Author Topic: EEVblog #672 - GoPro Hero 4 Silver Teardown  (Read 29493 times)
Offline EEVblogTopic starter
« on: October 11, 2014, 10:52:27 am »
What's inside the new GoPro Hero 4 Silver action camera?
Dave tears it down!
Ambarella A9 Chipset: http://www.ambarella.com/uploads/docs/A9%20Product%20Brief%20120813-2.pdf
TI TLV320AIC3212 http://www.ti.com/product/tlv320aic3212
Offline dr.diesel
Re: EEVblog #672 - GoPro Hero 4 Silver Teardown
« Reply #1 on: October 11, 2014, 11:27:13 am »
I really hope the 720P@240 is somehow just a in the works software snafu.  That was my primary buying consideration, with 4k just a nicety.
« Reply #2 on: October 11, 2014, 11:29:08 am »
Yep, I was really hoping for and expecting that. Maybe some clever cookie will hack the firmware? All the hardware in there is capable of it.
« Reply #3 on: October 11, 2014, 11:49:54 am »
More impressive is that it went together again. I agree that that heatsink compound is hard to replace, likely a custom pad from Bergquist, which you could probably get as a sheet ( at a price no doubt) and trim to size.
Upgrading frame rate would probably be merely a firmware switch flip, likely like the E4, it all is in there but disabled. Wonder what the few bits difference between upgrade firmware for the black and the silver is. Might work but unless you get better cooling for the processor and support chips along with the sensor it possibly could cause issues in very hot environments or in cases where there is no ability to dissipate heat in any case.
Offline Legit-Design
« Reply #4 on: October 11, 2014, 12:30:11 pm »
Quote from: EEVblog
Striking the Youtube search terms before anyone else has a teardown up, this is a world first AFAIK.?
Even if someone did a teardown there would be no contest compared to yours. Usually people don't talk on teardowns or if they talk they just show how little they know about something. I don't blame them since not everyone has decades of industry experience. But quality and insight will always win over being first or shelling out multiple videos without much content in them. I still think PS3/PS4/X360 or any other console that has multiple teardowns and if you did a teardown of one then the insight and knowledge into design aspects and all kinds of things would definitely make it worth watching.
Offline max_torque
    • bitdynamics
« Reply #5 on: October 11, 2014, 02:13:50 pm »
The lack of soldermask over the pcb that houses the CCD might be just to ensure that the sensor is sitting parallel to the lens assy when screwed down?  (assuming the flatness of the copper layer is likely to be much better controlled than that of the solder mask layer etc)
Offline ratdude747
« Reply #6 on: October 11, 2014, 04:17:08 pm »
Looks like heatsinking to me as that lens frame is indeed metal with some sort of coating/anodizing (the threads on the inside give it away)... I'd wager that there are more places for lens lineup wear in the sensor's mounting to the board than there is with the solder mask.
What would be really clever would be if the coating used was thermally dissipative, like is used on some purpouse-made heatsinks. It looks that way from here at least.
Offline dentaku
« Reply #7 on: October 11, 2014, 04:46:07 pm »
The sound quality is amazing for such a tiny camera.
Offline bigsky
« Reply #8 on: October 12, 2014, 07:54:00 am »
The soldered-on backup battery was interesting. I wonder if that means GoPro regard the camera as having a life of a few years, after which it is scrap as this battery can't (easily) be replaced. If so, that's a bit thumbs down from me.
« Reply #9 on: October 12, 2014, 08:03:35 am »
I think that will be a rechargeable battery there, only meant to keep the clock running for a few months if you are not using it. Yes it will eventually die, but that is likely only after 10 years or so, when the rest of the plastic parts are more than likely to have disintegrated in any case from just exposure to light and air.
« Reply #10 on: October 12, 2014, 09:13:52 am »
Those usually last much longer than a few years.
« Reply #11 on: October 12, 2014, 09:15:16 am »
I just LOST the GoPro in a canyon today!
It currently resides in the bottom of a 3-4m pool in Fortress canyon.
 |O
Offline nowlan
« Reply #12 on: October 12, 2014, 09:29:17 am »
Doent it float? Invest in ping pong balls on string next time.
Bad luck.
Offline HighVoltage
« Reply #13 on: October 12, 2014, 10:16:46 am »
Wow, sorry you lost it!
Being in the market for a GoPro for my son, I really enjoyed the details for your teardown on a weekend and watched it together with my children.
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #14 on: October 12, 2014, 10:22:13 am »
Hardly scrap - it would just mean the RTC doesn't keep time.
Day Job: Mostly LEDs
Offline firewalker
  • Country: gr
« Reply #15 on: October 12, 2014, 10:24:16 am »
 |O
Was it in an airtight case? Provide photos in order to design apparatus to salvage it!
Alexander.
« Reply #16 on: October 12, 2014, 10:25:24 am »
Only 3-4m deep..?  SCUBA time?
