Author Topic: EEVblog #388 - Fake Apple USB Charger Teardown  (Read 44660 times)
Offline EEVblogTopic starter
« on: November 20, 2012, 11:36:50 am »
Dave.
Offline JoannaK
    • Diytao making blog
Re: EEVblog #388 - Fake Apple USB Charger Teardown
« Reply #1 on: November 20, 2012, 11:48:42 am »
No wonder people get killed with those cheapo powers.
Offline T4P
  • Country: sg
    • T4P
« Reply #2 on: November 20, 2012, 11:58:31 am »
No wonder most more advanced phones wouldn't accept a charge without having the UI going all wonky (Sensation and counting only my original LG Optimus would accept a charge no problem)
Even charging a portable speaker is a problem, the noise it couples through to the ground plane while my phone is plugged in makes my phone go wonky
Lack of filtering and lack of a bridge rectifier = DOUBLE TROUBLE
Offline BravoV
  • +++ ATH1
« Reply #3 on: November 20, 2012, 12:06:51 pm »
Understand you're a "pro" ranter though, but c'mon Dave, 15 minutes duration should be enough to include some quick & fast measurement say at your scope on these crap charger output to let your audience see apart from the poor build, also how bad they are at their output to give the complete story. Just a suggestion.
« Last Edit: November 20, 2012, 12:08:36 pm by BravoV »
Online mariush
« Reply #4 on: November 20, 2012, 12:12:45 pm »
I agree. I frowned the moment i saw the video is only 16 minutes, I knew it was rushed.  Would have loved to see something similar to Mike's teardown, where he put some load and showed voltage dropping just from the length of the cables, not to mention the load amount... and heat going up in those transistors.
Offline Sionyn
« Reply #5 on: November 20, 2012, 12:25:59 pm »
i would trust it any further than i could shove it up the designers arse
they do indeed kill this woman bought a gameboy charger for her son which killed him
http://www.destructoid.com/young-boy-dies-from-gameboy-charger-29079.phtml
eecs guy
« Reply #6 on: November 20, 2012, 12:26:54 pm »
Sorry, I didn't have time to do it.
There is always the opportunity for another video you know, it's not the end of the world...
Dave.
Offline Sionyn
« Reply #7 on: November 20, 2012, 12:31:26 pm »
it could be the end of the world, if you bought those apple chargers
eecs guy
Online tom66
« Reply #8 on: November 20, 2012, 12:49:44 pm »
One thing -- that 4R7 resistor probably ties into the base of that NPN through another resistor.
It's a ringing choke converter (two-transistor) and when well designed they can be a low cost alternative, unfortunately in most cases the cost cutting means they often fail. They are suitable for things like LEDs, but not suitable for delicate electronics. And by the time you've designed a really reliable one... you may as well just use a controller IC.
Offline andersm
« Reply #9 on: November 20, 2012, 02:16:42 pm »
Do the AC prongs come off these clone chargers just by tugging, like early Apple ones and other cheap clones?
Offline G7PSK
  • It is hot until proved not.
« Reply #10 on: November 20, 2012, 03:08:10 pm »
It is obvious that the small creepage distance is the one hung lo version of a safety device, get the distance small enough so that if you get a power surge it flashes over, saves on a spark gap. >:D
Offline Winston
    • IC Die Photography
« Reply #11 on: November 20, 2012, 03:08:55 pm »
Before you tore them down, I noted that even the "better" charger had to be a fake.  Note the wording of the CAUTION message.  They omitted the "mation" portion of "infor-mation."  At least the worse looking charger got it more correct, but they still didn't use a hyphen as they should have to split "infor" and "mation," probably because they incorrectly perceived them as two different words.
Offline amyk
« Reply #12 on: November 20, 2012, 06:04:51 pm »
From that article:
Hotel management believes the young boy had just come from the pool and while still wet he touched the charger, which caused him to receive a lethal shock from the unit.
