Author Topic: EEVblog #411 - MiniPro TL866 Universal Programmer Review  (Read 1451840 times)
quicknick and 4 Guests are viewing this topic.
Offline FrankBuss
    • Frank Buss
Re: EEVblog #411 - MiniPro TL866 Universal Programmer Review
« Reply #1075 on: September 24, 2017, 10:40:03 am »
You may look at / try the Open Source Software:
https://github.com/radiomanV/TL866
This doesn't look like a programmer, just a program how to flash the original firmware. But it is nice to see that the schematic is included, someone could write a new firmware with it.
Offline ebastler
« Reply #1076 on: September 24, 2017, 11:11:51 am »
How about this one?
https://github.com/vdudouyt/minipro
(Never tried it; no affiliation and no endorsement...)
Offline crx991
« Reply #1077 on: September 26, 2017, 06:06:27 pm »
Hi,i'm using the programmer in a windows 7 x64 virtual machine using vmware and it works without any problem...
Maybe some problem with virtualbox?
Offline Old Don
« Reply #1078 on: September 26, 2017, 09:29:46 pm »
Programmer works in Win10 64 bit and so I believe it should work in Win7 too. Might be something in your settings and not the programmer software. Why not D/L a new copy of the Windows programmer driver software and reinstall it.
« Last Edit: September 27, 2017, 11:15:52 am by Old Don »
Retired - Formerly: Navy ET, University of Buffalo Electronic Tech, Field Engineer and former laptop repair business owner
Offline .::Rizwan::.
  • Country: pk
  • Knowledge=>Power
    • The Unlocker
« Reply #1079 on: September 27, 2017, 12:16:12 am »
Hi,i'm using the programmer in a windows 10 x64 VM on a MacBook Pro using Parallels and it works great...
One Machine can do the work of 50 Ordinary Men,
No Machine can do the work of One Extraordinary Man.
Offline ketimoi
« Reply #1080 on: October 04, 2017, 03:14:20 am »
Yes, I am doing same and working perfectly. However recently, I have created a multimeter blog https://bestmultimeterreviews.org/. I am trying to write multimeter review and how mulitmeter works. I need some feedback from you guys.
« Last Edit: October 18, 2017, 04:10:18 am by ketimoi »
Offline FrankBuss
    • Frank Buss
« Reply #1081 on: October 04, 2017, 05:16:14 pm »
I tried it again and now it works. Host system: Debian 64 bit, VM: Oracle VirtualBox 5.0.40 r115130, guest system: Windows 7, 64 bit and later tested with Windows 10, 64 bit. I guess the USB stack somewhere got confused when I updated the firmware and the host system needed a reboot, which I don't do often since I use Linux as my main system.
Offline Old Don
« Reply #1082 on: October 05, 2017, 04:26:39 pm »
Glad you got it working.  :-+
Offline ElektroQuark
    • ElektroQuark
« Reply #1083 on: October 05, 2017, 06:20:56 pm »
You are looking for THIS.
Offline SergMM
  • Country: ru
« Reply #1084 on: October 13, 2017, 03:16:30 am »
Hello everybody.
Now beta testing of the Android shell for the programmer TL866.
A video with a brief overview of working with soft WizardProg Mobile.
Write feedback, now you can affect how the program will look and work.
https://play.google.com/apps/testing/com.wizardprog.mobile
TL866 has become unique, it works in both Windows and Android.
Offline BravoV
  • +++ ATH1
« Reply #1085 on: October 13, 2017, 04:59:27 am »
Hello everybody.
Interesting, thanks for the update.
    • ElektroQuark
« Reply #1086 on: October 13, 2017, 06:48:32 am »
Impressive.  :-+
Offline ealex
« Reply #1087 on: October 13, 2017, 07:35:32 am »
that's great  :-+
Offline bitseeker
« Reply #1088 on: October 13, 2017, 09:00:49 pm »
Hello everybody.
That's very cool. Another good project for old Android phones -- make a standalone TL866.
The following users thanked this post: Old Don
Offline kd6aaj
« Reply #1089 on: October 19, 2017, 03:18:31 am »
Google Play says my Android phone (Alcatel One Touch Evolve 2) is not supported. Oh well. Great looking project though!  :-+  :clap:
Offline kd6aaj
« Reply #1090 on: October 19, 2017, 03:53:54 am »
Thanks Radioman and everyone else here who have contributed to this forum.
