Author Topic: EEVblog #539 - RFID Tag Repair  (Read 30850 times)
Offline mobbarley
Re: EEVblog #539 - RFID Tag Repair
« Reply #50 on: October 28, 2013, 09:55:42 am »
Dave, would you like a compatible reader for a teardown? I work across the road from you.
Offline David_AVD
« Reply #51 on: October 28, 2013, 10:22:56 am »
Stalker Alert  LMAO!   :-DD
Offline mobbarley
« Reply #52 on: October 28, 2013, 10:31:36 am »
If only you knew what my occupation was...  ;)
Offline EEVblog
« Reply #53 on: October 28, 2013, 11:25:26 am »
*waving* (from my windowless box)
Would it do anything useful without the system connected to it? What model?
Offline mobbarley
« Reply #54 on: October 29, 2013, 08:18:33 am »
Sure, it will beep and you can read out the card number via wiegand pulses. I have some documents on the way a HID card is read/programmed too. Probably only interesting if you want to do a more in-depth blog on rfid.
