Author Topic: EEVblog #197 -- uCurrent failed units  (Read 2252 times)
Offline ejeffrey
« on: August 18, 2011, 08:45:59 pm »
Dave,
I wonder if you did a post-mortem on the uCurrent units which failed testing?  Was the problem out of spec parts, damage during assembly, or a conspiracy of worst-case component errors?
Offline Kiriakos-GR
  • Country: gr
  • User is banned.
    • Honda AX-1 rebuild
Re: EEVblog #197 -- uCurrent failed units
« Reply #1 on: August 19, 2011, 12:27:40 am »
Link ...  :)
Offline Zad
    • Digital Wizardry, Analogue Alchemy, Software Sorcery
« Reply #2 on: August 19, 2011, 04:25:29 am »
Fault finding would probably make quite a good Raw video! In this instance I suspect they are just slightly out of tolerance components that are conspiring against you.
Offline Elandril
« Reply #3 on: August 21, 2011, 07:17:47 am »
I'd second that!
I'd love to see a fault finding episode for those uCurrents!