How many documented instances of lethal injury have occurred from these cheap chargers, relative to how many are in use? I'd think the actual (vs. perceived) risk is a lot lower than the big companies etc. would want you to think... and lots of people seem to have no trouble with getting around using one of the most dangerous means of transport.
The problem seems to be that these things are either ultra-cheap or ultra-expensive; there's nothing in between, and so tons of people are willing to take the risk.
The lack of a fuse/fusible resistor does scare me a bit, however.
Offline G7PSK
« Reply #13 on: November 20, 2012, 06:10:28 pm »
A hyphen in information would also ring alarm bells.
Offline DavidDLC
« Reply #14 on: November 20, 2012, 06:13:46 pm »
Dave.
Do it before Dec 21th 2012 !!!!
David.
« Reply #15 on: November 20, 2012, 09:14:32 pm »
OH SHIT!!!  :o
Dave.
Offline PChi
« Reply #16 on: November 20, 2012, 09:30:40 pm »
Thanks for the tear down.
Definitely a 'Don't turn it on take it apart' (then throw it away). A fire and electrocution hazard.
Offline Bored@Work
« Reply #17 on: November 20, 2012, 09:34:11 pm »
Who knows?
But something else is apparent. A local newspaper recently published the first preliminary statistics for 2012 regarding causes of fires in this area, based on data collected by the fire brigades and inspector. We have an almost 10% year over year increase in fires caused by electrical appliances of all kinds. A trend continuing from previous years.
From that you can say there is certainly coming a lot of dangerous crap from China, and it is not harmless.
And ultra-expensive doesn't guarantee quality. You might still get crap. It could be genuine crap or counterfeit crap, but just because it is expensive doesn't mean you won't get crap.
Online tom66
« Reply #18 on: November 20, 2012, 09:40:48 pm »
If I need a cheap USB supply, I'll buy something like a used charger for an Android phone. HTC one for example is available for about £3.
I'm sure it's possible to produce something low cost and reliable -- problem is, it's hard to compete with "absolute cheapest".
Offline T4P
  • Country: sg
    • T4P
« Reply #19 on: November 20, 2012, 09:44:48 pm »
Like the apple one, still a crap charger by any standards just look at the SAMXON caps! Bound to fail!
That thing just terrifies me, well, it costs 30$
If i wanted a USB supply a HTC one is excellent as well as a LG one that i use to charge my HTC (Uhuh ... yeah)
Online tom66
« Reply #20 on: November 20, 2012, 11:34:47 pm »
Apple's new iMacs have been seen with Taicon! and Ltec!!! Both have been seen failing in large numbers. Profit-squeezing bastards...
Offline TriodeTiger
« Reply #21 on: November 21, 2012, 12:01:02 am »
It's just a teardown! Without even thinking hard I can envision in my crystal brain: 1V+pp ripple, kHz+ noise, volts dropping 1% per mA ::)
I see a theme of impatience sometimes, "Dave do this! this!", I assume this is good as it'll spawn people wanting to actually make blogs about that stuff when Dave can't do "everything". He's just a guy with a scope ok...more like 20.
"Yes, I have deliberately traded off robustness for the sake of having knobs." - Dave Jones.
Offline FenderBender
    • The Solid State Workshop
« Reply #22 on: November 21, 2012, 12:03:11 am »
I don't understand..How much more would it cost for 3 more bloody diodes?
Offline Sionyn
« Reply #23 on: November 21, 2012, 12:04:14 am »
here the full story from a bbc program about the fake gameboy charger
https://www.youtube.com/watch?feature=player_detailpage&v=9BZPadQuC8c#t=107s
eecs guy
Offline kaindub
« Reply #24 on: November 21, 2012, 03:05:24 am »
One charger has Australian pins, so I assume its targeted at Australia.
It fails because Australian market plugs need to have a plastic ring about 50mm diameter around the pins
Its to stop fingers going behind the plug and touching the pins when its plugged in.
