Willing to discuss the VFLEX design more, as already mentioned, VBUS is a straight passthrough from the USB connector to the output contact. This is also done in 2oz copper. I've run tests running at 5A continuous and there is just a modest temp rise. Most of the heat generated comes from the USB-C cable that is connected to VFLEX. In the end, with a good quality cable, there is about a 30 deg F temp rise when running continuously at 5A.
Regarding protection, the supplies provide this. A series switch inline or other protection there would be a lot of added physical space, cost and much more heat generated in the normal use case. In the end it just did not seem practically necessary. Just like any power supply, that you plug into something, there are risks involved.
The statement about the reverting to 12V when targeting 19V, I don't think that this is an action taken by the supply, it could have been a feature of that particular trigger chip. For VFLEX, if it cannot achieve the target voltage, it will always revert back to 5V and show the LED.
We also independently monitor the voltage with on chip ADC so if you see a green LED it means that negotiation was successful AND that the ADC measures a voltage that is within tolerance.
There are 3 failure states:
Solid Red LED = Negotiation success but ADC voltage out of range
On / Off Red Blink in 1s interval = Negotiation not successful
Fast Blink RED = eMarker Cable error
Especially for voltages over 20V, the supplies also enforce a cable check so you need to consider compatibility of the cable that you are using as well. VFLEX tries its best to distinguish those types of error.
Really enjoyed the video and happy to answer any questions that people may have!
