Hi Guys,
Has anyone had any luck using the tl866 with fujitsu flash chips? namely the MBM29DL322TE...
I have been trying for a few days now, finally stuck
Its in the supported list, and it reads ok (after re seating a few times until the checksum stays the same), saved to file, but when trying to write to new ic (tried 4 new ones) or even another used ic, it fails at 0x000000 or 0x000001.
Initially it was coming up with overcurrent protection, so I fitted a bypass switch across c22
, so I can switch as necessary.
Its an original tl866 on rev 6.16, and original adapters as it comes v3 on check.
Maybe the size, 32M, is the issue?, as I can successfully read/erase/write to a Fujitsu MBM29DL800, so the tsop 48 adapter seems good.
I'm trying to replace the ic with new, as I suspect its causing failure over time, and when reflowed the device works fine for a given amount of time before failing again.
Any help is appreciated