Offline iloveelectronics
  • Country: hk
« Reply #25 on: November 21, 2012, 03:22:41 am »
It's more likely targeted for the China market. Chinese plugs/sockets have the same layout as the Australian's.
My email address: franky @ 99centHobbies . com
My eBay store: http://stores.ebay.com/99centhobbies
« Reply #26 on: November 21, 2012, 04:26:37 am »
That's my world!  ::)
http://theoatmeal.com/comics/making_things
I don't mind people suggesting things for future videos, e.g. "I'd love to see some load measurements of this in another video"
But it can be quite disheartening when you continually get comments the likes of "I'm disappointed in this video, I expected this and that, why didn't you do this" etc, and they thumb it down just because you didn't do something they wanted.
That's the kind of stuff that leads to a "PhotonicInduction"  :o
Dave.
Online Monkeh
« Reply #27 on: November 21, 2012, 04:28:27 am »
You're many things, Dave, but you're not a drama queen on his level. ;)
Offline IanB
« Reply #28 on: November 21, 2012, 04:53:18 am »
Neither of the chargers in the video was an Apple charger. Both were fakes and neither cost anything near $30.
You can see if you follow the link in the description that the genuine iPhone charger has a different and very sophisticated design with many clever features.
Offline BravoV
  • +++ ATH1
« Reply #29 on: November 21, 2012, 08:21:04 am »
Growing thicker skin is part of basic requirements in this kind of biz, other wise you've taken the wrong decision in your career. The bigger audiences you have, the thicker you need to grow it.
Also sometimes swallowing a bit of own pride and the bitterness of criticisms (especially the constructive ones), is like having a smack at the head for a wake up call from complacency.
Offline T4P
  • Country: sg
    • T4P
« Reply #30 on: November 21, 2012, 08:28:18 am »
I was looking at the teardown of the real one. That one has a badcap right where it matters the most, output!
Offline G7PSK
« Reply #31 on: November 21, 2012, 09:18:39 am »
Here is a link to a very detailed tear down that I found on the web.
This is genuine Apple power supply that is dissected.
http://www.arcfn.com/2012/05/apple-iphone-charger-teardown-quality.html
Offline jeroen74
« Reply #32 on: November 21, 2012, 11:26:42 am »
That's the same page as in the blog post ;)
Uncle Vernon
  • Guest
« Reply #33 on: November 21, 2012, 11:08:41 pm »
From that?
So you have surmised that it only cheap & nasty Chinese product that causes fire from that? I call flawed assumption!
Where is your evidence that all these faulty plug-packs etc, are of Chinese origin? How do you support your inference that Chinese manufacture equals cheap & nasty. You prime source of statistics being some "Local Newspaper", authoritative stuff that! Why not switch on some tabloid television too, they run this kind of crap at least monthly. Who needs standards and test labs when we have cadet journalists right?
You need to think back to this quote from Monty Python which demonstrates the absence of wisdom in your wild assumptions.
"Fish live in the sea!" "Carp are fish!" "Therefore all fish are carp!"
Sure there is a lot of rubbish coming out of China, as well as some quality product. This is a fact which prevails throughout most of Asia. Once again you are putting Xenophobia before fact or reason!
"Made in China" does not instantly signify quality nor does it automatically equal death-trap. Lets face it if you were to solely rely on product from your own land, the technical pinnacle for most, would be the Austin Allegro and the open wire kettle. Safety plus, indeed!
« Last Edit: November 21, 2012, 11:30:19 pm by Uncle Vernon »
Offline Dread
« Reply #34 on: November 23, 2012, 12:05:51 am »
Hi Dave
Thanks for the video, it was entertaining but like many other viewers I wish you had shown a true side by side comparison with Scopes/Load/Multimeter etc. of the Cheapo vs the real thing.
If you are going to do a new video let me just add a few suggestions that will make it even more useful.
