Author Topic: EEVblog #330  (Read 1408 times)
Offline assafberman
EEVblog #330
« on: May 04, 2014, 11:12:39 am »
hi,
I have Medela swing,it is working but the suction is low,
How do I measure the pumping pressure?(volts)
thx assaf
Offline EEVblog
Re: EEVblog #330
« Reply #1 on: May 04, 2014, 12:58:49 pm »
you would need a pressure gauge to do that.
Offline assafberman
Re: EEVblog #330
« Reply #2 on: May 04, 2014, 02:06:59 pm »
hi
thanks for the fast respond
I know the pressure is low,(no milk suction)
how can I tell if it is the motor or the board,
Do you know what voltage the motor recives for normal work ,and where can I check i t?
thx again
assaf
