Author Topic: EEVblog #284 - Braun Toothbrush Teardown  (Read 25799 times)
Offline amyk
Re: EEVblog #284 - Braun Toothbrush Teardown
« Reply #25 on: June 02, 2012, 11:32:10 am »
Yeah, there was a bit of crud around the bottom of the brush. But I guess the only way they could make it absolutely watertight is to seal the case completely in wich case you could not replace the battery. The electronics in Dave's brush still work so it doesn't seem to be a big problem.
The moisture comes in from the top, where the shaft meets the housing it doesn't seal well. My ideal design would be a brushless motor with a rotor in the wet part and the stator inside the housing (which would not need a hole into the interior), like those used in aquarium pumps. The downside is that it requires more power and control electronics than a regular brushed DC motor. Sealing the bottom and buttons isn't difficult even with replaceable batteries, since they make waterproof torches in the same form factor with an o-ring and threaded cap.
Offline madworm
« Reply #26 on: June 02, 2012, 11:55:52 am »
Perfectly sealed toothbrush units... that's never going to happen.
Less opportunity to rip off the consumer, just like with inkjet printers that "suddenly" require maintenance because some nefarious droplet counter has reached its maximum value.
The sponge used for head cleaning might be full and overflow.
The "service" costs 5x more what a new printer costs and the fact that this "error" is software resettable is kept a secret and/or the tools are not available to the end consumer.
Offline saturation
  • Doveryai, no proveryai
    • NIST
« Reply #27 on: June 05, 2012, 12:23:20 pm »
I've been using Sonicare since late 1990s, before they were bought by Phillips.  I've never had a problem with them except the batteries dying.  Its very annoying because since the discharge rate is fairly slow, the batteries can not be deep cycled or reconditioned to get them back up to speed.  So, by 2 years, you get only half the rated AH, and the battery slowly deteriorates from there.
4 years ago, Sonicare came out with the only AA powered version; sans inductive coils and batteries the thing is cheap and lightweight.
Because the motor is identical to the sealed brushes the brush power is identical, and you don't have the charging issues.  Instead, most folks don't know how to seal o ring joints properly, leading to leaks.  Its not entirely user friendly that way, because an o ring seal must be impeccably clean for it to be watertight, else the o ring will leak where the dirt is.  That said, my brushes have served me well for over 4 years without leaking, I have 2, so that comes to nearly 8-product years of use and I submerge these brushes in 4" of water during cleaning, which is every use.
Never drop an electronic toothbrush.  They are not built with shock/vibration resilience and the extra mass of the batteries when it falls will add to the injury.  A tiny droplet size leak is an other wise water tight casing means very slow to nil drying out, and inevitable death.
Best Wishes,
 Saturation
Online vk6zgo
« Reply #28 on: March 25, 2013, 02:12:47 am »
I know this is an old thread,but I just had occasion to look at my electric toothbrush.
My daughter bought it,don't know where,it worked for about 3 minutes & stopped,never to go again.
It is a Braun,even though it also says "Oral B" on the handle.
The charger is about half the size of Dave's one
Same waveform from the charger, frequency looks to be about 25.6 kHz,but the last time the Tek 7613 was calibrated,Ronnie Reagan was in the White House!
Tried the unscrewing technique,but it just slipped around on the "peg" protruding from the charger.
Looks like it is fully sealed,so no fix,& only a fully destructive teardown possible -----bummer! >:(
Offline amyk
« Reply #29 on: March 25, 2013, 09:39:31 am »
It might just be a usual buildup of gunk around the base. They're built to be waterproof so the seal is tight even without the gunk.
Online vk6zgo
« Reply #30 on: March 25, 2013, 02:41:47 pm »
No gunk,it's virtually  brand new!
Offline Fezder
  • Lean on, or was it learn on?