Have a real one on Hand |O
And here is something you might want to let the viewers know:
If a person wants to know if they have a real one versus a knock off I know a few methods that anyone can try. I will list them from the least reliable to the Most.
1) The Label Info
2) The Balancing trick, the real one can stand up on its plug connectors with ease when put on a level table.   The Fake ones are almost impossible to make them stand up. Sometimes it can be done but it takes many tries, while the real Apple ones do it on almost the first try every time.
3) The Weight:  A real charger weighs 23.07 Grams and the Fake ones vary all over the place.  I have one of the Cheapos that is exactly the same one you used in the video marked “made by Apple”, it weighs 19.56 Grams.   If you don't have access to a precision scale just pop by your local Pharmacy or Jewelry Store and explain that your trying to find out if you bought a real one or Fake and they will almost certainly weigh it for you.
4) Connect it to a scope and the real one has almost no ripple or noise, the fake has a nice big layer of noise.
5) Connect a Load and the real one will go up to 1100ma and maintain aprox 5V but the fake ones tend to drop off between 300ma and 500ma of load depending on the AC supply.  At 110V they only go up to 300-400ma and 220V gets you 450ma to 600ma before the voltage starts to plunge.
Those are the five best tests to know the real from fake (apart from opening and ruining the unit).
For people who don't have any electronics background or equipment the best test is number 3.  Almost all the fakes vary from Apples standard 23g weight and it's pretty easy to get it measured precisely.
Robert
« Last Edit: November 23, 2012, 12:26:49 am by Dread »
The Optimist says the glass is half full, the Pessimist says its half empty, an engineer only see's a glass that’s twice as big as it needs to be!
Offline timelessbeing
« Reply #35 on: November 23, 2012, 05:40:32 am »
I must have bought the deluxe wun hung lo charger. It has FULL-wave rectification!  ;D
Offline T4P
  • Country: sg
    • T4P
« Reply #36 on: November 23, 2012, 06:01:09 am »
Looks like i got one the worst ones! It weighs 30 grams  :-DD I don't even need to plug it into a scope, my portable speaker tells the whole story!
Oh, the 30g one i got can actually charge my phone  :o
I give you : the blown up ones!
« Last Edit: November 23, 2012, 06:50:37 am by T4P »
« Reply #37 on: November 23, 2012, 06:20:38 am »
Uncle Vernon:
Of course, not every single thing made in China is crap. Nobody is retarded enough to claim that. But spare me the PC jingo. China specializes in cheap imitations. EU import statistics prove this. They even have their own term for it: Shanzhai.
Uncle Vernon
  • Guest
« Reply #38 on: November 23, 2012, 06:47:39 am »
Uncle Vernon:
Wasn't that what I had stated previously?
Oh, I wouldn't be too sure about that.
You could spare yourself lots of bother by obtaining a clue.
China produces, what its market demands, it has beaten the world in terms of low cost manufacture.
Well bully for the EU. While they've been busy creating mountains of useless statistics, pointless legislation and meaningless standards, China and India and most of Asia has been busy actually making and selling stuff!  With both the genuine item and the imitations originating in China, anyone using country of origin as a determinant of quality is making themselves look like a rank tool.
« Reply #39 on: November 23, 2012, 07:09:48 am »
Yah meaningless standards about poisonous chemicals and electrical safety regulations. Who needs their health anyway right.  ::)
Sometimes, Chinese stuff is so bad, the problem isn't that it functions poorly, it's that it doesn't stand a hope of working. I call these deliberate deceptions "pretend products".
I don't care if keep your head up yer arse, but if anything makes you look like a tool, it's your personal attacks.
Uncle Vernon
  • Guest
« Reply #40 on: November 23, 2012, 07:24:26 am »
Who needs a bunch of self important garlic eaters incapable of managing their own economies, setting standard for them?
Some Chinese stuff isn't and some Chinese stuff is of serviceable quality. You may be slow on the uptake, so I repeat again for your benefit. Country of Origin is not the sole determinant of quality or usability!
