But as I read you also got yourself a HD7850 and that one didn't work neither..
I can imagine aside from video capture , you would probably do stuff like looking up datasheets, viewing CAD work (always nice to know what to probe) and running some firmware debugger tools.
However keep in mind the other i7 (desktop model) has way more raw horsepower, but it can also be gross overkill if the only thing you do is internet & programming.
Where are you at trying to sort this out? Was that message you posted on Twitter referring to another instance of the AMD install or were you running some other install/upgrade at the same time? I have seen similar messages when trying several upgrades simultaneously.
Tell me you can be sure it isn't something stupid like inadvertently click starting the install when it was scripted to automatically start.
Well, I assume there isn't a rash of reports about this on their support site. In which case it seems probable that something peculiar to your system is at the root of it.
I hate to see you spend heaps of money on a new machine just as I would hate it if it was my money.
I'll order a new desktop PC tomorrow dedicated for this, no other choice really, going to cost about $850 or so.
This is starting to be a little retarded.
Uncompressed 1080p 60Hz is ~500MB/s so I highly doubt they are doing it raw. Cant they just give you proper drive and capture program?
have you tried my link?
https://trac.ffmpeg.org/wiki/DirectShow
"-vcodec copy"
Quotehave you tried my link?
"-vcodec copy"
Will that mix in audio from a USB mic too? Without that ability, it's useless.
Did you try -vcodec copy, as suggested?
Yep, didn't work. "unknown decoder copy"
That is probably bad syntax. Does this thing really enumerate as 'Integrated Camera'?
I am using the correct ID identifier as returned by ffmpeg, which also works with other commands.
Wow ... looking at Dave's struggling "just for recording", the Tagarno HD Microscope looking more like a fail product.
You'd have the exact same problem with any 1920x1080x60fps USB3 video source
No Dave, business sense talking here, not technicality, with that price tag, one should expect it works out of the box, no matter how proprietary hard & software they implemented in there.
My issue is that I don't think they really understand their recommendations and why they chose them.
Aha ... its clear now, so this product is not designed and thought "carefully" before hand by Tagarno them self to be used for recording.
Say for potential customers that are looking for view + record capabilities, like for instructors or presenter that has to show it live + record the material, I think these crowd should skip Tagarno product until they the maker them self really know clearly how to do that properly.
Have you ask Tagarno whether Intel QuickSync is also supported?
I really think, if they would still specify a gaming graphics card it's a bit lunatic. We rant on about soft power buttons on scopes and they consume a couple of Watts when "off", but I think this is not far off from the same category of "overkill" / they haven't really thought this through.
Is does work out of the box, plug monitor in and it works.
As for recording the video output Targarno have no control what PC you buy and use with it, they have a recommendation sheet about what specs you need.
I can go buy a $1000 and that meets the specs and it will work.
There is nothing proprietary in there, it is simply a high end sony camera that acts as USB 3.0 webcam at a fixed 1920x1080 @ 60fps camera. Capturign and encoding that in real-time takes a lot of grunt.
They simply say to use Youcam 6, that's it, that's all they know.
I tried ffmpeg and it shows the device has a format of yuyv422 1920x1080 @ 59.9402fps
When trying to record using the example command:
ffmpeg -f dshow -i video="Integrated Camera" out.mp4
It says dshow is not a valid format.
Right. I'd still like to see the full output so I have a better idea of what I'm looking at.
It is amazingly hard to troubleshoot things otherwise, especially when the last time you used the tool was four years ago on a more consistent platform.
