watcher's activities list on eevblog:
- watch a guy scrapping the basement for old electronics
- watch the same guy walking at electronics fairs and ... do nothing
- see non sense - "repair" videos (i can't remember of any video of him actually repairing anything)
- see fotographs from postcards packed together with adaptor boards.
- see how you mount a camera on a bench
- learn to solder ?
not to mention, the hidden advertisements, emotional catches from showing his child (using the child for this purpose dave is inqualificable) ... you add to the list.
best to all.
peace.
Here's a couple (there are more), now you have something to remember! ;....
It's easy to be so critical when you don't know how much work goes into making videos and running a forum. Most of the time it's a thankless job.
yes. these are a bit better, but still not good enough. these are really really basic things. ofcourse, for a beginner, probably that's OK (with the note: begginers should probably first read some books, then be entertained), but yes.. ok for beginners.
from a random pick.. compare with this:
There was no sign of an inverter board on that TV, so i'd assume it is a LED back-light.
There was the common 25v supply used by inverter boards, unless the board was hidden under the white plastic base.
A while ago I got really fascinated by faultfinding and repairing, I know seems to be a black art, however at 60 years old, I have found a TV repair shop thats more than willing to help me along, and I'm loving it so much, the young guys in there seem genuinely pleased to help an old git,I have learned some of the boards and what they do.now I have forgotten something though, is it the inverter boards,Y main,Y sustain,X main , buffer board or T Con that run flat out, I think it's the inverter board,and is it, if the inverter board goes high damage will occur to the other boards, I maybe totally wrong which means later when I go down to the shop,Ill have to go through the whole excercise again.
Then I came across 2 monitors (manufactured year 2009) that have the 2 seconds backlights turning off, I couldn't fix them and told friends that the electronic boards were good, all good caps so I think is the ccfl, however I don't have any spare lamps to test with to find out for sure. I just gave up because you have to factor in personal time for such small gain (LCD monitors are cheap now).
benQ/dell/acer?
look for c5707 transistors in the inverter, those die producing effect you describe
What are you offering on your channel? Do you have one?
nothing really and no, i dont have a channel and that's because i'm not the one selling concepts around.
if we were to compare something, let's compare similar blogs across the spectrum.
your pick.. let's start with 3 proposals and rank them on (negociable) criterias:
- electronic insight offered
- degree of time "loosing"
- actuality and news
- [add more]
don't know which other criteria fits in, but eevblog fails the most and wins the "nerd entertainment" section.
any other criteria you might find usefull. please add. excuse my english. i'm not a native speaker.
My only complaint is that if Dave was going to do a TV repair video for blog #630, he should have done the famous RCA 630 chassis, which was the first mass-produced TV set, introduced just after WW2:
http://www.tvhistory.tv/1946%20RCA%20630TS%20TV.htm
Like the IBM PC in later years, dozens of manufacturers copied this design more or less completely for the first few years of TV. 630-derived sets are still widely available and popular among the vintage TV crowd.