That's good, but you need to realise how much I care about, what you care about! Nof do I care about the personal insults or profanities you believe necessary to bolster your lack of reasoned or rational thought.
You're the one making the insults persomal. (see above) But if the shoe fits, and you can identify yourself within a generalised criticism then that's your issue.  I cannot help it if you choose to be thick!   8)
« Last Edit: November 23, 2012, 09:21:36 am by Uncle Vernon »
Offline BravoV
  • +++ ATH1
« Reply #41 on: November 23, 2012, 07:31:27 am »
Not sure, but if many of you think that bashing certain country, because they're producing dodgy stuff is unique and new, trust me, nothing new about this at all.
Just ask your parent or grand parents, this kind of bashing has been for ages ....
60's - Damn Japanese clone, why we still buying this shitty stuff, next time buy anything made in German .....
70's - Step over my dead body 1st before you bring those "Made in Hongkong" shit in here.....
80's - Why these days we almost bumped into these shit labelled "Made in Taiwan" or "Korea" almost every where ? ....
90's - Just couldn't stand it anymore, I want a native English staff for this telephone support call , not someone lives thousand miles away speaking English with "Indian" accent clown, anyway, these clowns are robbing "our" IT people's job as well.
2000's - ..as seen in familiar video blog  ;)  "made in German"... <two thumbs up> .......what ? made in China .... ... <thumb down> .... "damn chinese " .........  :-DD
Offline T4P
  • Country: sg
    • T4P
« Reply #42 on: November 23, 2012, 09:08:47 am »
Rigol is made in china isn't it? But they're now up there with the big names in terms of quality  ^-^
Dave noted that too  ;)
« Reply #43 on: November 23, 2012, 09:52:56 am »
When something good comes out of China, I say so. And lots of good stuff comes out of China. Every product gets judged on it's merits.
The reason I harp on about China a lot is because it's boring. I don't want everything in the world to be made in China. I want other countries to keep their manufacturing capability too. Which is why I get as much of my uCurrent made here or outside of China, and get a nice little feeling when I see something that's not made in China.
Dave.
Offline amyk
« Reply #44 on: November 23, 2012, 10:46:18 am »
Even the West was like this before. I think the Chinese would still be selling completely unisolated supplies if they could get away with it.
« Reply #45 on: November 23, 2012, 02:38:55 pm »
China is good at low cost manufacture. Depending on who makes it it can be low cost and good or low cost and junk. Plenty of labour, and a lot of it being skilled does do wonders.
« Reply #46 on: November 23, 2012, 06:25:44 pm »
I had big problems with my macbook adapter. (am currently using a cheap Chinese knockoff because I don't feel like paying $80 for a crApple one.) I just decided to look in their online store to see if they've come down in price at all.  They haven't and all their adapters have two stars or less. People hate these things!
Uncle Vernon
  • Guest
« Reply #47 on: November 23, 2012, 10:28:26 pm »
something good comes out of China" " Every product gets judged on it's merits."
That's it in a nutshell
I agree entirely. and although China (as a nation) has contributed with exchange rate manipulation,it is a world problem and a problem created by the importing countries and consumers.
There are / have been / and hopefully will be Chinese readers and participants on this and other forums. if those guys cannot cope with some Wun-Hung-Lo references that is tough, it's a big bad world no PC required. It is an entirely different matter however to see reader comments like "all Chinese are thieves", that is truly ignorant and offensive.
Having to deal with legions of buyers always trying always to drive your minuscule margins below cost would make anyone a tough negotiator and will necessitate a lot of cost and corner cutting in any design.
The reason we have retailers shelves full of Chinese made crap is because we the consumers demand it. Ask retailer how well sales will go for quality product at a 30 to 100% price premium and you soon realise what sells. It's not the fault of the Chinese or of any other low cost manufacturer.
