Author Topic: EEVblog #693 - AVO Transistor Analyser Teardown  (Read 20974 times)
Re: EEVblog #693 - AVO Transistor Analyser Teardown
« Reply #25 on: December 17, 2014, 07:56:11 pm »
That is a standard depot level mod plate. Basically used if there was a manufacturer field upgrade issued, which would be implemented by a service depot, and then they would punch the level done with a small circular punch to obscure the required number. You might have a unit that has eg only mod level 3 done, while an older unit might have levels 1 and 2 done, as it would be serial number dependant as to which mod is applied. In a device like this there would likely be no mod state as the unit would be returned to manufacturer for servicing and upgrade, and would not have the sticker done but the version would be in a serial number range.
Can be very confusing in having items which are use specific, such use being determined by the mod number. Thus you can have an indicator that has 2 varieties, one for use in a particular application but only if it has the specific mod level applied by the service base. The other one looks identical, but is not usable in this application as the mod state is different. Was often used with RPM indicators where there were 2 different gearboxes in use, and they were slightly different in the RPM output drive, such that you would get a slightly wrong indication if you used the wrong gauge. Pilots tent to get a bit tetchy if the 3 gauges are not in the same position at a specified power level with good engines, even more so when it is a dual indicator and a split needle is an indication there is about to be a loud bang and the big fan keeping the pilot cool is about to stop. Had to go to the stores and pull all the stock to get the right mod state, and sent the old one back as " not suitable for mod statexx".
Offline G7PSK
  • It is hot until proved not.
« Reply #26 on: December 17, 2014, 09:15:30 pm »
Those batteries are half a No.8 cell. No.8 cells were very common at one time for pocket torches, two cells in a cardboard tube giving 3 volts. I was trying to remember the No8 cell name earlier but could not, I used to use them in torches many years ago in my first torch a black with silver stripes Ever Ready torch made from aluminium. I was nearly ten years old when that unit left the factory.
Offline German_EE
« Reply #27 on: December 17, 2014, 10:07:02 pm »
At 56 next birthday I'm beginning to wonder if I'm the oldest person on the EEV Blog board?
Warren Buffett
Offline EEVblogTopic starter
« Reply #28 on: December 17, 2014, 10:12:59 pm »
Imo a C cell battery would fit perfecly in those battery cans .  :)
Do you think so? They looked just a bit too small to me - but then again, I don't handle C cells much.
Nope, C cells don't fit.
Offline Macbeth
« Reply #29 on: December 17, 2014, 10:15:35 pm »
SeanB - Interesting, I think I would give up and leave those labyrinthine logistics to the NCO in charge of the Quartermaster's Store.
My eyes are dim, I cannot see...
« Reply #30 on: December 17, 2014, 10:18:20 pm »
My first thought when seeing those flatish devices marked 1R is that they were diodes. I would never have thought them to be capacitors. Are you sure Dave?
Agreed. They're IR (International Rectifier) 2E1 diodes.
Yes, they are back-to-back diodes.
Offline robrenz
  • Real Machinist, Wannabe EE
« Reply #31 on: December 17, 2014, 10:37:47 pm »
Your not even close ;D
Offline Dave Turner
« Reply #32 on: December 17, 2014, 11:10:53 pm »
Nope - beat you but younger than robrenz!
Offline w2aew
    • My YouTube Channel
« Reply #33 on: December 18, 2014, 05:07:33 am »
Well, there are at least a few of us in the over-50 club. Didn't I see a poll in the past that asked the forum member's age?
FAE for Tektronix
Offline rf-loop
« Reply #34 on: December 18, 2014, 07:26:28 am »
Nice equipment and no FW bugs!
Also in over 60 club.
« Last Edit: December 18, 2014, 09:40:11 am by rf-loop »
I drive a LEC (low el. consumption) BEV car. Smoke exhaust pipes - go to museum. In Finland quite all electric power is made using nuclear, wind, solar and water.
Wises must compel the mad barbarians to stop their crimes against humanity. Where have the wises gone?
Offline ciccio
  • Designing analog audio since 1977
    • Oberon Electrophysics
« Reply #35 on: December 18, 2014, 11:42:58 am »
No, I'm older than you: 64, 65 next birthday.
I used AVOmeters model 8  at work in the 70's,  bough one second-hand, kept it as a decoration in the lab shelves for 20 years and sold for 5 times the price I've paid it...
Best regards
Strenua Nos Exercet Inertia
I'm old enough, I don't repeat mistakes.
I always invent new ones
Offline rob77
  • Country: sk
« Reply #36 on: December 18, 2014, 12:51:19 pm »
According to http://www.vintage-radio.net/forum/showthread.php?t=78716
the 1289 4.5v cycle battery would yield 3 U10 sized cells. I've not tried it myself but may be worth checking out.
as far as i remember... yes , that should be the case ;) at least it was like that when i was a kid and i was taking apart batteries (30+ years ago) ;)
btw... the marking 3R12 for the 4.5V battery is because it's 3 times R12 inside... and R12 is the same battery as U10 is.
