crap, doesn’t like static and temperature |
| 2N7002K-T1-GE3 | SOT-23 | N | 60 | 0,3 | 2 | 20 | 2,5 | 0,35 | VISHAY | Jellybean with built-in TVS |
| MMBF170LT1G | SOT-23 | N | 60 | 0,5 | 5 | | | | ONS | 2N7002 with a purposely higher Rds.on |
| IRLML0100TRPBF | SOT-23 | N | 100 | 1,6 | | 16 | | | IR | 100Vds SOT23 N-type |
| SI2302CDS-T1-E3 | SOT-23 | N | 20 | 2,4 | 0,06 | 8 | | | VISHAY | Nice low voltage MF, 2.4A |
| IRLML0060TRPBF | SOT-23 | N | 60 | 2,7 | 0,092 | 16 | 2,5 | | IR | Best of both worlds, 60V 2.7A |
| IRLML2502TRPBF | SOT-23 | N | 20 | 4,2 | 0,045 | 12 | | | IR | Even nicer low voltage jellybean, 4.2A |
| IRLML0030TRPBF | SOT-23 | N | 30 | 5,3 | 0,027 | 20 | 1,7 | | IR | Top high current stuff |
| 2SJ305TE85LF | SOT-23 | P | -30 | -0,2 | 2,4 | 20 | -1,5 | | TOSHIBA | Low Vgs.th, high side current sensing |
| BSH201.215 | SOT-23 | P | -60 | -0,3 | 2,5 | 20 | -1,9 | | NXP | P-type complement to 2N7002 |
| BSS83PH6327XTSA1 | SOT-23 | P | -60 | -0,33 | 2 | 20 | -1,5 | | Infineon | BSH201 replacement |
| SI2307BDS-T1-E3 | SOT-23 | P | -30 | -3 | 0,064 | 20 | -1 | 4,5 | VISHAY | An older version of SI2307CDS-T1-E3 |
| SI2307CDS-T1-E3 | SOT-23 | P | -30 | -3 | 0,064 | 20 | -1 | 4,5 | VISHAY | Generic 3A P-type |
| SI2305DS-T1-GE3 | SOT-23 | P | -8 | -3,5 | 0,052 | 8 | -0,8 | | VISHAY | Very low Vgs.th |
| IRLML9301TRPBF | SOT-23 | P | -30 | -3,6 | | | | | Infineon | Modern replacement for SI2307CDS-T1-E3 |
| IRLML6402TRPBF | SOT-23 | P | -20 | -3,7 | | | | | IR | A bit different Vds/Id tradeoff |
| BSR92PH6327XTSA1 | SOT-23 | P | -250 | -0,14 | 11 | 20 | | | Infineon | High voltage P-type |
| BSS127H6327XTSA2 | SOT-23 | N | 600 | 0,021 | 500 | 20 | | | Infineon | High voltage N-type |
| BSS131H6327XTSA1 | SOT-23 | N | 240 | 0,1 | 14 | 20 | | | Infineon | High voltage N-type |
| BSS139H6327XTSA1 | SOT-23 | N | 250 | 0,03 | 30 | 20 | | | Infineon | High voltage N-type |
| IRLML6401TRPBF | SOT-23 | P | -12 | -4,3 | 0,05 | 8 | | | IR | Current for voltage tradeoff |
| SI2305CDS-T1-GE3 | SOT-23 | P | -8 | -5,8 | 0,035 | 8 | -1 | | VISHAY | Even higher amps, but very low Vds |
| DMN1019USN-13 | SC-59 | N | 12 | 9,3 | 0,01 | 8 | 1,2 | | DIODES | Low Vgs.th, high side current sensing |
| DMN2005K-7 | SOT-23 | N | 20 | 0,3 | 0,4 | 10 | 0,9 | | DIODES | Low Vgs.th, high side current sensing |
| IRLTS2242TRPBF | SOT23-6 | P | -20 | -6,9 | 0,023 | 12 | -1,1 | | IR | Crazy amps SOT23 |
| FDC6420C | SOT23-6 | 1xN+1xP | 20 | 3/-2,2 | | 12 | | | ONS/FAIR | Push-pull in single package |
| BFF199/T1 | SOT-143 | 2G1N | | | | | | | NXP | Dual gate high frequency for radio stuff |
| BSP126.115 | SOT-223 | N | 250 | 0,375 | 5 | 20 | | | NXP | High voltage N-type |
| IRFL4105TRPBF | SOT-223 | N | 55 | 3,7 | 0,045 | 20 | 4 | | IR | 4105 family but small |
| BSP317PH6327XTSA1 | SOT-223 | P | -250 | -0,43 | 4 | 10 | -1 | | Infineon | High voltage P-type |
| IRFR4105PBF | DPAK | N | 55 | 3,7 | 0,045 | 20 | 4 | | IR | 4105 but DPAK |
| IRFR4105ZPBF | DPAK | N | 55 | 3,7 | 0,045 | 20 | 4 | | IR | 4105 but DPAK |
| IRF5852TRPBF | TSOP-6 | 2xN | 20 | 2,7 | 0,09 | | 1,25 | | IR | 2 in 1 N-type |