Nice if you can do it, but hardly changing the world. While I'll commend any efforts to support local and diverse industry it remains a drop in the bucket compared to the political efforts to drive industry out of the country, to turn the place into a quarry with bike paths.
Good luck selling Aussie made plug pack supplies at under $100 and making a profit from them, it wont happen. Worker rights and environmental considerations are not part of that purchase decision. We are happy to remain oblivious to all the factors that contribute to our being able to buy junk at low low prices.
It's not China's fault it's ours!
Online tom66
« Reply #48 on: November 24, 2012, 01:07:22 am »
I agree.... but I think it may be fixable, it's just going to be painful.
Thinking about it from a purely economic standpoint: work in China is cheap because it is valued as being worth very little compared to other work. But, despite earning less than ~$15 per day average, they are able to afford rent, electricity, food, water, etc. Certainly not a premium lifestyle -- but FAR more than what $15 would purchase elsewhere.
Why is this? Perhaps because everyone is earning more the value of real work (assembly/production) has gone down to the point at which it doesn't pay enough. But I think that's only happened because we've been willing to get rid of the manufacturing base for cheaper competition overseas. If we still had that, the value of real work would increase, people would be paid more overall and yes while products would be more expensive, people would have more money to spend on them so the increase wouldn't be so noticeable. Once we have more supply, the prices will fall to the point the market will bear and at which employees will be willing to work for.
Problem is, if it were to be fixed... it would mean that we'd probably have at least a few years -- probably decades -- of economic gloom... It would have to be done very slowly. Politicians probably wouldn't support it.
« Last Edit: November 24, 2012, 01:12:59 am by tom66 »
Uncle Vernon
  • Guest
« Reply #49 on: November 24, 2012, 01:28:15 am »
Never said it wasn't fixable! Is the pain of putting things right worse than the pain of watching them deteriorate?
I don't agree it would be gloom other than for a select few, fostering real efficiency and real productivity does not have to be painful at all. Less of the nanny state and an environment where individuals can prosper from their own enterprise is all that is required.
Begs the question, why the hell are we are supporting politicians who don't!
Online tom66
« Reply #50 on: November 24, 2012, 01:41:08 am »
It seems the majority of the population don't like either of the two parties.
However, we're drawn to decide which one to vote, because they're less evil than the other party. We are constantly voting red or blue. You are either supporting the red team or blue team. Neither brings much progress, just more fighting with the other side.
Offline BravoV
  • +++ ATH1
« Reply #51 on: November 24, 2012, 08:51:29 am »
...<snip>.... a problem created by the importing countries and consumers.
...<snip>..
...<snip>..
Well said UV !  :-+
Sometimes its so funny to read people are complaining bout this thing like there is no bodies of authority at their own country say like import customs & inspection, import control and etc. Heck, its even easier to elect/vote for their own gov or political representative that will enforce a full embargo on everything produced from China if needed.  ;)
I guess all of this noises its just the matter of the need for whining.  :-DD
Online tom66
« Reply #52 on: November 24, 2012, 12:24:26 pm »
Thing is -- it's virtually impossible to avoid stuff made in China. But I do my part by rarely buying new, always buying used or faulty. My monitor (thrown out by my workplace) and computer have most parts made in China, but repaired in UK :D.
  • Country: hk
« Reply #53 on: November 24, 2012, 01:00:50 pm »
Quote from: Uncle Vernon
I am Chinese and I don't have a problem with the one hung lo references. I simply take it as a general term for the low quality low standard manufacturers which certainly are in no shortage in China.
Offline ptricks
« Reply #54 on: November 24, 2012, 02:07:20 pm »
Have you seen any changes in the labor in China ? I am wondering how the increase of jobs and people now having more money to improve their lifestyle is changing what manufacturers have to pay for labor .  As a population gains experience and knowledge it becomes harder to tell them , this is all you can get.
