As someone else beat me to saying scan signals are commonly driven by the same signal as the HT drive circuit, I'll add it's only used in the horizontal (or in this case line) drive since they have to operate in the 15+ kHz range. Anyone else ever get driven, no pun intended, nuts by the the ringing noise given off by the flybacks in old CRT TVs?
I have to wonder about the repeler system though. I wonder if it used a static voltage or if it swept as well. Since it's safe to assume the electrons are all travelling at the same speed regardless of deflection angle (but not vleocity ;-) ), you wouldn't need as strong a repulsion voltage at the far end as you would the near end (referenced from the line deflection plates). Of course it's easy enough to use the line signal to synchronize this but it would be in reverse magnitude in relation to the line sweep. My brain SPICE isn't able to make it out looking at the schematic, but it would surely be something that would affect the astigmatism of the image.
Too much loon? Cheers!
