Author Topic: EEVblog #547 - Dumpster Phone Teardown  (Read 15621 times)
Online EEVblog
« on: November 13, 2013, 12:38:02 am »
Dave tears down and salves some parts from old Panasonic, Telstra, Cisco, Nortel, and Polycom PABX and VOIP phones found in the dumpster.
Are there any salvageable parts in them?
Offline nitro2k01
Re: EEVblog #547 - Dumpster Phone Teardown
« Reply #1 on: November 13, 2013, 01:06:19 am »
What about look at that grill through a microscope? And if you're feeling adventurous, maybe an attempt to reverse engineer one of the graphical LCDs? (Like the one 10:40 in the video.)
Offline NiHaoMike
    • Facebook Page
« Reply #2 on: November 13, 2013, 02:42:00 am »
The IP phones might be hackable, especially the ones that run Linux based firmware.
Offline rain
« Reply #3 on: November 13, 2013, 04:23:15 am »
The sidecar for the Polycom phones actually only transmits power over the 2 wire slide connector -- for some reason they decided to use IR to transmit between the phone and the sidecar.  You can see the IR modules (one on each side) by Dave's hands at ~8:25
I'm pretty sure none of the IP phones featured run Linux -- they've got relatively wimpy processors since most of their life is spent playing a single 8000Hz audio stream
« Last Edit: November 13, 2013, 04:26:43 am by rain »
Online EEVblog
« Reply #4 on: November 13, 2013, 04:37:13 am »
Yes, in my hasty teardown I missed that completely.
Offline Bored@Work
« Reply #5 on: November 13, 2013, 06:17:59 am »
Small correction. At 5:15
Quote from: EEVblog
Nortel are huge.
No, Nortel are dead.
Bankrupt in 2009, closed or sold most of their stuff piecemeal. The remains aren't worth to mention.
Offline HamiltonHipster
« Reply #6 on: November 13, 2013, 07:13:28 am »
Hi Dave,
  The speakers, especially the assembly with the bassport, look like a good opportunity to have a look at the frequency response and harmonic distortion of speakers...
Would you use the DSA measure these things?
Online Kjelt
« Reply #7 on: November 13, 2013, 07:55:55 am »
@5.34
1000V 16uF
???  would that perhaps be a 1000uF 16V  ;)
Offline chip273
« Reply #8 on: November 13, 2013, 08:13:25 am »
I didn't know so many phones would use standard hitachi controller LCD boards. I always assumed they all would use some custom LCD's with no chance of reuse. Thanks for that info Dave !
Offline daqq
  • Country: sk
    • My site
« Reply #9 on: November 13, 2013, 08:44:35 am »
Nice post.
Minor correction: The encoders in phone #1 are not optical, they are mechanical such as these ones: http://www.sos.sk/a_info/resource/a/pdf/ec11.pdf
Far cheaper, far easier to use.
Offline nathanpc
  • Country: br
    • Innove Workshop
« Reply #10 on: November 13, 2013, 03:56:28 pm »
I really like these dumpster teardown/salvage videos, it's incredible the amount of stuff that you can get from the trash.
I thought the same thing. It's incredible how popular they are.
Offline DutchGert
« Reply #11 on: November 13, 2013, 04:42:38 pm »
What are those rectangular pads on the Cisco board (from 14:17)? I also seen them on a Intel Ethernet board but what are they for? There are not grounded, no via's in them, just floating square pads with solder mask on them.
Offline fcb
  • Test instrument designer/maker G1YWC.
    • Electron Plus
« Reply #12 on: November 13, 2013, 05:13:21 pm »
Fiducial's for vision recognition.
https://electron.plus Power Analysers, VI Signature Testers, Voltage References.
Offline DutchGert
« Reply #13 on: November 13, 2013, 05:27:56 pm »
Dont think so, whole board is covered with them and they have solder mask on them
Offline NiHaoMike
    • Facebook Page
« Reply #14 on: November 13, 2013, 05:29:41 pm »
It's pretty common to find $10 wireless routers running Linux.
Offline killy
« Reply #15 on: November 13, 2013, 06:51:58 pm »
Whoa! This episode became almost mike's-fast :)
Dave, can you put some board photos to flickr, please?
Online Kjelt
« Reply #16 on: November 13, 2013, 07:33:20 pm »
yeah wondering the same thing, only thing I can think of is that this is cheaper for the pcb manufacturer because they don't have to edge all that copper away, if you produce hundreds of thousands of these pcb's that can save quite some money on the edging fluids. And if there is a mistake in the pcb you can add some fixes on these pads but then naaaaah.
