Author Topic: EEVblog #479 - Opamp Input Bias Current  (Read 26681 times)
Offline Rufus
Re: EEVblog #479 - Opamp Input Bias Current
« Reply #25 on: June 12, 2013, 09:01:40 pm »
Someone said this in the YouTube comments too, but so far, Dave has ignored this point.
You are, of course, quite correct.
Dave makes mistakes like the rest of us (on live video probably less than the rest of us would).
We should point them out but he doesn't have to fess up or apologize or anything. He isn't arguing about it which I just take as acceptance.
Offline kg4arn
« Reply #26 on: June 12, 2013, 09:16:57 pm »
but most of it flows through the lowest value ... so that portion does get amplified.
No, the "lowest value" has no voltage across it. All of the voltage is across the feedback resistor, and the input bias current flows through it.
@dtweed
Are you serious or are you mocking the video?
Offline dtweed
« Reply #27 on: June 13, 2013, 01:44:59 am »
Ordinarily, I'd agree with you. But in this case, Dave makes the error at about 20:00 in the video, and much of what follows is based on this erroneous calculation.
Also, this isn't just some hobbiest putting out random videos, this is now Dave's livelihood, and I would think he'd have a vested interested in getting the fundamentals right.
Offline dtweed
« Reply #28 on: June 13, 2013, 01:51:09 am »
@dtweed
Quite serious. As @Rufus said, you can etiher think of the current as going though the parallel resistors, and apply the gain to the resulting voltage, or you can think of it as going only though the feedback resistor -- but you can't do both.
Offline EEVblogTopic starter
« Reply #29 on: June 13, 2013, 02:04:28 am »
Yes, I goofed that up.
But it's not like I can pull the video. The best I can do is post-annotate.
« Reply #30 on: June 13, 2013, 02:11:22 am »
It is my livelihood, yes, but the videos are still "off the cuff".
I am not teaching university here, nor producing paid-for content or some course.
I shoot the video and don't review it, so unless I catch myself at the time I'll miss any errors. I try to sanity check as I edit it, and if there are any errors that's were I'll catch it. But proof checking your own stuff is useless as most will know. Then I upload and it's too late at that point.
No matter how hard I try to check for errors, they are always going to slip through. Heck, even textbooks have errors.
The fact that the errors dropped as expected during the practical measurements when dropping the resistor values probably reinforced in my mind that I made no mistakes in the theory part.
Offline xrunner
  • hp>Agilent>Keysight>???
« Reply #31 on: June 13, 2013, 02:41:48 am »
Warning - Analogy coming at full speed ...
dt - have you ever watched reality TV shows? My favs are Man vs. Wild and Survival Man. Basically they are survival experts thrown into a new environment on each show. Being experts, they can manage quite well yet, even so, they can't always be perfect in a survival setting. That's the way I look at these videos and enjoy them. It's a survival expert trying to tackle a new island or a new situation where you are running out of water. You do what you can at the moment, and later in the studio you can see how a perfect show could have been made.
But, that's not what people want to watch.  :)
« Reply #32 on: June 13, 2013, 03:13:17 am »
Perhaps I've painted myself into a corner with calling it Fundamentals Friday and people expect it to be somehow different/better fact checked to my regular content?
The analogy to a textbook highlights the difference I think. You can spend a couple of years writing an electronics textbook, check it a dozen times, have a third party technical review, and still have a dozen technical errors creep into the final print.
I conceive, shoot, build, and edit a video in less than a day with a streamlined process that has minimal checking. The odds of technical errors creeping in will always be high I'm afraid, that's just the way it is.
In the end, only a few people actually picked up on the error, out of how many, 15,000+
In this case, if the practical measurements didn't show anything to support the theory, then I would have noticed something and went back to review my theory material and likely found the error.
« Reply #33 on: June 13, 2013, 03:15:38 am »
I don't think your current measurement with the Keithley 480 was accurate. The input burden voltage of that meter is supposed to be below 200uV. While this figure is very low, it's still way more than those microvolts of error that the bias current caused in the circuit.
Sure, but it at least still showed the current to within an order, and showed it change value and go negative, which was the intent.
Offline free_electron
    • SiliconValleyGarage
« Reply #34 on: June 13, 2013, 05:14:06 am »
Theoretically yes... Measure it and you will see there is a voltage.
« Reply #35 on: June 13, 2013, 06:33:47 am »
Yes, I certainly formed the view that that was your intention.
Hmm, unfortunately it wasn't.
For any of my videos to take extra time to fact check, produce, refine, spin and release, that is time I simply do not have available.
