Author Topic: EEVblog #542 - ZD985 Desoldering Station  (Read 117257 times)
Offline Muttley Snickers
Re: EEVblog #542 - ZD985 Desoldering Station
« Reply #150 on: April 01, 2015, 02:21:29 pm »
Just got my ZD-915 from bourne electronics in Melbourne at the bargain price of $189. Best thing I have bought in ages! The desoldering pump works like a dream. No more burnt fingers and the components just drop off the board like Dave showed in the vid. I got a bit carried away desoldering a pcb from a old pc power supply trying all the different components. My only slight criticism is the filter in the pump seems to get clogged after a bit. Has anyone tried cotton wool as a cheap alternative to the little filter pads? Dunno if the solder might be a bit too hot for it and start to burn it? My missus was nt impressed, when I suggested I can now grab peoples electrical rubbish for component salvage.  :-+
 :palm: You did really good dude... :-+ if you need some filters or tips then let me know with a PM because I bought a few to many last time from Rhino, I am also " happy " to advise on a few tricks for the best performance of the unit that you have purchased.
Best Regards and Life Solder Sucks
Muttley
« Last Edit: December 15, 2015, 01:37:03 pm by Muttley Snickers »
Offline AHT52
« Reply #151 on: April 02, 2015, 08:41:08 am »
Sorry the confusion. I meant the ZD-917 the dual desoldering/soldering iron. It was after a long day hv switching, I was a bit cream crackered. :=\ I still love it tho the solder station that is, although being a A.P keeps me in job. I do agree tho about the price of stuff here in oz, when you compare it to the U.K can be a bit dear. In screwfix you could buy 1000 BZP m5 nuts for £5.65=>$11.30ish where as here I have nt found anywhere as cheap here yet. Does anyone know any cheap fixture and fasteners shops/online companies here in OZ?
I had a look at Rhino tools Muttley and for a dollar for a set of filters can`t be bad.
« Last Edit: April 03, 2015, 03:13:16 am by AHT52 »
Offline Jidis
« Reply #152 on: April 04, 2015, 05:21:36 pm »
Try stuffing a wad of glass fiber batting in there and see if it helps.  I don't get solder on the spring and it cleans up with a pair of tweezers.
Thanks for the tip. I'm going to try that on my next desoldering job. I use a CSI (Aoyue?) 474 and I dread that part. Like the previous poster, with mine, I have to wedge a hot iron tip into the spring while holding it with a pair of pliers, then pull up on it and let it snap back down until it releases the glob. It's as much of a PITA as it sounds like and usually takes several tries. I was anxious to see what happened on Dave's, but his just popped right out. I did notice his spring was a bit larger at the tapered end than mine.
Take Care
Offline GreyWoolfe
  • NW0LF
« Reply #153 on: April 04, 2015, 07:42:43 pm »
Is there anywhere else besides Australia to get parts for the ZD-985.  The prices are fine but shipping to USA has to suck.
Online Rasz
    • My random blog.
« Reply #154 on: April 05, 2015, 11:02:18 am »
what parts? the gun is the same as 915-917, and costs $17
Offline dav
« Reply #155 on: April 26, 2015, 07:29:04 am »
Due to the poor quality of the gun, did anyone replace it with a better one?
Are there better quality compatible guns for ZD985?
Online Rasz
    • My random blog.
« Reply #156 on: April 26, 2015, 08:10:34 am »
What are your main complaints about this gun? I only used this and xytronics desoldering irons, so have no comparison to the top shelf stuff :(
Offline dav
« Reply #157 on: April 26, 2015, 09:11:33 am »
I would buy it (it costs about EUR 90 in Europe), but I'm unsure due to several people claim poor quality of the gun.
So I was wondering if I could replace the gun with a better quality one (if anyone tried this)
Online Rasz
    • My random blog.
« Reply #158 on: April 26, 2015, 10:19:47 am »
ehh, so you never used one (this or any other), and base it on 'some people claim" without linking to those people :/
price is ~$70
http://diolut.pl/stacja-rozlutownicza-rozlutownica-zd985-esd-grzalka-80w-p-4789.html
same as zd915
Offline dav
« Reply #159 on: April 26, 2015, 05:38:17 pm »
How do you rate it?
Do you suggest it? (for a non intensive use)
Online Rasz
    • My random blog.
« Reply #160 on: April 26, 2015, 06:10:34 pm »
How do you rate it?
I have no comparison :( I also had no problems using one, so no complaints.
Offline boffin
« Reply #161 on: April 27, 2015, 07:26:46 am »
It strikes me you could vastly improve one of these inexpensive desoldering tools by doing the following
1) Create a small vacuum chamber out of a couple of inches of 1" PVC/ABS pipe and hook that to the internal pump.
2) Change the pump switch to run off a vacuum switch to pull the chamber down to negative pressure (trial and error rqd here)
3) Change the trigger on the tool itself to open an air valve between the tool and the new vacuum chamber.
This way when you pull the trigger you get an initial whoosh of suction.
Online Rasz
    • My random blog.
