Author Topic: EEVblog #546 - Mailbag Monday  (Read 18746 times)
Offline tcleavela
Re: EEVblog #546 - Mailbag Monday
« Reply #25 on: November 12, 2013, 07:42:52 pm »
JAL looks suspiciously similar to Pascal, but without the confusing semicolon rules...
Looks like they swapped the semicolon rules for the infamous C-style assignment and equality operators.
Offline Vasi
    • Visual Pin Configurator for Nucleo L152RE - produces SPL code.
« Reply #26 on: November 14, 2013, 09:31:04 pm »
Hi Dave, is there a reason why my comment is not moderated on your blog? Should I post it here, or should I forget about? Anyway, no big problem but I would liked to know where and what I did wrong...
Offline olsenn
« Reply #27 on: November 18, 2013, 02:55:16 am »
Anybody know where I can pick up one of those cables for converting the screw terminals on the e-load to female banana jacks? Or a similar (high quality) product if that one is custom made for Dave
alm
  • Guest
« Reply #28 on: November 18, 2013, 07:47:12 am »
A spade lug to banana jack adapter like this might work (I haven't checked the dimensions of the terminals on the load). I'm sure you can also find commercially manufactured spade lug to banana leads.
