Author Topic: EEVblog #468 - Uni-T UT513 Insulation Resistance Meter Teardown  (Read 32049 times)
Offline larry42
Re: EEVblog #468 - Uni-T UT513 Insulation Resistance Meter Teardown
« Reply #50 on: May 17, 2013, 10:59:52 am »
My UNI-T UT502 always has voltage on the output connection - regardless of the "TEST" button. Which is not good on a 2500V tester (Have to switch to DCV to prevent getting shocked). Anyone got a schematic for me to try and fix this UNI-T P.O.S.?
Followup from myself: I had hoped that my faulty UT502 might have a similar relay that was either incorrectly wired, or the wrong "form". Unfortunately there's not safety relay in the UT502, from what I can tell.
If you have an animated GIF in your avatar or signature then I reserve the right to think you're a dolt.
Offline larry42
« Reply #51 on: May 19, 2013, 10:19:02 pm »
Just for completeness I'll mention that I fixed the UT502 - the was a solder bridge on Q4 right out the box, causing the "test" button to be ignored, and hence the HV output was always present.
The UT513 looks like has has better construction.
JuanPC
  • Guest
« Last Edit: June 19, 2013, 12:47:27 am by JuanPC »
Offline ilanko
« Reply #53 on: October 28, 2013, 02:07:13 am »
Hi Dave,
Way not blasting Fluke 87-V Digital Multimeter http://goo.gl/FKZYrL with 5k volt ?
Offline mboensel
« Reply #54 on: April 15, 2016, 11:51:08 pm »
They used a special power adapter and plug for isolation? God I hate having to keep track of those! Why couldn't they just use a little inverter to provide their own isolation to whatever adapter you use? There can't be much cost difference between the external transformer and an internal one - throw in a couple $0.03 transistors and you have yourself an inverter!
Old video and old comments, but I'm optimistic.
Could you explain what you mean by isolation? Isolation from Mains Ground?
Also Dave at 8:11 says "Linear adapter higher isolation voltage" when referring to the input. Could someone explain or point me in a direction? Thanks