« Reply #31 on: April 22, 2013, 05:00:01 pm »
just saw this video, nice! especially i liked ''scope probe-hack'' :D
Both analog/digital hobbyist, reparing stuff from time to time
Offline madires
  • A qualified hobbyist ;)
« Reply #32 on: April 22, 2013, 06:11:41 pm »
Seems to be the same model like I have (Professional 2000). Just after about 50 charge/discharge cycles the battery lasted only 4 days. At the beginning it was about 7-8 days. While searching for a way to open it (unscrewing method doesn't work) I stumbled across a recycling hint in the Japanese manual. The bottom part is fixed by a pair of snap-in thingies. You can open it by creating a torque with a large screwdriver. Afterwards it won't close as precisely as before but the sealing gasket is good enough to prevent any ingress of moisture. And it will open quite easily the next time :-) I replaced the 4/5 AA NiMH and I'm curious if the new battery will perform better than the original one after 50 cycles. 50% after 50 cycles is a bad joke! Never had such a bad rechargeable battery.
Offline AndersG
« Reply #33 on: August 08, 2019, 12:39:21 pm »
Sorry for arriving late to the party, but I took apart a Braun charger and it is indeed potted, but I managed to strip the coil and ferrite and measure dimensions:
It is wound with 0.3mm wire on a bobbin OD 17mm, ID 7mm, h 5mm. Inside the bobin, there is a ferrite dia 6mm h=18,5. Plain wire, not Litz.
I created a quick and dirty Class-e/push-pull/multivibrator and wound my own coil. Image shows my mesurement pickup coil over the transmitter coil. Works a treat. It charges one of our brushes in 45 minutes and I also tested with a discarded brush. Measured the charging current which was approx 70mA into a rather tired battery with the original charger and 100mA with mine.
806022-0
806028-1
806034-2
Now, why would anyone do such a daft thing? Well, I need a charger that runs off 12V in my boat :)
I also need to be able to turn it off after charging. The resulting output is much cleaner than the original. First overtone at 60kHz is -36dB down and second if -26dB down.
« Last Edit: August 08, 2019, 12:47:37 pm by AndersG »
Offline Gyro
« Reply #34 on: February 06, 2021, 06:29:16 pm »
A bit of a blast from the past, but I don't think Dave ever managed to complete this teardown due to the charging base being potted. I realised that I had a Lidl charging base for a rechargeable PIR night light / torch in my pile which isn't potted. Although the circuit may not be identical, it shares the same centre spigot arrangement, so it is likely that the coupling coil / inductor is similar.
In the Lidl torch, the coupling receiver is an identically sized inductor, but with a smaller number of turns of thicker gauge wire, as would be expected. I tested it with an old Braun toothbrush, with its larger diameter air cored coil, and the charging performance seems to be the same, so it's likely that it is a similar circuit.
The charging base uses a single transistor oscillator with a capacitive mains dropper. It's likely that the supply voltage to the oscillator varies quite a bit depending on the magnetic loading, the reservoir capacitor is rated at 400V and the transistor has a VCEO of 450V. It's a bit surprising that such a simple circuit can tolerate such a wide load range without running into problems. Operating frequency is 143kHz off load and 166kHz on load (Braun toothbrush). The waveform seems fairly clean with some flattening at the base of the sine wave.
Anyway, the schematic and teardown photos are attached. I included most of the component values - it didn't seem worth desoldering the MLCCs at I'm thinking of using it as part of a high isolation PSU converter (https://www.eevblog.com/forum/metrology/power-supply-for-voltage-references/msg3398466/#msg3398466). I did note that the mains caps (and specifically C8) are not X rated, but at least look to be reasonable quality and are down-stream of a low current fuse. C8 also lacks a discharge resistor, relying on to current drain of the oscillator to bleed off its residual charge.
Hopefully of interest to someone.
EDIT:  Just looking back again at Dave's video, I noticed that the charging waveform on his Braun base was at significantly lower frequency, around 22kHz and with significant ringing. Maybe the higher operating frequency of the Lidl base accounts for the lack of observed ringing.
« Last Edit: February 06, 2021, 06:47:59 pm by Gyro »
Best Regards, Chris
Offline Marty1
« Reply #35 on: December 05, 2022, 09:16:17 am »
Also sorry for arriving late, but this breakdown was the best, that I could find, but leaves me with some questions, that you might easily know the answer to.