Offline NickS
« Reply #17 on: November 13, 2013, 10:53:21 pm »
Actually virtually every consumer router is Vxworks or Linux.
As for phones it depends on the complexity of the phone if they would go for Linux or not.
I'm pretty sure my Gigaset VoIP phones use Linux (or equivalent) however they have a full web interface where some of these phones would not.
Offline jh15
« Reply #18 on: November 14, 2013, 12:15:57 am »
How do I get started firing up those standard LCDs?  I have some arduinos kicking ariund.
Tutorials and data sheets links anyone?
tek 575 curve tracer top shape, 535 top shape, 465. 545 Hickok clone, Tesla Model S,  Ohio Scientific c24P single board computer, many c-64 from my club days, Giant electric bicycle, Rigol stuff, Heathkit AR-15 receivers, Heathkit et 3400a trainer and interface,
Offline calexanian
    • Alex-Tronix
« Reply #19 on: November 14, 2013, 12:28:37 am »
At some point a friend of mine had something to do with the audio quality at polycom. I have no idea if this was one of his designs with the seperate enclosure and the fancy bit over the mic, but I would not dobut it. He specialized in that sort of thing and whoever took over after he left kept on going with some good stuff.
Charles Alexanian
Alex-Tronix Control Systems
Offline Atreidae
« Reply #20 on: November 14, 2013, 12:53:42 am »
Looks like Rain beat me to it, Poly continued this trend even on their newer colour sidecars too.. We always assumed it was some sort of isolation thing but it doesnt make much sense does it?
Ill add too that the order Dave reviewed the phones in was not the order they were produced in.. I didnt get a good look but the handsets looked like an
IP 301. a lower end early IP Phone from Polycom
IP 330 or 331, Midrange "current" generation phone there were also more powerfull processor and audio wise supporting a massive 22khz!
IP 501 High end phone of the same series as the 301
Dave's commend about "they learned their lesson" re the double sided load wouldn't apply as the 501 is an older unit than the 33x
Just realized, I'm apparently a phone nazi
Interesting fact the early x01 series were notorious for rebooting whist using speakerphone and powering them via 802.3af (Normal PoE)
The Polycoms are actually pretty complicated from a software prospective, upon bootup they will grab provisioning details via DHCP option 66, connect to an FTP/TFTP server and download their firmware, flash themselves, reboot, download their config and register to whatever PABX / SIP provider you are using (most commercial sip phones do this regardless) The Polycoms also have multiple stages of firmware, suggesting an OS + app so perhaps something like Vxworks or a linux kernel. They also have a built in webserver for reconfiguration and the ability to change VLAN tagging in the switch.. so alot of stuff to program from scratch.
I could go on about these phones for hours but I need to get some work done :)
« Last Edit: November 14, 2013, 01:02:23 am by Atreidae »
Offline Rasz
    • My random blog.
« Reply #21 on: November 14, 2013, 01:53:08 am »
Cheapest router boards start at ~$15 for really low end, and cheapest routers start at $20.
Cisco phones run VxWorks, there are many attack vectors for them including using one as a remote listening device over the network.
Offline Atreidae
« Reply #22 on: November 14, 2013, 04:05:47 am »
...Cisco phones run VxWorks, there are many attack vectors for them including using one as a remote listening device over the network...
I remember when I was trialing large Multifunction printers for a government department we had one of the devices malfunction in weird ways.. When the engineer came out and plugged his laptop into the console I't kept printing ascii art instead of debug info. Turns out it was a Virus targeted towards Vxworks
Offline Stonent
« Reply #23 on: November 14, 2013, 10:38:55 am »
Pretty easy:
http://arduino.cc/en/Tutorial/LiquidCrystal
Martin's video (the first one) talks more about serial LCDs but the parallel ones are more common and cheaper. The second video by Derek Malloy focuses on parallel displays which are most like what Dave salvaged from the phones.
As long as they LCD are using the Hitachi style interface, they're pretty easy. The third video by Jeremy Blum is pretty good also. Jeremy's videos are what got me started with Arduino.
« Last Edit: November 14, 2013, 11:32:53 am by Stonent »
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #24 on: November 14, 2013, 10:02:46 pm »
The TMS320VC5472 (Orion) is an ARM7 + C54x DSP designed for IP phones (some news releases here and here). It probably runs uCLinux or maybe Nucleus, QNX or VxWorks RTOS.
The TNETV1055 is a newer generation device with a MIPS and a C55x DSP and a boatload of peripherals.
The TMS320VC5402 is a DSP-only device...