I just got the MiniPro TL866CS off Amazon, and it looks good so far. It works fine on my desktop pc running Windows 7
The only issue I have is probably "DotNet" related, but I am not sure. Other software (Autodesk, and some others) have the same error caused by the type of installation inf file used or the setup file itself.
I can't install the USB driver on either of my 2 WinXP laptops. The programmer software installs, it thinks it installed the USB driver, but after I connect the TL866CS to the cable when instructed to, the "Found New Hardware Wizard" retrieves the device name (MiniPro TL-866 Programmer" then "MiniProWdf".
After a while of the red light staying solid and yellow flashing, the wdfcoinstaller runs from the .inf file and I get an error from the "Found New Hardware Wizard" window saying something about "no signature found". Screenshot attached:
Anyone else have this problem? Any solutions? Thanks.
Offline kd6aaj
« Reply #1091 on: October 20, 2017, 05:15:59 am »
Well, I ran the separate driver installer in the DRV folder, and it says the driver is unsigned, that's why it won't install on my XP machines. Certificate expired in 2012.
I will just try to find some older sw version to try with XP.
Offline BrianG61UK
« Reply #1092 on: October 20, 2017, 07:09:54 am »
Why is your XP machine not just asking you if you're okay with installing an unsigned driver?
Sent from my SM-N9005 using Tapatalk
Offline kd6aaj
« Reply #1093 on: October 20, 2017, 05:18:23 pm »
It did ask, I told it to install anyway. Then it fails. I will get a new screen shot. If I can find a different driver install or xp registry file to import, that would be great....
Offline kd6aaj
« Reply #1094 on: October 20, 2017, 08:53:38 pm »
Screenshots. Incidently, MiniProWDF.sys in the DRV folder has no digital certificate, but the one in DRV\WIN64 is signed. I tried both, no luck in XP.
Offline Willem52
« Reply #1095 on: October 21, 2017, 08:05:41 am »
Sorry, but Windows XP 64bit is known to have issues like this.
If you have access to another system with a newer Windows of even Windows XP 32bit, try it again.
Offline kd6aaj
« Reply #1096 on: October 21, 2017, 06:51:46 pm »
My laptops are only 32 bit. I was ust saying the 64 bit file is signed so it installs on Win7 x64 fine, but the 32 bit one is messed up. This is version 6.6 that is current. Incidentally my CD that came with it is also version 6.6. CRC check shows identical 32 bit files (I use "Hashtab" for crc checks).
If I can find an older version with a good driver install for win32 somewhere, then I can still use the current program.
Most of the old uploads people did to rapidshare, etc, are no longer there. Maybe someone here has an older cdrom with a working win32 usb driver install?
« Last Edit: October 21, 2017, 06:55:56 pm by kd6aaj »
Offline Willem52
« Reply #1097 on: October 22, 2017, 08:00:45 am »
I should have mentioned that I have tested the current v6.60 version
on a old Windows XP SP3 laptop here. It installed and works well.
You can't use the 64bit driver on a 32bit OS version. You need to use
the MiniProWDF.inf in the installed drv folder. Normally it should have
done it automagically when installing the MiniPro software.
My normal used systems are all Windows 10 64bit, but for the sake
of some awfull cases and testing purposed, I kept the old notebook.
« Last Edit: October 22, 2017, 08:20:39 am by Willem52 »
Offline kd6aaj
« Reply #1098 on: October 23, 2017, 02:42:43 am »
I only checked 64 bit folder for comparison. I ran the regular full install, tried importing the inf, tried installing certificates, nothing fixed the unsigned driver error.
It must be something I am missing, but Microsoft is silent about. Like I originally posted, other software had similar issues according to my Google searches... DotNet4 had it, I think an autocad version did as well. They said it had to do with using a devcon install with a coinstaller. Deleting temp files and the Cat2 folder didn't work.
I give up for now. Maybe I can install or remove sometyhing in Windows XP that clashes with the driver install.
Thanks for trying though: :-)
Offline Willem52
« Reply #1099 on: October 23, 2017, 07:35:11 am »
OK, I Google-searched for this phenomena and found this:
(use Methode 5 for Windows XP)
https://support.hidemyass.com/hc/en-us/articles/202723596-How-to-disable-Driver-Signing-check-on-Windows