Offline G7PSK
« Reply #37 on: December 18, 2014, 03:17:32 pm »
There is a company here in the UK that still sells R12 or U10 batteries but at £4-70 each I would not use them as AA will fit if you put 1 or 2 coins of the right size under the coil spring as packers/spacers and wrap the AA's with some masking tape to centralize them. That meter also allows for external power so that is the easiest and cheapest way to go. AVO liked to use odd ball batteries, the AVO I have takes two 3R12 and a funny 1.5 volt sqaure shaped cell with screw terminals on top, I just use a D cell with wires soldered on the batteries last for 5 or more years. I had thought of using a 9 volt instead of the two 4.5 volt but the resistance range uses both 4.5 and 9 volt with the 1.5 used for offset on the AC ranges.
Offline bigsky
« Reply #38 on: December 18, 2014, 09:13:24 pm »
Dave, I am almost certain that your analyser is ex-military. The secret is the brass plate which shows a small arrow pointing upwards, this was the symbol for the War Department in the UK (now called the Ministry of Defence). Now that we know you are dealing with a military device it explains the build quality including the laced wiring, the chunky switches and the rubber seals.
I was Sagan's age when this unit was manufactured :-+
Sorry for late reply. I didn't exist when this was made. It's definitely ex-military.
The arrow is known as the broad arrow.
See http://en.wikipedia.org/wiki/Broad_arrow
The stencilling on the cover (visible in the first 15 secs of the video) is also a giveaway. The 13 digit number on it (6625-99-949-0872) is virtually guaranteed to be a NATO stock number, and indeed it's in the databases:
See http://www.nsn-now.com/Indexing/ViewDetail.aspx?QString=6625999490872
or http://www.nsncenter.com/PartNumber/40695B
« Last Edit: December 18, 2014, 09:16:02 pm by bigsky »
Offline SNGLinks
« Reply #39 on: December 19, 2014, 04:06:20 am »
I was 68 last July!
Offline steve_w
« Reply #40 on: December 19, 2014, 09:42:28 am »
The thing that gives it away as military is the NATO stock number on the front, the first 4 digits is the group/ class, 6625 = test equipment  next 2 numbers is the country code, 99 = UK (00, 01 = USA, 66 = Australia 14 = France) the rest is sequence numbers that dont mean much to techos.
Hope that jogs some memories
regards
Steve W
So long and thanks for all the fish
Online coppice
« Reply #41 on: December 19, 2014, 10:11:25 am »
The thing that gives it away as military is that its an expensive hand made device to do not very much. Any civilian lab with enough need for transistor testing to invest in serious equipment for the job bought something like one of the Tektronix transistor curve tracers. They cost a lot, but they also did a lot.
Offline (In)Sanity
« Reply #42 on: December 19, 2014, 02:05:10 pm »
I rather like this tear down.  It's a device that you can't just run out and buy and tear apart,  or that your likely to see at any time.  Would love to see it up and running just for the sake of doing so.   Age wise I'm guessing I have a year or two on Dave but not caught up with Alan.   I have one of the old Sencore Cricket transistor testers that still works perfect.
Jeff
Offline (In)Sanity
« Reply #43 on: December 20, 2014, 07:48:08 pm »
OK,  now I'm just sad that nobody else has commented on this video.   Guess I must be getting old and stuck in the past.   This stuff is great..but it would appear I'm in a small group of people that think so.   Ohh well,  I like my group.
Jeff
Offline ttp
« Reply #44 on: December 21, 2014, 07:17:23 am »
There is at least one older than you ;)
« Reply #45 on: December 21, 2014, 07:53:32 am »
Jeff
I have it's baby brother, which fits inside the battery casing. TYear down of that is likely to be destructive though, it was assembled from the face out and does not come apart easily once laced up.
Offline (In)Sanity
« Reply #46 on: December 21, 2014, 05:08:35 pm »
Jeff
I just wish more people were interested in the origins and history of the electronics industry.   Very few people build anything anymore with just a few transistors.   I myself am guilty of throwing too much technology at the simplest of problems.
Jeff
Offline Refrigerator
  • Country: lt
« Reply #47 on: December 21, 2014, 06:21:48 pm »
I just found my gramp's old resistance meter, maybe i should to a teardown of it ?
I have a blog at http://brimmingideas.blogspot.com/ . Now less empty than ever before !
An expert of making MOSFETs explode.
Offline Electronics-Repairman
  • More people talk about Electronics than do it
« Reply #48 on: January 01, 2015, 12:13:52 pm »
I'm 60 & will be 61 in May if spared
If it's highly recommended, then  I'm not interested.
