EEVblog => EEVblog Specific => Topic started by: EEVblog on August 11, 2012, 07:42:55 am
EEVblog #332 - Mantis Elite Microscope Scratch'n'Sniff (https://www.youtube.com/watch?v=PlAXAuco8gs#ws)
Dave.
From the looks of the arm, it seems like you can't move the head to all points on a plane parallel to the table without refocusing. This seems inconvenient for big boards that are clamped down for soldering.
Not in the Y-Axis, no. In the X-Axis, or an X-Axis arc, yes.
Dave.
That is a limitation of the cheaper mantis units. You basically get an arc of coverage on the bench, with only a small change in radius with up/down to focus. In practice this isn't a big problem as that thing you are looking at can be moved into the working area.
They do make some fancier arms if you really need more flexibility.
Hi Dave
Just registered as I don't know if you saw my message left on the video.
I have just released a review of the Elite and thought it might be useful to you and your followers, like me ;)
The review can be download from http://www.mediafire.com/view/?l86zku3zk5hi46x (http://www.mediafire.com/view/?l86zku3zk5hi46x)
It is 2.2Meg so I can't attach it here.
One of the other arms may be far more suitable depending on your uses. :)
regards
Trevor
Television-Magazine-Forum UK
How do you drown a blonde? Put a scratch'n'sniff sticker at the bottom of a pool.