  • Country: hk
« Reply #55 on: November 24, 2012, 02:45:08 pm »
Well, I live in Hong Kong so I'm not entirely sure of the changes in labour in mainland China. But as far as I know wages have been increasing and margins shrinking (rather quickly) for the factory owners. Plus the Chinese currrency is slowly creeping up in value so I imagine at some point down the road Chinese products won't be as cheap as they are today. Whether that will mean a shift to a more quality centric production for a premium I'm not sure.
Offline LEECH666
« Reply #56 on: November 29, 2012, 10:54:08 pm »
FUUUUUUUUUUU----
So basically I made a follow up video trying to see how these type of junk chargers behave under load (fairly limited test with my limited equipment) but I forgot to select the right audio source on my capture tool. So I got two nice mute videos of me fiddling around on my bench. :(
Guess I have to retake the video and post it here later.
*SIIIIIGH*
« Reply #57 on: November 29, 2012, 11:08:05 pm »
Been there, done that  ;D
Or have the 3.5mm external mic plug not fully inserted and you get massive 50Hz hum over all your audio.
Why not just do a voice-over? No need to reshoot the video.
Dave.
Offline LEECH666
« Reply #58 on: November 29, 2012, 11:23:26 pm »
I was sure this has happend to you before. I don't really take videos like that that often.
Well anyway I am already done with the retake. Squeezed it into ~7 minutes. Hehe, the first time I am satisfied with the take (no editing needed).
Well I need to reencode this now and then upload it to Youtube. That might take a while.
Cheers,
Florian
Offline LEECH666
« Reply #59 on: November 29, 2012, 11:52:26 pm »
Still uploading, but here is the link anyway.
I really need to build up a dummy load soon. :S
« Reply #60 on: December 01, 2012, 08:53:47 am »
Offline LEECH666
« Reply #61 on: December 08, 2012, 07:28:11 am »
I cam across another one of these chargers. This model even has a tiny little full wave rectifier on board, but is pretty crappy as well.
Anyway, I know there is another video of Dave encountering a "ChongX" brand capacitor.
Does anyone know which video this is? I can't seem to find it anymore.
Cheers,
Florian
Online tom66
« Reply #62 on: December 09, 2012, 09:52:13 pm »
ChongX caps are pretty poor, have seen them fail in some cheapo LCD TVs...
Offline LEECH666
« Reply #63 on: December 10, 2012, 12:48:57 am »
I sometimes rewatch Daves videos just for certain comedic moments. The first "Chong" cap encounter was one of those moments for me that made laugh. That's why I asked for the video.
I remember the part in the video like this: Dave opens a device and comes across the Chong cap and says "Chong, yeah im not gonna trust that one as far as I can throw it." But I might remember it incorrectly.
It's not the charger video, so if anyone knows which video that was in, please tell me.
Cheers,
Florian
Offline bitwelder
« Reply #64 on: January 16, 2013, 05:38:07 pm »
On the same website/blog I happened to find today a nice comparison of 12 different USB chargers:
http://www.arcfn.com/2012/10/a-dozen-usb-chargers-in-lab-apple-is.html
Offline pussyfoot
« Reply #65 on: March 25, 2013, 05:41:44 pm »
After watching this video, I now know what a bad USB charger looks like. What I want to learn is what makes a GOOD usb adapter. Is there a schematic with explanation of what makes a good one?  The same would apply to a DC-DC converter for a car. I'll build my own converters if need be, but I don't want to make the same mistakes.
Offline HKJ
    • Tests
« Reply #66 on: March 25, 2013, 07:29:15 pm »
Some of the important things is a good distance between mains and low voltage side, if the PS uses a chip, instead of only a transistor, it will also be considerable better.
I did measure and disassemble on a load of them, you can see the result here: http://www.lygte-info.dk/info/usbPowerSupplyTest%20UK.html.
