Author Topic: EEVblog #550 - Manfrotto Video Camera Articulated Arm  (Read 26019 times)
Offline EEVblogTopic starter
« on: November 21, 2013, 10:12:00 pm »
Dave checks out the Manfrotto 396B 3-section double articulated arm to see if it's suitable for his bench video camera work. Also, the Manfrotto 035 super clamp and the 237HD heavy duty flex arm.
DIY camera mount
DIY microscope stand:
Online eliocor
    • rhodiatoce
Re: EEVblog #550 - Manfrotto Video Camera Articulated Arm
« Reply #1 on: November 21, 2013, 10:34:42 pm »
I warmly suggest you the "Magic Arm" (obviously from Manfrotto!!!): you won't regret it!
I use this one: http://www.manfrotto.co.uk/magic-arm-with-quick-release-plate (very sturdy)
but maybe you will prefer this model which have variable friction: http://www.manfrotto.co.uk/variable-friction-arm-with-quick-release-plate
« Last Edit: November 21, 2013, 10:38:44 pm by eliocor »
Offline Anks
    • www.krisanks.wordpress.com
« Reply #2 on: November 21, 2013, 10:47:31 pm »
Manfrotto stuff is great we use there winch stands for lighting rigs.
Offline JoannaK
    • Diytao making blog
« Reply #3 on: November 21, 2013, 11:15:51 pm »
My main tripod is venerable 055, must be soon 3 decades old still working great.. Not as light as some newer ones, but **** stable.
Dave, did you clamp trough the ESD mat when testing 3-part arm? I'd expct that ESD mat to be somewhat soft and thus cause extra flex?
Offline Maxlor
« Reply #4 on: November 22, 2013, 12:43:37 am »
It occurs to me that you have the segments where you talk to the camera, and then there's the segments where you show us something on your bench. Ever considered using a head-mounted camera for the latter? It seems to work well for guys shooting sports videos. Maybe you're a candidate for the Google Glass, heh. Then again, too much camera movement is uncomfortable, and it's hard to keep your head still while working...
So maybe not a head-mounted camera, but an eye-ball-mounted camera, because even if your head moves, your sight usually stays focused on one area, right? I'm envisioning cyborg dave here, or Dave LaForge, hehe.
Cheers though. I appreciate the thought you put into increasing the quality of your video production.
Offline robrenz
  • Real Machinist, Wannabe EE
« Reply #5 on: November 22, 2013, 12:50:29 am »
Shameless self promotion of my solution here
Online BravoV
  • +++ ATH1
« Reply #6 on: November 22, 2013, 01:19:45 am »
Approved !  :-+ ;D
Offline hobbs
« Reply #7 on: November 22, 2013, 01:21:03 am »
Seconded.  I've been using Magic Arms on my optical tables for a good 15 years--a regular 1/4-20 set screw holds it to the bench amazingly well.  Best hundred bucks in tripods.
Cheers
Phil Hobbs
Offline staxquad
  • Eye Candy
« Reply #8 on: November 22, 2013, 07:39:48 am »
send him one, he ain't got no machine shop to make one (or your expertise)
finally put him out of his misery
"TEPCO Fukushima you long time"
You say Vegemite, I say Yosemite. (Ve-gem-mit-tee, Yo-zey-might)
"For starters : you're Canadian...."
Offline G7PSK
  • It is hot until proved not.
Offline EEgalitarian512
  • It is better to be loved/hated for who you are.
« Reply #10 on: November 23, 2013, 06:08:34 am »
Don't know if it is just me, but, this Manfrotto Articulated arm video does not show up in my YouTube "My Subscriptions" list. Curious.
Offline yvesdm3000
« Reply #11 on: November 23, 2013, 08:18:58 am »
I worked with the magic-arm (your first link) and that thing is awesome, VERY sturdy and all the movement releases with only 1 handle, very quick to handle that way.
-Yves
Offline jancumps
  • New Low
« Reply #12 on: November 23, 2013, 08:59:22 am »
Yes, curious. It shows up in mine. "EEVblog heeft één video geüpload  EEVblog #550 - Manfrotto Video Camera Articulated Arm •1 dag geleden •9.353 weergaven"
Offline amyk
« Reply #13 on: November 23, 2013, 09:00:03 am »
"Manfrotto" is a little too close to the (NSFW) term "man frottage" :o :o :-DD
alm
  • Guest
« Reply #14 on: November 23, 2013, 02:01:17 pm »
My two comments (worth at least $0.01 each), since this thread still has less than 1000 replies.
1. The Manfrotto stuff is very modular, like Legos. You could for example attach a stud like models 036, 037 or 066 to the superclamp, to which you could attach a ballhead or something like model 158 that should attach to a 036 stud and rotate.
2. In my experience you want as few degrees as possible that still allow you the range of motion you need. So try to have as few ballheads / joystick grips as you can get away with. Or trying to use a 1-axis joint (eg. model 026) instead of a ballhead joint. The magic arm or gooseneck is much better in that regard than the articulated arm with half a dozen knobs. Just undoing one knob, moving the camera to the correct position, and fixing everything with one knob is ideal. This does not apply to panning shots, but none of these setups appear to be suitable for panning anyhow.
Offline ju1ce
« Reply #15 on: November 23, 2013, 08:57:28 pm »
It happens to me too from time to time. Only when I come to the forums I notice that a new EEVblog video is out!
Offline Arie57
« Reply #16 on: November 24, 2013, 05:30:51 pm »
Hee Dave,
You got some advise to use de back of your table (not the wall). You said that it is too wobbely to connect your rig.
If you mount a piece of wood, let say with a width of 40+ cm, onto the pillars, then it become stable. Better is to make a cross to the pillars. This can be made with cable. But wood is the cheapest. Mount this with screws in the corner of the plate of wood.
(Always make a triangle. It's set a plane and also a ridget construction.)
Then you could also mount your rail onto this.
Arie
Offline Zad
    • Digital Wizardry, Analogue Alchemy, Software Sorcery
« Reply #17 on: November 28, 2013, 06:03:16 am »
I just present this as an idea for what it is worth...
When filming commercial television and video, the main camera would normally be directly opposite the presenter. I appreciate that for the most part, there is a slightly inconvenient wall and set of shelves in the way, but how about the space behind you? If you had a sturdy desk at right-angles to the back wall with space on both sides of it, you could have the camera conventionally mounted opposite you on a tripod - the extra space would perhaps allow you to use a "dolly" mount or a semi permanent track. Tripod dollies also have the benefit that they brace the legs, making them more sturdy.
Now clearly this isn't suitable for all filming, but it does mean that you aren't stretching over the camera and mount, and is generally a more professional approach which viewers in general are familiar with. If it came to it, the camera mount could be opposite you, but the camera mounted closer to your point of view. Moving the filming area into the middle of the room would enable lighting from more sides too, with space for fill and targeted spot lighting.
Offline Sebzy
« Reply #18 on: January 08, 2014, 01:31:13 pm »
Was just looking for a new mount for my theremin and stumbled upon this youtube video where the guy converts an old mic stand into a camera boom stand. Quite simple but provides great reach. The stand can be counter weighted too to offset the weight of the camera.
Nice cheap hack.
Offline lunar
  • Country: aq
« Reply #19 on: December 28, 2019, 07:57:24 pm »
It looks like this video is missing from http://www.eevblog.org/video/