Fishing trip with a camera on a string maybe...
Offline max_torque
    • bitdynamics
« Reply #17 on: October 12, 2014, 11:36:08 am »
Next week on EEV, Dave modifies his Sinclair C5 into a Piloted Underwater Vehicle............   Who says electricity and water doesn't  match!  ;-)
« Reply #18 on: October 12, 2014, 12:38:16 pm »
In the stand waterproof case with the new touch screen window on the back. That window is only rated to 3m, so I don't expect it to survive for as long as the normal back door.
Also had the headband attached.
http://img.pecheur.com/headband-fixing-gopro-z-685-68518.jpg
« Reply #19 on: October 12, 2014, 12:41:43 pm »
A pair of googles and flippers would do it. We recovered a rope from the bottom, but no camera. Was too cold to spend much time there hunting.
The problem is it's whole days adventure to go back and search for it.
Offline firewalker
  • Country: gr
« Reply #20 on: October 12, 2014, 12:46:28 pm »
It will make a good video though!
Alexander.
« Reply #21 on: October 12, 2014, 12:56:09 pm »
Filmed with what?  ;D
Offline open loop
« Reply #22 on: October 12, 2014, 01:03:46 pm »
Review time for a really cheap action camera like,
http://www.banggood.com/Gopro-Hero-Extreme-Action-Bike-Sport-Waterproof-Camera-Wifi-Support-p-916900.html
Do a teardown and see how it compares to a real "action" camera. I also suspect you want to get what's on the card. Many people who loose a camera are not worried about the camera but want the last years of photos they forgot to download from the memory card.
Offline Bored@Work
« Reply #23 on: October 12, 2014, 02:30:44 pm »
Well, better it is only the camera than the camera and you still attached to the camera at the bottom of a 3m pool.
Offline firewalker
  • Country: gr
« Reply #24 on: October 12, 2014, 02:31:25 pm »
You still have the Pro 2, right? :D
Alexander.
Offline senso
  • Country: pt
    • My AVR tutorials
« Reply #25 on: October 12, 2014, 11:15:39 pm »
That heatsink pad in the main processor really looks crappy/crummy, with a reduced contact to the heat-sink..
Offline RobertoLG
  • Country: br
« Reply #26 on: October 12, 2014, 11:18:38 pm »
maybe one of these would help :runs:
« Reply #27 on: October 12, 2014, 11:44:40 pm »
« Reply #28 on: October 12, 2014, 11:45:42 pm »
I have the case for the GoPro 2  :-[
Offline dentaku
« Reply #29 on: October 13, 2014, 02:25:01 am »
A few years ago we went kayaking in a very dark lake to recover a GoPro with the headstrap still attached but it didn't work. The bottom of the lake was probably rather large rocks that anything can hide between.
« Reply #30 on: October 13, 2014, 02:36:46 am »
This pool, as are most in the sandstone blue mountains, sandy bottoms. So the camera could eventually bury itself in the sand.
Online coppice
« Reply #31 on: October 13, 2014, 02:41:36 am »
The way the front fixes it looks like dirt could work its way in there. Seems like a crude design for something to be use on the go, where keeping things clean is nearly impossible.
Offline digital
« Reply #32 on: October 13, 2014, 08:35:03 am »
Great teardown Dave I thought the gopro were toys now I know better, thanks for the video
Offline ovnr
  • Country: no
  • Lurker
« Reply #33 on: October 13, 2014, 10:26:27 am »
I was rather surprised that the thermal pads didn't seem to make better contact - it just seems to have flowed a bit between the surfaces on the main SoC, and the rest looks untouched.
Offline dentaku
« Reply #34 on: October 13, 2014, 04:16:44 pm »
Someone could make some money selling buoyant headstraps.
Offline ozwolf
« Reply #35 on: October 13, 2014, 11:00:52 pm »
A bit like this? http://shop.gopro.com/APAC/accessories/floaty-backdoor/AFLTY-003.html
I reject your reality and substitute my own.
Offline ConKbot
« Reply #36 on: October 13, 2014, 11:53:40 pm »
Ineresting comment on heatsinking of the sensor to the lens body. Perhaps its a there to provide heat to the lens as anti-fogging, perhaps as a secondary benefit, or maybe a main purpose.
Offline dentaku
« Reply #37 on: October 14, 2014, 01:28:33 am »
That looks useful but it would still be cheaper to make a headstrap that floats. Of course if the camera dislodges from the strap the floaty backdoor is better.
Offline NiHaoMike
    • Facebook Page
« Reply #38 on: October 14, 2014, 05:52:43 pm »
An excuse to get the 4K version (when it becomes available), evaluate how good the 4K quality is, and then do a teardown?
Offline CChin254
« Reply #39 on: August 17, 2020, 01:57:53 am »
I did an IC Identification and Block Diagram of this device:
The following users thanked this post: EEVblog