« Reply #162 on: April 27, 2015, 10:55:54 am »
I think this
http://www.hakko.com/english/products/hakko_fr400.html
might have valve in the handle instead of pump switch
Offline N2IXK
« Reply #163 on: April 28, 2015, 11:44:11 pm »
Anyone else have to replace the heater element on one of these? I just did, and it is a relatively painless job... Except for the fact that the temp sensor is a thermocouple which is not marked for polarity in any way.  :-//  If you get it hooked up backwards you don't get a screwy temperature reading (as with most industrial TC systems). You get a display that stays stuck on 77F while the heater warms up.  After a few seconds the unit drops out on a fault. Presumably when there is no response from the thermocouple within X seconds,CPU sets an error (and hopefully) shuts down the element to prevent overheating.  Nice to see that they did put some thought to protect against this (or a shorted sensor), as well as having a separate fault for an OPEN thermocouple.
The replacement heater comes with tiny brass crimp sleeves, which need to be used because the thermocouple and heater element wires are not copper, and won't take solder easily. I did flow solder over them after crimping to fill any voids left in the dodgy crimps.
I replaced my heater because the tube got clogged with something that is resistant to melting, presumably oxides and carbon from flux, etc.  Got most of it reamed out with a drill but need a longer drill to get it all out.  Hopefully can save it for a spare. Not sure how it happened, as I'm pretty religious about running the cleaning rod through the thing.
« Last Edit: April 28, 2015, 11:48:45 pm by N2IXK »
"My favorite programming language is...SOLDER!"--Robert A. Pease
Offline dav
« Reply #164 on: April 29, 2015, 09:21:41 am »
Offline max666
  • Country: at
« Reply #165 on: April 30, 2015, 04:49:27 pm »
http://www.hotair.pl/pl/sklep/stacje-lutownicze/rozlutownica-odsysacz-cyny-zd-985-esd.html?keyword=zd-985
http://allegro.pl/rozlutownica-odsysacz-cyny-zd-985-okazja-i3689307025.html
~70$ (without delivery)
Site in polish but the shop sells in whole EU.
Thanks for the tip! I got one for 71,25 EUR + 25,52 EUR shipping. Site is in Polish, but they do speak English if you contact them.
I did some recreational desoldering and for the price this thing works really well.
this is how far I got until suction declined
some cleaning was in order
as I understand it the ZD-985 now has a new spring assembly and I had no issues separating the spring from the funky grown solder column
PS: I don't find the stand is that bad, yes it is flimsy, but I don't see me breaking it that easily.
« Reply #166 on: April 30, 2015, 05:15:14 pm »
When you put the spring in put some motor oil on it, along with the seals. that way the solder is easy to remove.
Offline Jidis
« Reply #167 on: May 03, 2015, 09:20:37 pm »
FWIW,
I've been using Rory's suggestion of fiberglass batting (from back at post #138) for the past few desoldering jobs. If there's a downside to it, I have yet to hit it. The solder never makes it back into that small end of the spring and it doesn't seem to noticeably impede the airflow either. Wish I had been doing it all along.
- this of course is for those more tightly wound springs with the cone shaped end
Offline gl
« Reply #168 on: May 11, 2015, 04:37:04 pm »
Does anyone know a ZD985 supplier in the UK or Europe that accepts Paypal, preferrably the ESD version?
Diolut in Poland (also on Allegro) have ignored my messages (even with a Google translation to Polish)?
Hotair (also Poland) have the ESD but only accept bank transfers (expensive for me + slow and no protection if something goes wrong) and shipping to UK is expensive.
Emporio Tecnologico in Italy take Paypal but only have the non-ESD version + waiting on new stock (this week appt.).
I wouldn't even mind importing from China, my usual go-to AliExpress doesn't seem to have it.
« Last Edit: May 11, 2015, 04:39:52 pm by gl »
Online Rasz
    • My random blog.
« Reply #169 on: May 11, 2015, 08:30:21 pm »
in the repair forum was a thread about broken pump, dude was able to directly mail Zhongdi(?) and they were happy to sell to him directly. You might try that route.
Offline gl
« Reply #170 on: May 11, 2015, 08:38:23 pm »
Thanks Rasz, I actually tried that (using their web form IIRC) but I haven't had a reply yet.  I'll try the two email addresses on that page.  Really strange that they're not even on AliExpress though, and nobody else in UK / EU?
Online Rasz
    • My random blog.
« Reply #171 on: May 12, 2015, 05:05:58 am »
Diolut sells them in Poland, but they dont ship internationally.
Offline wilhelm
« Last Edit: May 12, 2015, 03:49:15 pm by wilhelm »
Offline gl
« Reply #173 on: May 12, 2015, 04:22:29 pm »
@Rasz, good to know.  They coulda still sent a reply saying so though.
@wilhelm right, those are both ZD-915's (the other seems a rebadge), like the Duratool rebadge which is available in the UK here (this is a cheaper code then you get if you search for it), I could buy that here.
I prefer the 985 for the clear tube & overall design though (blue and white is nice :)).  And the new version heats up faster than the 915 right?
Offline gl
« Reply #174 on: May 17, 2015, 07:37:48 pm »
Zhongdi got back to me, but wanted 75USD (courier) / 65USD (airmail) shipping to UK.  They say the package is about 4kg, that can't be right surely?
