Author Topic: EEVblog #690 - TDS220 Oscilloscope Autopsy  (Read 15880 times)
Offline EEVblogTopic starter
« on: December 07, 2014, 09:57:17 pm »
Dave dissects and then powers up the Tektronix TDS220 oscilloscope used in the Mud Run. Did it survive?
The Mud Run video:
Offline dr.diesel
Re: EEVblog #690 - TDS220 Oscilloscope Autopsy
« Reply #1 on: December 07, 2014, 10:24:55 pm »
Ha, that's awesome!
And it was underwater during most of this part:
« Reply #2 on: December 07, 2014, 10:31:29 pm »
Yeah, totally under for a while in a few places.
And you can see the tape had come off the vent holes by this time too.
I'm shocked there is hardly any residue inside.
Offline woox2k
  • Country: ee
« Reply #3 on: December 07, 2014, 10:39:01 pm »
I was waiting for that video after seeing the Mud Run one.
I am amazed how well it survived. Old gear but at least it has still some toughness left inside! :clap: This thing was not made in the Wun Hung-Lo factory, that's for sure.
Offline artag
« Reply #4 on: December 07, 2014, 11:15:36 pm »
I think the braid coil under the shielding is to link it to the nickel plating.
Offline justanothercanuck
  • Doing retro repairs...
« Reply #5 on: December 08, 2014, 12:44:39 am »
Could that screen issue be the video "data" cable?  Since it's still working for the most part, it kindof looks like a connectivity issue.  :-//
Maintain your old electronics!  If you don't preserve it, it could be lost forever!
Offline nitro2k01
« Reply #6 on: December 08, 2014, 01:07:36 am »
Request: Take the crustiest of the pots (or rotary encoders?) and desolder it and dissect it. Not only to look for mud, but to see the internal construction of it.
Offline Tek_TDS220
« Reply #7 on: December 08, 2014, 03:54:11 am »
"Rusted with age."  I don't think so, mine is perfect inside and it is 18+ years old.  Based on the corrosion on the boards, nickel plating, and steel chassis, yours must have been exposed to a corrosive environment.  It's a surprise it still mostly works.
"Slow as a wet week."  The refresh rate is slow by modern standards, but mine boots much faster than my Agilent, and the controls are very responsive.  It's nice to use when you want a quick answer.
Offline RJFreeman
    • Australian Technical Production Services
« Reply #8 on: December 08, 2014, 05:38:53 am »
Couple of things:
I replaced one of the BNC connectors on my TDS210 a couple of weeks ago. It was a very do-able job job, I had to remove the top shield in order to get access to the solder joints for the bottom shield which I had to remove in order to get enough room to desolder the joints on the BNC connector  - although if I had a finer tipped desoldering iron (I have a Hakko 808) I might not have had to bother but it was reasonably straight forward to replace.
It is s slightly odd ball BNC connector, made by TE Connectivity / AMP - I used part no  6274127-1 as it was available from Element 14/Farnell
Mine has had the mod (well it was sent back for it, and has a sticker saying it was carried out at least - is that being cynical?), and the Ground wire runs from the back of the mains connector across to a spade lug on the 'main board' the same is that one, and I would be surprised if the Australian Defence Force had not sent theirs back to be modified (they tend to be very fussy about such things).
Offline 84GKSIG
« Reply #9 on: December 08, 2014, 06:58:01 am »
the one i bought off ebay didnt have the strap  :-DD so is mine a fake  :( i personally dont think theyre a bad scope at all regardless of its age and i think daves just proven how rugged they are, did the power supply board look to have like a clear protective coating of some sort over the whole thing or was that just me?
Offline Vgkid
« Reply #10 on: December 08, 2014, 07:41:06 am »
I was surprised it survived that well, cool that i ran when first powered up.
Offline digital
« Reply #11 on: December 08, 2014, 08:31:30 am »
I bought one of the TDS220 scopes of Daves on ebay and the display on mine is far superior than the display on my Rigol 1052.The Tek will now replace the Rigol.
Offline G7PSK
  • It is hot until proved not.
« Reply #12 on: December 08, 2014, 08:54:14 am »
I think that scope has been to sea at some time. The insides look like salt exposure. I have seen lots of stuff looking like that coming off the oil rigs and boats on the North sea.
Offline 84GKSIG
« Reply #13 on: December 08, 2014, 11:21:26 am »
same here but mines replaced my siglent SDS 1102CML  :-+  i cant fault the TDS  220 for what i do its over kill but its helped pick up a couple of things i had no luck with due to the lag on the siglent
« Reply #14 on: December 08, 2014, 11:49:39 am »
Couple of things:
Did exactly the same with one I scored some years back.
It was a common breakage, those BNC mounting pins. Even replacements break the pins.
Remedy: scrub some of the conformal coating off the adjacent GND plane on the top side of the PCB and strap the BNC's down with a strip of thin copper sheet soldered to GND plane and BNC's. Quick work with a big tip and hot iron required. They don't come loose again.  :-+ With care it can even look quite neat.
Also had a failed backlight inverter in mine. Confirmed with the bright torch test.  ;) IIRC it was a 0.33 uF cap that set the frequency for the primary switching transistors for the 1150 V backlight inverter. Cap had drifted to a value in the pF region.  :o 30 c fix.
This unit had around 600 power cycles in its log.
Did some research on the "earthing" issue and my PCB was a SN after the recall, so Tek must have revised the PCB. All that stuff used to be on the Tek website, not sure now.
Had a look through my files and all I have now is the Users and Service manuals in PDF if anybody needs them.
Offline Muttley Snickers
  • Cursed: 679 times
« Reply #15 on: December 08, 2014, 12:16:27 pm »
Here's the recall notice and like tautech I have a truckload
of PDF manuals on these thing's, why I will never know,
I dont even have this model.
Muttley
« Reply #16 on: December 08, 2014, 12:27:03 pm »
Muttley
Me neither any more, but as Dave says they can go for good money and are reasonably easy to fix for their specific common faults.
Unfortunatly they were pre USB otherwise they would have been a good first scope even today.
It doen't take much in a modern scope to run rings around them though, but they have good basic functionality.
Offline lampbus
« Reply #17 on: December 08, 2014, 10:52:41 pm »
It's nice to see inside, I envisaged the main PCB would be vertical like the PSU board...from looking in the vents on my TDS210.
I love my TDS210, but long for the TDS2MM module that is no longer available anywhere...and people want silly money for complete units on ebay...more than the price of a far more capable brand new Rigol.
I found a mention on another forum of code that could be flashed into a TDS2CM module to make it into the MM type...never found a download though. (THe CM has the comms ports...the MM added measurement routines to the CM)