IHAQ: Does charging of the internal NiHM battery terminate when it is full or does it charge for a fixed amount of time?
My findings and the reason for asking:
I'm using my third Braun-Oral-B electronic toothbrush since 2017 now. They were all of the type: 4729 (Oral-B PRO 600) with charger type 3757. They tend to last for 2 years and 10 months. Then the internal NiMH battery life gets so bad, that it's annoying.
After about 300 charge cycles the NiMH battery (a 4/5 AA Sanyo ) has degraded for about 60%.
The 4729 toothbrush always charges for 18 hours indifferently from when its battery was new versus now that the battery is old and degraded. It's the time that the green charging light keeps blinking for and then stops.
The old battery now has less than half the run time (9 minutes) versus when it was new (27:30 min).
Because the now wearing battery can hold less charge, it should be charged lesser/shorter. Otherwise it will overcharge and and overcharging degrades the internal NiMH battery even faster.
Question 1:
Will charging be automatically terminated when the battery is filled, or will it bluntly charge for a fixed 18 hours. Thereby overcharging the now aging battery and wear it out at an ever faster rate?
Question 2:
Because I don't want to buy a new tooth brush every 2 years, I now want to replace and upgrade its battery.
When I would upgrade from the standard 1400 mAh battery to a 2450 mAh  AA sized NiMH battery, will the standard 18 hours charge time be sufficient to load the new battery completely? Will charge termination take place when the battery is full? Or can I better opt for a 1900 mAh one that can take twice the abuse due to overcharging, but has a shorter run time?
Offline madires
« Reply #36 on: December 05, 2022, 03:42:31 pm »
From my experience the Oral-B toothbrushes seem to have a standard charge control. Going for more mAh should work fine. BTW, I've switched to a LiIon model and I'm happy with it so far.
Offline Marty1
« Reply #37 on: December 07, 2022, 10:53:39 am »
Thanks for your reply. What I'm trying to determine is if the Pro 600 (type: 4729), will keep receiving a charging feed, even when the (already for 50% deteriorated) battery is full?
I'm under the impression that it keeps receiving a charge feed, because the greenly blinking indicator light keeps blinking for 18 hours. It did that when it was new, and now that it has a 50% deteriorated battery, the charging light still keeps blinking for 18 hours when charging.
Offline madires
« Reply #38 on: December 07, 2022, 11:04:36 am »
IIRC, my old NiMH Oral-Bs charged for about 15h.
Offline Marty1
« Reply #39 on: December 07, 2022, 06:23:43 pm »
If there is a charge controller active, then it should terminate charging, when the battery is full.
This is not what I observed. When the battery was new it charged for 18 hours and now that the battery can hold only 50% of its capacity, it is still is being charged for 18 hours.
Then I conclude that there is no charging controller active. Otherwise the 18 hours of charging when the battery was new should be halfed to 9 hours now that the battery lost 50% of its capacity.
The NiMH battery will therefore be overcharged for the remaining 9 hours. Because of over charging the battery will be damaged and loose its remaining capacity in an ever increasing rate.
Can anybody confirm this?
A lifetime of 300 charge cycles for a Sanyo 1400 mAh NiMH battery seem kind of short to me. When overcharging on a regular basis occurs, then that would explain it.
Offline Marty1
« Reply #40 on: December 11, 2022, 09:09:48 pm »
The information I'm looking for can't be found, so I devised the following experiment in order to gather new information.
The hypothesis, is that the toothbrush is being overcharged, which wears out the battery at en ever increasing rate.
I halved the charge time of the brush and measured how long it would run for.
Low and behold, the runtime was the same with half the charge time.
It charged for 9 hours ((instead of 18 hours) and pulled it off the base / charger while the green charging indicator was still blinking.
The run time that I got after that was identical to when it was charged until the automatic cut-off /  termination after 18 hours of charging (green blinking indicator light).
« Last Edit: December 12, 2022, 12:47:58 pm by Marty1 »