No doubt some will say "but it doesn't take much effort", but unfortunately it does. And errors will still creep through.
I doubt there is a single technical video I have done that doesn't has some form of error or slip of the tongue/brain fart etc in it.
Perhaps you can make FF videos available to a selected group of volunteer reviewers (like they do with textbooks) prior to making them available to everyone on YT.
Good idea in theory, in practice probably not workable. It would lead me to having to do the usual edit/process/upload cycle, and then have to refine any errors and repeat the cycle. Ok, if they are gross errors, fine, that needs to be done. But that's also a possible slippery slope toward "perfecting" videos.
That could also involve having to go back and re-shoot scenes, keep continuity etc, days after the fact too.
And then, take the current video for example, only a few people out of 15,000+ were able to spot the error. And no one person or small select group would be able to be knowledgeable and fact check everything right on every subject. So errors would likely still slip through.
It would also lead to the inevitable ticked-off reviewer because they might come back with a bunch of suggestions on a better way to explain something etc, and then for the sake of the not "perfecting" things above, I'd have to politely decline to do/fix that. And they would get peeved and won't bother any more etc.
I can see it being a very messy business...
And with having to try and push out maybe 3 videos a week on average, it's a tough enough ask already.
« Last Edit: June 13, 2013, 06:39:33 am by EEVblog »
Offline dtweed
« Reply #36 on: June 13, 2013, 11:34:58 am »
No, not really. But I think this particualr error deserves at least one of your "post-annotations", since it keeps getting mentioned through the rest of the video.
I never really expected that your video production process would be any different for Fundamental Fridays, but I do have some expectation that you do a little more preparation before starting to shoot, including making a list of the points you intend to cover, and thinking about the sequencing of the presentation.
Overall, I think you're doing a great job!
« Reply #37 on: June 13, 2013, 11:46:05 am »
I put a little bit of thought into it, but it's still essentially press record then figure out what to say.
e.g. I don't recall exactly, but for this one I knew I wanted to structure the sequence pretty much as you see it.
eg. what is IBC, simplistic diff input circuit, a couple of problem scenarios, showing that Ib will flow through Rf in an ideal situation (not often known), and work from there to explain how complex it can get to figure it out, or that you often can't really figure it out because the specs are so wide and interacting etc.
It's often much better in my head than what eventually comes out of my mouth  ;D
Offline dtweed
« Reply #38 on: June 13, 2013, 11:51:59 am »
Any voltage you measure at the inputs is basically the result of the amplifier correcting for VOS, which is a completely separate issue (as Dave described). The effects of IOS, and IB appear only at the output, and the voltage shift at the input as a result of this would be the output shift divided by the open-loop gain of the opamp.
Offline wilheldp
« Reply #39 on: June 14, 2013, 01:50:30 am »
I saw Dave's tweet about the Owon scope video getting twice as many YouTube views as his "Fundamental Fridays" video on opamp bias current.  I'm admittedly not as up-to-date as many members of this Forum on electronics design, so I don't find in-depth design discussion or white-board diagramming very interesting.  I tend to find the "theory" videos like this one kind of dry, and they don't hold my attention as well as reviews or teardowns.  I will still watch any video that Dave produces because I like his style and find the vast majority of the videos interesting and engaging.  I'm just not a huge fan of the Fundamental Fridays series.
« Last Edit: June 14, 2013, 01:53:28 am by wilheldp »
« Reply #40 on: June 14, 2013, 02:47:38 am »
Cool, thanks for the feedback.
I guess the FF Friday videos simply aren't of much interest to those who know about the topic, or as you say, watch more for the entertainment/infotainment value (which I know is a lot of people).
The FF videos really don't have much if any of the "entertainment" aspect.
As always, it comes down the fact that not everyone is going to like every video style.
But it's not like they are not getting any views, so still very worthwhile doing, and feedback is very good.
Offline wilheldp
« Reply #41 on: June 14, 2013, 02:52:53 am »
I'll continue to watch them, Dave, and they are valuable.  But as you said, the entertainment value is fairly low.  Electronics aren't my business...just my hobby.  You will inevitably hit on a topic that will be applicable to one of my projects, so in that respect, I don't want to discourage more of the FF videos.
Keep up the good work.
Offline 3roomlab
« Reply #42 on: May 27, 2017, 08:40:33 am »
i have a noob question
when a opamp datasheet says bias is -10nA
is it trying to say current is going in or out? or it doesnt matter and we can take the value as +/-10nA?
« Reply #43 on: May 27, 2017, 11:19:32 am »
It means it will source (output) 10nA.
