Author Topic: EEVblog #562 - More SMD Oven Reflow  (Read 32402 times)
Online EEVblogTopic starter
« on: December 28, 2013, 12:54:06 am »
Dave assembles his first uCurrent in the SMD reflow oven.
With random running commentary while pick and place assembling.
Offline jesuscf
Re: EEVblog #562 - More SMD Oven Reflow
« Reply #1 on: December 28, 2013, 03:50:05 am »
Securing the strips of parts tape to a piece of soft wood board with push pins is much easier than using tape.  The push pins fit perfectly into the tape's holes.
Homer: Yeah, but faster!
Offline dumle29
« Reply #2 on: December 28, 2013, 05:20:40 am »
Dave, you might want to take a look at this :)
The following users thanked this post: dave528
Offline nitro2k01
« Reply #3 on: December 28, 2013, 05:37:43 am »
Or as told by Mike:
« Reply #4 on: December 28, 2013, 05:39:50 am »
I know. I don't have a vacuum pump. Will eventually get one.
Offline scopeman
« Reply #5 on: December 28, 2013, 05:50:10 am »
Nice Job Dave.
Now you have me thinking about another project - a DIY SMD reflow oven. As if I need yet another project!
Sam
W3OHM
W3OHM
Offline MatCat
« Reply #6 on: December 28, 2013, 06:16:46 am »
Nice Job Dave.
Sam
W3OHM
I just got done doing one, works fantastically, I am documenting it here https://www.eevblog.com/forum/projects/another-diy-reflow-controller/
Offline Nermash
« Reply #7 on: December 28, 2013, 09:06:53 am »
Will there be any review of that Metrahit Ultra?
Offline Michael_P
« Reply #8 on: December 28, 2013, 10:08:12 am »
Oh!
Dave, could you please recommend or suggest any cheap source of current reference, it would be perfect.
« Reply #9 on: December 28, 2013, 10:17:22 am »
http://www.voltagestandard.com/DMMCheck_Plus.html
Simple low cost one, though might not be to the spec you want.
Offline redben
« Reply #10 on: December 28, 2013, 11:13:25 am »
How would you use this oven with smd parts on both sides ?
Does the soldering paste hold the components upside down ?
« Reply #11 on: December 28, 2013, 11:24:54 am »
You would need an extra stencil to screen on an adhesive to hold the components, allow it to dry then screen on the paste, then place the underside and activate the adhesive to hold the components. Then paste the topside and place and reflow to do all at once. You can see this on some boards where the components are held down by red dots of thermoset adhesive then reflowed.
Offline trackman44
« Reply #12 on: December 28, 2013, 12:59:23 pm »
Now that, my friends, is uCurrent Gold #1!! Would probably be worth alot.
Will
How 'bout them Maple Leafs?
Offline Towger
  • Country: ie
« Reply #13 on: December 28, 2013, 02:45:22 pm »
What's the ticking sound during the oven shots?  It seems to be there when the oven is not on, so not the controller turning it on/off.
« Reply #14 on: December 28, 2013, 02:50:12 pm »
For the class required to test the uCurrent, no such thing as really cheap. I'm building a not-so-cheap one now, but still <$100 maybe.
Offline robrenz
  • Real Machinist, Wannabe EE
« Reply #15 on: December 28, 2013, 02:51:12 pm »
Probably the oven mechanical timer. It would have to be turned on for the oven to work since the oven mains plug goes into the controller output.
Online mikeselectricstuff
    • Mike's Electric Stuff
« Reply #16 on: December 28, 2013, 03:22:41 pm »
Unless you have big/heavy parts on both sides, you don't need glue - surface tension will hold parts on during the second reflow.
Probably the biggest difference is your stencilling setup needs to be able to support a board with parts on the underside when stencilling the second side, and of course you need to support the board during reflow.
Day Job: Mostly LEDs
Offline trackman44
« Reply #17 on: December 28, 2013, 05:39:12 pm »
You could hack the oven and remove the timer, if its only purpose is for reflow work, but I wouldn't toast anything edible, that's for sure :P
Will
« Reply #18 on: December 28, 2013, 05:44:45 pm »
Will
I left the electronic timer on my oven, and use it as a fall-back set to 6 mins to prevent incineration if I forget to check it..
Offline hikariuk
« Reply #19 on: December 28, 2013, 05:46:59 pm »
My guess would be the sound metal things make when they cool down and contract.
I write software.  I'd far rather be doing something else.
Offline ion
« Reply #20 on: December 28, 2013, 08:15:56 pm »
You could get an aquarium air pump and reverse the valves - I made a decent pickup tool like that.
Offline MatCat
« Reply #21 on: December 29, 2013, 01:08:45 am »
I just scored a VIRTUAL INDUSTRIES V8000 SMD-VAC-GP Vac pen on ebay for $60!  Got it in today and I must say it's pretty nice, beats the pants off of placing SMD with tweezers .  The model I have is an older model but the company still makes them and they start at around $300!  So I think I got a good score, plus ebay has variants of it.  I plan on doing a photo tare down to check it out, will have a thread for that soon :).
Offline Stonent
« Reply #22 on: December 29, 2013, 03:23:22 am »
Considering some of those resistors were in the dollar range, I could imagine costs going up significantly with precision.
Offline Stonent
« Reply #23 on: December 29, 2013, 03:36:52 am »
If anyone's looking to roll your own reflow oven, Kevin Darrah had a couple of nice videos on it.
He, like Mike, left the time enabled and also left the internal thermal protection enabled in case the microcontroller goes into a runaway mode. That way the oven will turn off by itself and at least won't go over the maximum safe temperature for the oven.  Also he found that he could get a lot better temp control by coating the glass with foil.  He also mounted a small fan in the back to circulate the air to help eliminate hot/cold spots but my concern with that would be even with the fan on a standoff, it could start to melt.
One thought I had is you could also do it without modifying the oven at all. Just move the electronics into an outlet strip or use a Power Switch Tail that is controlled by your Arduino.
The actual setup he had was, Arduino (well AVR board programmed as an Aduino), cheap Walmart oven, Sharp 16A/250VAC solid state relay with heatsink, a start button, K type thermocouple, Maxim thermocouple amplifier,  and a standard Hitachi interface 2 line LCD.
Video 1 is the teardown and conceptualizing of the design, Video 2 is his finished design and explanation of what he came up with.
« Last Edit: December 29, 2013, 03:43:30 am by Stonent »
Offline trackman44
« Reply #24 on: December 29, 2013, 03:49:56 am »
Wouldn't it be nice if you could cut some louvers on the top that were attached to a servo controlled by the Arduino? Then you'll have a proper cool-down cycle. That would be awesome.
Will
