Author Topic: Possible New Dumpster Winner  (Read 1186 times)
Offline msuffidy
« on: June 10, 2021, 07:58:45 pm »
I used to own a (low quality) used guitar I sold because I didn't want to spend time learning to play it. I have been sort of regretting getting rid of it. But hey it's ok because last night I found an electric guitar in my garbage room. It had a broken string but I think I can get another. Controls are a bit scratchy but the line voltage is like mic voltage so I don't know what to expect. To date I have found 4 monitors in my garbage room, 3 of which had no problems, one mac router/dsl modem combo, and a few minor bits, and 6 sealed bottles of champagne.
https://www.facebook.com/matthew.suffidy.1/posts/313666933742165
« Last Edit: June 10, 2021, 08:10:13 pm by msuffidy »
Offline HowdyPartner
Re: Possible New Dumpster Winner
« Reply #1 on: June 10, 2021, 08:38:44 pm »
Looks like a Yamaha Pacifica. There is a metal thingy missing, you might want to go back and look for it. [attach=1]
Online themadhippy
« Reply #2 on: June 10, 2021, 08:52:11 pm »
its  a wammy bar,or in polite company tremolo arm.
Offline msuffidy
« Reply #3 on: June 10, 2021, 10:17:07 pm »
I was aware of that but I am just learning so I was not expecting it to be a big deal. There is an open hole with no apparent damage so hopefully that is ok. I just went back, but the guitar was on top of a bunch of plastic recycling bins and I did not really look anywhere else. If it was in the real garbage it is under real garbage now and I did a quick look around the bins. nada I was just researching the issue and it looks like some people take it out and stick a block in there to keep it in tune. If that was not the case here I guess I would have to do it. It is a cheap but a bit important effect....
« Last Edit: June 10, 2021, 10:43:09 pm by msuffidy »
Offline msuffidy
« Reply #4 on: June 10, 2021, 11:09:04 pm »
I took the rear plate off and it looks like it was probably unscrewed and removed. I am not seeing damage. I don't know if the threads are still ok. There is a smaller hole on the bottom and you can see through to the opening where it was supposed to go. I've seen a lot of them without them maybe some don't come with it?
« Last Edit: June 11, 2021, 12:07:30 am by msuffidy »
Offline james_s
« Reply #5 on: June 11, 2021, 04:51:52 am »
Somebody probably removed it for one reason or another, maybe it got bent or broken. I wouldn't worry about it, if you get to the point where you can play it well enough that it matters then you can probably buy a replacement.
Offline dzseki
  • Country: hu
« Reply #6 on: June 11, 2021, 05:40:12 am »
Tremolo arms are for instant detuning of the strings therefore produce a "sliding" sound effect. They are easy to remove as they not that often used, also the arm itself may impede the player in playing. There are two flavours of tremolo arms, this is the simlplier one, this one is much easier to use (and tune the strings) but heavy usage may cause the strings get out of tune. The more complicated designs employ a locked nut right before the first fret, which holds the tune almost perfectly all the way, but the strings are ultimately more difficult to get in tune (whenever the temperature changes etc.)
HP 1720A scope with HP 1120A probe, EMG 12563 pulse generator, EMG 1257 function generator, MEV TR-1660C bench multimeter
Offline msuffidy
« Reply #7 on: June 11, 2021, 06:30:38 pm »
Thanks for the info. I managed to get the strings, costing $6 after tax Canadian, on today. I did the proper downward non overlapping winding. It so happens there is a music store not very far from where I live walking. I used to have a computer store also but it closed down. It was a learning experience. Have to keep tension while turning feeding from the bottom and holding the other side up. Some big probs are it seems the tone knob does not do anything and that is not a problem if it is not limiting anything as it is.
« Last Edit: June 11, 2021, 06:33:17 pm by msuffidy »
Offline james_s
« Reply #8 on: June 11, 2021, 09:48:08 pm »
Well that shouldn't be too hard to repair if you are inclined to do so, guitars are not electrically complex devices, the tone control is normally just a potentiometer in conjunction with a capacitor. Look for signs of damaged components and molestation, it's probably just a broken pot or a bad connection.
Offline msuffidy
« Reply #9 on: June 12, 2021, 02:07:46 am »
The way they seem to be usually wired is the tone pot is a dampener for the circuit effecting certain frequencies. Since pots probably fail open, in theory I already have the default although it does not sound like it. Also I don't see why I could not just bypass the volume and tone to just output 100% volume 100% tone without buying any more parts. Then external equipment could manipulate it. There could be issues with taking out the top plate with the strings on.
Offline james_s
« Reply #10 on: June 12, 2021, 02:18:20 am »
Why would you want to bypass them? There's a reason pretty much every electric guitar ever made has at minimum a volume and tone control. It's trivial circuitry.
Offline msuffidy
« Reply #11 on: June 12, 2021, 02:32:13 am »
never crackles again... and I found it in the trash. But I will keep my options open
Offline rjp
« Reply #12 on: June 12, 2021, 02:47:34 am »
Lots of people bypass the cheap pot and cap tone controls nowdays because the modern signal chain has far better tone modifiers on it than a simple treble rolloff
Offline msuffidy
« Reply #13 on: June 12, 2021, 03:44:28 am »
Next time I change the strings I think I will bypass the pots. I got the service manual, no surprises in store.
« Last Edit: June 12, 2021, 03:46:32 am by msuffidy »
Offline Brumby
« Reply #14 on: June 13, 2021, 09:28:54 am »
There's a reason they put those controls ON the body of the guitar.