| IRF7331PBF | SO8 | 2xN | 20 | 7 | 0,03 | | 1,2 | | IR | Low side of full bridge |
| IRF7313PBF | SO8 | 2xN | 30 | 6,5 | | | | | IR | Low side of full bridge |
| IRF8513PBF | SO8 | 2xN | 30 | 11 | | | | | IR | Low side of full bridge |
| IRF9358PBF | SO8 | 2xP | -30 | -9,2 | | | | | IR | High side of full bridge |
| IRF7316PBF | SO8 | 2xP | -30 | -4,9 | | | | | IR | High side of full bridge |
| IRF7379PBF | SO8 | 1xN+1xP | 30 | 4,3 | 0,09 | 20 | | | IR | Push-pull driver, half bridge |
| SP8M3FU6TB | SO8 | 1xN+1xP | 30 | 4,5/-4,5 | | | | | | Push-pull driver, half bridge |
| AO4606 | SO8 | 1xN+1xP | 30 | 6,9/-6 | | | | | | Push-pull driver, half bridge |
| IRF7389PBF | SO8 | 1xN+1xP | 30 | 7,3/-5,3 | | | | | IR | Push-pull driver, half bridge |
| AP9930GM | SO8 | 2xN+2xP | 30 | 5,5/-4,1 | 0,033/0,055 | | | | AdvancedPower | Full bridge in single package |
| SI9426DY | SO8 | 1xN | 20 | 10 | 0,0135 | 8 | 0,6 | | VISHAY | Crazy amps SO8 N-type, low Vgs.th |
| IRF7410PBF | SO8 | P | -12 | -16 | | | | | IR | Crazy amps SO8 P-type, low Rds.on |
| IRF7757TR | TSSOP-8 | 2xN | 20 | 4,8 | 0,035 | | 1,2 | | IR | Typical Li-Ion protection |
| FS8205A | TSSOP-8 | 2xN CD | 20 | 6 | 0,0275 | 10 | 0,65 | | SILKRON | Typical Li-Ion protection |
| ALD110800ASCL | SO16 | 4xN | 10,6 | 0,012 | 500 | 10,6 | 0,02 | | ALD | Precision matched pairs, zero Vgs.th |
| TPIC2603DW | SO24W | 6xN | 60 | 0,35 | | | | | TI | A whole array of 2N7002 |
| IRLHS2242TRPBF | PQFN2x2 | P | -30 | -8,5 | 0,031 | | | | IR | Tiny crazy amps P-type, hard to solder |
| IRFHM830TRPBF | PQFN3x3 | N | 30 | 21 | 0,0038 | | | | IR | Low Rds.on power gate |
| IRFHM4234TRPBF | PQFN3x3 | N | 25 | 20 | | | | | IR | Low Rds.on power gate |
| IRFHM8326TRPBF | PQFN3x3 | N | 30 | 19 | 0,0047 | 20 | 1,7 | | IR | Low Rds.on power gate |
| IRFLHM620TRPBF | PQFN3x3 | N | 20 | 40 | 0,0025 | 12 | 0,8 | | IR | Low Rds.on power gate, very low Vgs.th |
| SI7615ADN-T1-GE3 | PQFN3x3 | P | -20 | -35 | 0,0044 | 12 | -1,5 | | VISHAY | Low Rds.on power gate |
| DMN1004UFV-7 | PQFN3x3 | P | -12 | -70 | 0,0038 | 8 | -1 | | DIODES | Low Rds.on power gate, very low Vgs.th |
| IRFH8318TRPBF | PQFN5x6 | N | 30 | 50 | 0,0031 | 20 | 1,8 | | Infineon | Crazy low Rds.on power gate / Li-Ion protection |
| IRFH4201TRPBF | PQFN5x6 | N | 25 | 100 | 0,00095 | 20 | 1,6 | | Infineon | Crazy low Rds.on power gate / Li-Ion protection |
| IRFH9310TRPBF | PQFN5x6 | P | -30 | 21 | 0,0046 | 20 | 1,9 | | Infineon | Crazy low Rds.on power gate / Li-Ion protection |
| BS170 | TO-92 | N | 60 | 0,5 | 1,2 | 20 | 2,1 | | FAIR | Corrected: 2N7000 equivalent |
| 2N7000 | TO-92 | N | 60 | 0,2 | 1,2 | 20 | 2,1 | | ST | 2N7002 but TO92 |
| ZVP2106A | TO-92/E-Line-3 | P | -60 | -0,28 | | | | | DIODES | 2N7000 but P-type |
| IRLR7843PBF | DPAK | N | 30 | 161 | 0,0033 | 20 | 2,3 | | IR | Low Rds.on power gate |
| IRLR8113PBF | DPAK | N | 30 | 94 | 0,006 | 20 | | | IR | Low Rds.on power gate |
| IRLR8721PBF | DPAK | N | 30 | 66 | 0,0084 | 20 | | | IR | Low Rds.on power gate |
| IRLR2905TRPBF | DPAK | N | 55 | 36 | | | | | Infineon | Low Rds.on power gate |