Offline HP-ILnerd
« Reply #67 on: March 31, 2014, 02:05:48 am »
Here's a recent injury from my neck of the woods due to a knockoff charger obtained on ebay:
http://www.myfoxtwincities.com/story/25113149/knock-off-iphone-charger-leaves-man-with-electrical-burn-infection
Offline FrankBuss
    • Frank Buss
« Reply #68 on: May 11, 2014, 01:24:57 pm »
Hackaday featured another counterfeit Apple charger teardown:
http://www.righto.com/2014/05/a-look-inside-ipad-chargers-pricey.html
Very detailed teardown, with measuring the voltage noise, unwinding the transformers and even with a die photo of some very cheap, but interesting, flyback controller IC (at the end of the article).
I wonder why there is a slot cut at one place in the fake charger, but then they ruined it at another place with just 0.6 mm gap between high and low voltage. They could have produced it even cheaper without any slot cut, with the same non-existing safety.
Offline FrankBuss
    • Frank Buss
« Reply #69 on: June 28, 2014, 01:26:42 pm »
Some information about quality Apple chargers:
http://www.apple.com/uk/support/usbadapter-european/
I have one of these chargers (I guess it was the standard model in Europe for 3 years) and I will replace it. The problem is most certainly not as worse as the problems in the fake charger, and an important difference compared to fake sellers is that Apple takes responsibility for their products and replaces it, but still not good that even original Apple chargers were unsafe.
Offline hikariuk
« Reply #70 on: June 28, 2014, 03:47:53 pm »
All of mine are the 10W modular ones you can change the connector on (A1357), which I really like because they're great for travel - you just switch the wall connector on it.
I write software.  I'd far rather be doing something else.
Offline JoeN
  • We Buy Trannies By The Truckload
« Reply #71 on: June 30, 2014, 11:10:28 pm »
This topic just resurfaced over at arduino.cc too.  It resurfaced there because of a very sad story out of Australia of a woman being electrocuted by a bad knockoff charger.  I figured it resurfaced, almost resurrected here, at the same time because of that story.  But, I don't see that story listed here so I will repost it:
http://www.dailymail.co.uk/news/article-2671493/Woman-dies-electrocuted-headphones-plugged-laptop.html
Arduino.cc post:
http://forum.arduino.cc/index.php?topic=251903.0
I hope my cheap-ass Adafruit wall warts are safe.   :-//
« Last Edit: June 30, 2014, 11:16:17 pm by JoeN »
Have You Been Triggered Today?
Offline FrankBuss
    • Frank Buss
« Reply #72 on: June 30, 2014, 11:43:38 pm »
There is already a thread about this here:
https://www.eevblog.com/forum/chat/warning-over-usb-chargers-after-woman-dies-from-apparent-electrocution/
Don't turn it on, take it apart, and post pictures :)
Offline JoeN
« Reply #73 on: July 01, 2014, 02:53:49 am »
You know what, I did my due diligence before posting that by searching for the keyword electrocution in the search box (top right) and it did not come up, I guess because it is in topic title rather than the text.  I guess I should not rely on that feature, it must have been written by the intern... :--
« Last Edit: July 01, 2014, 02:56:51 am by JoeN »
Offline classical
« Reply #74 on: March 29, 2015, 05:14:58 am »
Some measurements and a teardown of a true Apple charger bought from Apple web shop:
http://lygte-info.dk/review/USBpower%20Apple%20USB%20power%20adapter%20UK.html
A very advanced and expensive design.
Btw that website contains a lot of valuable tets of USB chargers, accu chargers, accus and flashlights.
Offline leroy_is_brown
« Reply #75 on: August 18, 2017, 02:01:02 am »
Cheers,
Florian
I was watching some old videos and I remembered this thread from ages ago. I think I've come across the one you're looking for -
at about 30:10. Dave's tearing down a USB Power adapter from that came with one of those cheap pocket DSO's. I know you you mean about these moments, classic stuff.
Cheers
Lee
« Last Edit: August 18, 2017, 02:09:26 am by leroy_is_brown »
If you aren't in over your head, how do you know how tall you are?
