Author Topic: EEVblog #66 – Death & Destruction of a Fluke Multimeter  (Read 9207 times)
Offline PetrosATopic starter
« on: March 07, 2010, 04:18:53 am »
Dave, I want to be the first to say, I'm impressed! Even after the 30m drop, it seemed from what you showed us that it would be enough to replace the LCD and inductor again, and it would be as good as new (assuming that the board didn't crack and lose connection somewhere...). That's quality build!
Thanks!
On a side note I wanted to ask if, in your opinion, some kind of rubber or foam gasket around the LCD would make it more impact resistant or are there just certain limits to the force that an LCD screen will handle?
I miss my home I miss my porch, porch
Online EEVblog
Re: EEVblog #66 – Death & Destruction of a Fluke Multimeter
« Reply #1 on: March 07, 2010, 05:15:20 am »
Yeah, I haven't actually tried to fix it again after the 30m drop, but I don't see any major problem, I would be surprised if a new LCD and inductor didn't fix it again.
An extra rubber internal surround on the LCD housing assembly would make it more compliant in both on-axis and on axis directions of the LCD, and hence provide increased shock absorption. But there will always be limits of course.
I think they could make it even more rugged if they wanted to!
But geeze, it's impressive what they can do with impact resistant plastics and a standard glass LCD!
Dave.
Offline Ferroto
« Reply #2 on: March 07, 2010, 05:27:49 am »
Man that was like an Electronics Engineering version of Top Gear. That meter is all but bullet proof... or is it.  ;)
« Reply #3 on: March 07, 2010, 07:01:18 am »
Speaking of Top Gear, I'll bet you'd need something larger than a regular passenger vehicle driving over it to break that meter ;) (hint hint, Dave...)
Offline EEwannabe
« Reply #4 on: March 07, 2010, 07:32:12 am »
Dave, great video! I would have liked to have seen a crappy meter dropped from the 30m mark as a comparison. : )
- Patrick
Offline Squirrel
« Reply #5 on: March 07, 2010, 07:33:41 am »
I wait for hole videotime, that Dave runs over it with car.
Offline Ferroto
« Reply #6 on: March 07, 2010, 01:52:18 pm »
- Patrick
but will it blend....
*edit* better yet can it survive being placed in a hollow paint can and put in a paint shaker, specifically this one
« Last Edit: March 07, 2010, 01:56:23 pm by Ferroto »
Offline rossmoffett
« Reply #7 on: March 07, 2010, 10:51:57 pm »
Dave, this made me laugh so hard!
I had an idea once to make a blog called "ExtremeElectronics" where I would solder, calculate or some other electronics-related task while rock climbing or water-skiing.  This is pretty much what I've been wanting to do for a long time!
I was wondering, do you use a dry-rope for those water rappels or just man up and carry the extra weight on the way back home?
ArcAttack - A group of musical Tesla coil performers with semi-regular blog updates.
Online EEVblog
« Reply #8 on: March 07, 2010, 11:23:20 pm »
Dry treatment is a bit of a myth, it doesn't help much for canyoning, the ropes still absorb the water. And the dry treatment wears off pretty quick in this environment and pollutes the creek. So I just man-up and carry the extra weight on the way out, sometimes two packs if someone else can't hack carrying theirs. I had over 100m of rope for this 30m abseil.
Dave.
Offline Veramacor
« Reply #9 on: March 08, 2010, 03:27:04 pm »
Dave,
How about the skeet shooting test... :P
We have HUGE canyons here in Michigan BTW.  They are just filled with water at the moment.