| IRLR3110ZPBF | DPAK | N | 100 | 63 | | | | | IR | 100V+Vds, top amps |
| IRFR4620PBF | DPAK | N | 200 | 24 | | | | | Infineon | 100V+Vds, top amps |
| IRFR4615PBF | DPAK | N | 150 | 33 | | | | | Infineon | 100V+Vds, top amps |
| IRLR9343PBF | DPAK | P | -55 | -20 | 0,093 | 20 | -1 | | IR | Ideal diode, power input gate |
| IRFR5305TRPBF | DPAK | P | -55 | -31 | 0,065 | | | | Infineon | Ideal diode, power input gate |
| FDD6637 | DPAK | P | -35 | -55 | 0,0116 | 25 | -1,6 | | FAIR | Ideal diode, power input gate |
| IRL3102S | D2PAK | N | 20 | 61 | | | | | IR | Some low voltage good amps D2PAK |
| IRF530NSPBF | D2PAK | N | 100 | 17 | 0,09 | 20 | 4 | | IR | 100V+ but poor amps |
| IRL520NPBF | TO-220AB | N | 100 | 10 | | | | | IR | 100V+ but poor amps |
| IRL3102PBF | TO-220AB | N | 30 | 55 | 0,019 | 16 | 1 | | IR | Nice low voltage good amps N-type |
| IRLB8743PBF | TO-220AB | N | 30 | 150 | | | | | Infineon | Crazy amps 30V N-type |
| IRL1004 | TO-220AB | N | 40 | 130 | | | | | Infineon | Crazy amps 30V N-type |
| IRFZ44ZPBF | TO-220AB | N | 55 | 49 | | | | | IR | Jellybean TO-220 |
| IRFZ44NPBF | TO-220AB | N | 55 | 49 | 0,0175 | 20 | 4 | | IR | Some 30+V 40+A N-type |
| IRF3205ZPBF | TO-220AB | N | 55 | 75 | 0,0065 | | | | IR | A bunch of 60V TO-220 with top amps |
| IRL3705ZPBF | TO-220AB | N | 55 | 86 | | | | | Infineon | A bunch of 60V TO-220 with top amps |
| IRFB3806PBF | TO-220AB | N | 60 | 43 | | | | | | A bunch of 60V TO-220 with top amps |
| IRFB7546PBF | TO-220AB | N | 60 | 75 | 0,0073 | | | | IR | A bunch of 60V TO-220 with top amps |
| IRF1018EPBF | TO-220AB | N | 60 | 79 | 0,0071 | | | | IR | A bunch of 60V TO-220 with top amps |
| IRFB7545PBF | TO-220AB | N | 60 | 95 | 0,0059 | | | | IR | A bunch of 60V TO-220 with top amps |
| IRFB7540PBF | TO-220AB | N | 60 | 110 | 0,0051 | | | | IR | Crazy amps 60V N-type |
| IRFB7537PBF | TO-220AB | N | 60 | 173 | 0,0033 | | | | IR | Crazy amps 60V N-type |
| IRFB7787PBF | TO-220AB | N | 75 | 83 | 0,008 | | | | IR | A bit of Vds/Id tradeoff |
| IRL540NPBF | TO-220AB | N | 100 | 36 | | | | | Infineon | 100V+ but whole 36A |
| IRF3205PBF | TO-220AB | N | 55 | 110 | 0,008 | 20 | 4 | | IR | Crazy amps 50V N-type |
| IRF4905PBF | TO-220AB | P | -55 | -74 | 0,02 | | | | IR | Ideal diode, power input gate |
| AUIRF4905 | TO-220AB | P | -55 | -74 | 0,02 | | | | IR | Ideal diode, power input gate |
| IRF9530NPBF | TO-220AB | P | -100 | -14 | | | | | IR | Ideal diode, power input gate |
| FDPF12N60NZ (FQPF12N60C) | TO-220FP | N | 600 | 12 | | | | | ONS | SMPS stuff |
| IRFP7718PBF | TO-247AC | N | 75 | 195 | 0,0018 | | | | Infineon | Electronic Load |
| IRFP4368PBF | TO-247AC | N | 75 | 195 | | | | | Infineon | Electronic Load |
| IRFP250MPBF | TO-247AC | N | 200 | 30 | | | | | IR | SMPS/welder stuff |
| IRFP4868PBF | TO-247AC | N | 300 | 70 | | | | | IR | SMPS/welder stuff |
| IRFP460PBF | TO-247AC | N | 500 | 20 | | | | | VISHAY/IR | SMPS/welder stuff |
| IPW60R045CP | TO-247AC | N | 600 | 45 | | | | | Infineon | SMPS/welder stuff |
| STW60N65M5 | TO-247AC | N | 650 | 46 | | | | | ST | SMPS/welder stuff |