So if you put a 10M resistor across the input to ground you'll measure about 100mV at the input pin.
« Last Edit: May 27, 2017, 11:22:05 am by EEVblog »
The following users thanked this post: 3roomlab
Offline David Hess
  • DavidH
« Reply #44 on: May 27, 2017, 02:37:51 pm »
Unfortunately you cannot depend on the polarity specified in the datasheet meaning anything; you have to be very careful about the polarity of the input bias current specification. (1)
Datasheets for the 324 list a 50nA input bias current but datasheets for the 741 list an 80nA input bias current.  They cannot both be positive or negative because the 324 uses a PNP input stage and the 741 uses an NPN input stage.  If you want to know the direction in these cases, you have to see a schematic of the input stage.  A 301 operational amplifier is kind of like a single supply *positive* rail version of a 324 so it uses NPN input transistors but its input bias current specification is the same, just 70nA without indicating direction.
Does this ever matter?  The 741 has an NPN input stage so the input bias current goes to the negative supply.  But what about the old 4136 which was advertised as a quad "741 performance" operational amplifier?  It has a PNP input stage so the bias current goes to the positive supply.  Both datasheets just list 40nA without anything to distinguish the direction so you have to check the device schematics. (2)
There are more sophisticated ways than simple resistors to cancel input bias current.  A single transistor can be used or another of the same type of operational amplifier.  When this is done, the direction of the input bias current matters or you will end up doubling it.
(1) None of the old or new datasheets I reviewed for this post indicated the direction of the input bias current *except* when it could go either way (usually but not always do to input bias current cancellation) in which case "+/-" was included.
(2) The details are lost in the fog of time but I know some designers got caught by this when they tried to use the 4136 in an application where the direction of the input bias current mattered.  I suspect this involved external input bias current cancellation.
Offline 3roomlab
« Reply #45 on: May 27, 2017, 05:13:14 pm »
i have a nearly unrelated question about input impedance
in extremely high input impedance opamps, many have opted for "air" deadbug build as air is very high resistance (40TOhm/cm?) compared to PCB. from one of dave's vids which spoke about ohm/square resistance of copper, since we know the resistivity of FR4 (about 30G/cm?) and the thickness of FR4 (1.6mm?), that would make FR4 sit at 187GOhm/square. is my deduction of this resistance correct? (http://www.edn.com/electronics-blogs/all-aboard-/4431390/Sheet-resistance-of-copper-foil--Rule-of-Thumb--13)
(PTFE @ 1e+15Ohm/cm, would result in 6250T Ohm/square !?)
if then assuming @ 187GOhm/square, and we are mapping FR4 with blue squares (see pic). will it be right to assume that pads with long-ish footfalls adjacent to other similar pads suffer a higher leakage as more squares get to fit into the "spaces" ?
ie : 3 squares fitting between 2 pads = 187/3 = 62GOhm (what do we call this? actual creep resistance?)
so with that in mind, would it make sense to use/edit pads that will connect lesser "leaking" squares? i wonder do any PCB designer use this ohm/square method to design high resistance designs?
but strangely, does using a thinner FR4 PCB = higher resistance? ie : 0.8mm board = 375GOhm/square? (i suspect something is wrong with my fundamentals again ha !)
**update
i had a go editting the SOIC8, and was able to get 2 - 2.5 squares in series between pads (reduced pad size and staggering in and out alternate). if only i could measure how much that is ... ha! 375GOhms? 560G ? anyone want to try and measure actual creepage?
« Last Edit: May 28, 2017, 11:57:09 am by 3roomlab »
Offline David Hess
  • DavidH
« Reply #46 on: May 27, 2017, 06:56:30 pm »
I think you did it right however I have never seen any designer bother with this because ...
... the larger problem is surface resistance do to contamination.  There is also a question about how consistent the printed circuit board material is.  Manufacturers seem to be better about the material used for parts packaging than FR4 board material.
The one exception I have seen is when guard traces are used.  Then adding vias from top to bottom through the guard traces will intercept leakage through the volume of the board material but you have to be doing something pretty extreme for this to matter and it may have more importance preventing coupling capacitance to other nodes.  The RF guys use via like this for completely different reasons.
The surface contamination problem is a real killer and especially so with surface mount parts where air wiring is even more difficult and spacings are closer.  The closest I have seen this done with surface mount parts is cutting slots through the board and not for high voltage isolation but how do you do this with such small pin spacings?  Unfortunately the newest ultra low bias current parts are not available in through hole DIP packages somewhat limiting their ultimate performance.
